i have version visible. i used the 5Mbps unlimited every day.
with my AR750S-EXT,
i can plug my pixel 4a into the router and use usb tethering.
or
on the pixel 4a, i can start the wifi hotspot and connect the router to that, in repeater mode.
both ways work great.
so i am a bit confused about this works and the benefits?
as far as i know, visible does not offer modems of any kind.
in my experience, visible definely looks for abuse, as i ran into a issue, by accident
and lost access to the hotspot for a period of time.
and in the visible forums,
there are examples of users having their account permanently closed without warning.
I am, on an AP1300LTE and E750. One is the ‘old’ $40/month plan, APN “VSBLINTERNET”, the ‘new’ $30/month plan in the AP1300LTE uses APN “internet” and has much lower latency, but more video content is throttled to ~2Mbps.
You’d be amazed at what a bit TTL tweaking and properly reporting IMEI will do as far as speed and not being disconnected by the carrier.
That’s going to heavily depend on tower capacity and load. I vary between 20-70Mbps with the AP1300. The E750 (which I let hop around automatically) varies between 5-50ish. It tends to really like band 13 (700Mhz), but is heavily congested. The ideal setup seems to be aggregating two band 66 (one 20Mhz, one 10Mhz), so on the AP1300 I let it aggregate 5 + 66 or 66 + 66 automatically for peak performance.
Online update for Beryl does not seem to be working? I get 100% in the app / admin panel and then am logged out. The router keeps blinking. I have waited an hour and it doesn’t stop. Cannot reconnect to router as admin (yes, I cleared browsing history). Then I switch it off and restart, update is shown as available again and has not been installed.
I have repeated this a few times before giving up.
Are there any known issues with GL-AR300M16 Shadow on Version: 3.215 from 2022-09-21 05:57:10 because after updating to the latest stable firmware, I am facing many difficulties?
connect/reconnect to wireless networks doesn’t always work
connect/reconnect to wireguard servers doesn’t always work
web admin not always accessible (web server is down)
All mentioned issues get solved with a restart of GL-AR300M16 Shadow
After the upgrade on Brume 1 GL-MV1000, AdGuard home stopped working. Had to uninstall package, install again, and update though the UI to make it work. (DNS was not working at all, that’s how I realized it got stuck)
Using a GL-SF1200, there are error logs of the gl_monitor service trying to detect a VERIZON USB connection, the GL-SF1200 does not have a USB port so the error happens over and over so i disabled the gl_monitor service for the error logs to stop.
