[Firmware Release] GL-MT6000 (Flint 2) - Version 4.8.5 Beta
L.E.
New Beta Firmware available for the GL-MT6000 (Flint 2).
Firmware Details:
  • Model: GL-MT6000 (Flint 2)
  • Version: 4.8.5 Beta
  • Build Date: 2026-03-25
  • * Download** Link:** * * 4.8.5
Firmware Details:
  • Version: 4.8.4 Beta
  • Build Date: 2026-02-27
  • * Download** Link:** * * 4.8.4
Thanks so much @staff :slight_smile:
Not tested yet, I plan to test it over the weekend and report back.
Please could we also have a beta with 4.8.4 as base and OpenWrt 24.10.5 ? :folded_hands: :pleading_face:
The open-source firmware op24/25 for Flint 2/Beryl AX need to take some times, R&D run into a few issues and they are scheduling resources and investigation to troubleshoot them.
Readed the title too fast :sweat_smile::rofl::joy::rofl::sweat_smile::rofl::joy:
@bruce op25 is still in beta, let`s wait until is stable :slight_smile: 24.10.5 which is the latest stable version should be great :smiley:
Also, clicking on
Recording 2026-02-28 223248
Drop-in Gateway still crashes the network :frowning:
Confirm that this issue still occurs in v4.8.4, since the front-end update is not merged in this version; and it will be merged in v4.8.5 (or the next release) to fix this issue.
The drop-in gateway function is available and works fine. If the IP cannot be obtained, you can also fill it in manually.
Thanks again :slight_smile:
Seems AmneziaWG 2.0 was added
good news
Flint2 as AWG2.0 is running with 2 Iphones, Beryl MT-3000 and Slate 1800AXT
( i tested both IOS: AmneziaWG + AmneziaVPN both work now)
Main-Issue was spaces between the Line in the H-Parameters
Hint1:
The confs from the QR-scans are refused in the IOS-APPs. Edit manually the spaces away between the H1 = xxxxx-xxxxx
and use the correct I1-Parameters:
I1 = <b 0xc30000000108><r 8><b 0x00001f><r 2><b 0x06001a><r 26>
You can install AmneziaVPN (v4.8.14) in iOS, which now supports awg 2.0.
Flint2 firmware v4.8.5: the WG server has been upgraded to awg 2.0 and remains backward compatible clients with awg v1.0 or standard wg.
BTW the WG client of firmware v4.8.5 also now supports awg 2.0.
When mt5000 or brume 3 will have 2.0 support?
Brume3/MT5000 has released a firmware version that's currently in testing.
But AWG 2.0 might be supported in the firmware version after next.
Just a note: v4.8.5 doesn’t exist in the firmware download center… I’m assuming it got pulled. v4.9 beta exists now though.
