Firmware Upgrade
Hi, does anyone know how to reset my router to factory default?
The new 4.6.8 update broke my GL-MT6000 Flint 2 router, the loading screen froze, then it was updated and the firmware was updated twice, the networks no longer appear and the reset button does not work.
I had it installed but it installed normally, now I'm on beta version 4.7.0 Beta 2024-10-18!
https://dl.gl-inet.com/router/mt6000/beta
I can't access 192.168.8.1 anymore.
then use Debrick via Uboot!
I have done all the steps to enter Uboot but it does not work.
Are you using the 2.5gb port? If so, it doesn't work, it has to be somewhere in 1gb
Try so!
ScreenShot_20241018125004
I connect it port on 1
You can't, it has to be from the 3rd ethernet port
gl should update this tutorial because this process is missing....
They are geniuses and it works!
