First impressions about 4.11 firmware on Flint2 (focused on mesh experience)
By disabling the guest network, I’ve had no further issues of any kind. I’ll try enabling it again at some point, but I’m convinced the problem was that the guest network was only active on the 2.4GHz band, meaning the backhaul 5Ghz wasn't active.
In the meantime, I’ve managed to assign a "fixed" IP to the mesh node using an IP reservation. The trick is not to reserve the MAC address shown in the "MESH" section of the graphical interface, but rather the MAC address of the backhaul interface that gets created—which, incidentally, is the same one I used to get the mesh node to restart via a script.
Ok, I send you the requested log and the logread txt.
I admittedly found this thread out of frustration, but appreciate the thorough review. I am out of the country right now (for the next month or so), but saw that the router needed an update. After the update, which went fine remotely, I was poking around and stumbled upon the router/mesh selection screen. I inadvertently misclicked the "mesh" option trying while trying to leave the panel. There was no confirmation and the router instantly went offline. I am currently trying to do recovery while 3k miles away and will likely need to have someone repair or reset the router.
Even more frustratingly, I'm not sure the repair function (hold reset for 4 seconds) while properly revert the settings and reconnect the WAN port. Your post about it being difficult to access the device without reconfiguring the network does not give me hope, but I think highlights a bigger issue with the feature as shipped.
I'm a bit disappointed at the lack of documentation around rollback/repair in general, and am surprised there was not confirmation before the router completely switched.
Sorry for the inconvenience.
We’ll submit your suggestion to add a confirmation prompt before switching to Mesh mode for further evaluation.
Regarding the repair function(hold reset for 4 seconds), pressing and holding the reset button to trigger it will exit Mesh mode and restore normal WAN connectivity. You can ask someone with physical access to the router to help with this.
Thank you for your understanding and support.
Thank you for your help—we’ve received the information and will pass it on to our engineering team for further investigation. We’ll post an update here as soon as we have more information.
Hello and thank you.
I had someone assist with the rollback today and it required minimal repair on my end after the 4-second reset. I do think a confirmation would be a good idea, but the repair feature did work as intended.
Appreciate the reply.
