tando
December 2, 2024, 9:11am
I want to update my E750 travel router with this firmware file: openwrt-e750-4.0-release30319-0906-1725586285.tar But the router is telling me that this file or firmware is older than the firmware I am currently running on
Below is a screenshot of my current firmware
What can I do to solve this, cause it seems like this is the right firmware for my device?
alzhao
December 2, 2024, 9:52am
2
You are having a 3.x firmware now. So when upgrading to 4.x firmware it may report incorrectly.
Pls upgrade without keep settings and it should be fine.
But I don't know why you have a VB_3.201 firmware. Seems it is from a business order.
tando
December 2, 2024, 9:53am
5
When i try to update i got this message:
tando
December 2, 2024, 9:55am
6
I don't know by it have a VB_3.201 firmware either, since never upgraded it and just bought in online from an online retailer
alzhao
7
Pls update without keep settings.
tando
December 2, 2024, 9:57am
8
If i don't keep the settings i have to configure the router all over again?
slesar
December 2, 2024, 10:00am
9
Yes. You could do backup settings
tando
December 2, 2024, 10:25am
10
I didn't know that it was possible to backup your settings.
tando
December 2, 2024, 10:40am
11
I did install the firmware and i didn't keep the settings but now I can't find a way to install my openVPN client.
tando
December 2, 2024, 3:42pm
13
I rebooted my router and after that, I could enter the VPN section, but unfortunately, the VPN is not working. In the screenshot, you can see that it wanted to write something on a /tmp/run/Ovpn_resolved_ip folder, but that folder isn't there
tando
December 2, 2024, 7:07pm
14
I solve the problem so help is not needed anymore at this stage. Everything is working normal again
alzhao
December 3, 2024, 2:00am
15
From your log you used the wrong username and password from Nord.
Pls kindly confirm.
tando
December 5, 2024, 11:30pm
16
Yes true. They changed the rules. You cannot use the normal username and passport anymore but it has to be encrypted
system
Closed
June 3, 2025, 11:30pm
17
