When will the Opala (GL-SFT1200) Firmware be updated?
What updates do you want, what functional requirements do you have?
I would like new functions the same as those in the Opal beta Firmware (GL-SFT1200)
SFT1200 has released v4.7.2 beta.
GL.iNet download center
Please review the update description and describe the features/requirements you would like to see improved.
This way we can determine whether your needs are included in our version update plan.
I would like the function of using an external hard drive on the USB port. In this beta version would it be possible to use this function?
Do you want to set up file sharing?
SFT1200_V4.7.2 beta supports the use of file sharing, but only supports the samba protocol.
I managed to get it to work 100%, thank you very much.
this beta is from april 2025.
any plan to support the Opal and release a 4.7 stable?
It will take time for Opal-SFT1200 to reach a stable version of V4.7. Currently, we are mainly testing and optimizing the different functional requirements of the V4.7.2beta version.
If you have any new requirements or suggestions, please contact us.
What I would realy like is a way to map the switch on the side to a mode. IE can have router mode on one switch setting and acsess point mode on the other.
We will collect this requirement and bring to PM team evaluate it. Thanks.
