Hmm, the firmware v.4.10.x for Slate 7 and Flint 3 add VLAN and AstroMesh functions.
Tested and it works, HELL YES!! It does create a new firewall zone for each new VLAN and enables isolation by default, but a quick fix is probably just to add the new VLANs to the LAN zone in LUCI if you need comms between VLANs.
Sono dovuto tornare alla v.4.9 su Flint 3. Dopo l'aggiornamento era sparita la rete Iot e non mi faceva entrare più su Lucy.
Anyone tried the AstroMesh yet? Curious how it feels.
Would be nice if you could add multiple vlans on the wan interfaces in the new vlan options, or could we get an optional managed AP mode if we’re already using 1 of the gl routers as the main one?
That's a great idea!
