Hi all
i did the personalisation of my gl-ar300-m lite
so i wanted to toggle all sotware that i don’t need as samba etc
how can i create the fimware backyp to make it as master for next routers ?
to avoid maybe connection lose problems so i want a make master flash with what i need i mean
Thank you
Check image builder in our github.
You can zip an image with only the packages you need.
thank you can you give me a link and a guide?
check the readme.
