[ 2.034182] ubi0: attaching mtd9
[ 2.402737] random: nonblocking pool is initialized
[ 2.502405] ubi0: scanning is finished
[ 2.510100] ubi0: attached mtd9 (name “rootfs”, size 115 MiB)
[ 2.510121] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.514829] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.521586] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.528452] ubi0: good PEBs: 920, bad PEBs: 0, corrupted PEBs: 0
[ 2.535221] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[ 2.541467] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1648964974
[ 2.548510] ubi0: available PEBs: 0, total reserved PEBs: 920, PEBs reserved for bad PEB handling: 20
[ 2.557806] ubi0: background thread “ubi_bgt0d” started, PID 116
[ 2.568901] hctosys: unable to open rtc device (rtc0)
[ 2.580028] ALSA device list:
[ 2.580047] No soundcards found.
[ 2.679053] VFS: Mounted root (squashfs filesystem) readonly on device 31:13.
[ 2.681026] Freeing unused kernel memory: 1024K (80c00000 - 80d00000)
[ 4.124857] init: Console is alive
[ 4.124966] init: - watchdog -
[ 5.538282] usbcore: registered new interface driver usbfs
[ 5.538341] usbcore: registered new interface driver hub
[ 5.542730] usbcore: registered new device driver usb
[ 5.549663] Button Hotplug driver version 0.4.1
[ 5.556044] exFAT: Version 1.2.9
[ 5.564047] SCSI subsystem initialized
[ 5.570541] libata version 3.00 loaded.
[ 5.574964] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 5.575437] ehci-platform: EHCI generic platform driver
[ 5.583907] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 5.585996] ohci-platform: OHCI generic platform driver
[ 5.592950] uhci_hcd: USB Universal Host Controller Interface driver
[ 5.600780] msm-usb-ssphy-qmp 78000.ssphy: Initializing QMP phy
[ 5.612428] msm-usb-ssphy-qmp 78000.ssphy: QMP PHY initialization timeout
[ 5.612453] msm-usb-ssphy-qmp 78000.ssphy: USB3_PHY_PCS_STATUS:68686868
[ 5.824633] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.824672] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 5.829927] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x00010010
[ 5.836613] xhci-hcd xhci-hcd.0.auto: irq 189, io mem 0x08a00000
[ 5.845707] hub 1-0:1.0: USB hub found
[ 5.851501] hub 1-0:1.0: 1 port detected
[ 5.855284] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.859131] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 5.864506] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 5.872356] hub 2-0:1.0: USB hub found
[ 5.880331] hub 2-0:1.0: 1 port detected
[ 5.884895] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/soc/gpio-leds/white[0]’ - status (0)
[ 5.884984] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/soc/gpio-leds/blue[0]’ - status (0)
[ 5.885997] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/soc/gpio_keys/wps[0]’ - status (0)
[ 5.886013] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/soc/gpio_keys/reset[0]’ - status (0)
[ 5.886035] gpio-9 (wps): gpiod_set_debounce: missing set() or set_debounce() operations
[ 5.886080] gpio-18 (reset): gpiod_set_debounce: missing set() or set_debounce() operations
[ 5.886269] input: soc:gpio_keys as /devices/platform/soc/soc:gpio_keys/input/input0
[ 5.889597] usbcore: registered new interface driver usb-storage
[ 5.896482] usbcore: registered new interface driver uas
[ 6.127614] init: - preinit -
[ 8.350627] UBIFS (ubi0:3): default file-system created
[ 8.351317] UBIFS (ubi0:3): background thread “ubifs_bgt0_3” started, PID 155
[ 8.411333] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name “rootfs_data”
[ 8.411361] UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 8.418154] UBIFS (ubi0:3): FS size: 71868416 bytes (68 MiB, 566 LEBs), journal size 3555328 bytes (3 MiB, 28 LEBs)
[ 8.428046] UBIFS (ubi0:3): reserved for root: 3394522 bytes (3314 KiB)
[ 8.438284] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID 12869CDD-9D54-4F5A-B797-B7D673842B75, small LPT model
[ 8.446766] mount_root: overlay filesystem has not been fully initialized yet
[ 8.456383] mount_root: switching to jffs2 overlay
[ 8.727234] procd: - early -
[ 8.727281] procd: - watchdog -
[ 9.378388] procd: - ubus -
[ 10.379112] procd: - init -
[ 10.943766] ubi: mtd9 is already attached to ubi0
[ 11.576353] export_store: status -22
[ 11.732023] cfg80211: World regulatory domain updated:
[ 11.732047] cfg80211: DFS Master region: unset
[ 11.736077] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 11.740705] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.744295] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 11.758260] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 11.763226] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.772386] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 11.780342] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 11.790059] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 11.799556] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.807592] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 13.005306] ssdk_switch_device_num_init[998]:INFO:ess-switch dts node number: 1
[ 13.009013] ssdk_dt_get_switch_node[836]:INFO:ess-switch DT exist!
[ 13.015944] ssdk_dt_parse_access_mode[737]:INFO:switch_access_mode: local bus
[ 13.022081] ssdk_dt_parse_access_mode[750]:INFO:switchreg_base_addr: 0x3a000000
[ 13.029201] ssdk_dt_parse_access_mode[751]:INFO:switchreg_size: 0x1000000
[ 13.036499] ssdk_dt_parse_mac_mode[242]:INFO:mac mode = 0x0
[ 13.042914] ssdk_dt_parse_mac_mode[251]:INFO:mac mode1 = 0xff
[ 13.048470] ssdk_dt_parse_mac_mode[260]:INFO:mac mode2 = 0xff
[ 13.054240] ssdk_dt_parse_uniphy[279]:INFO:ess-uniphy DT exist!
[ 13.060035] ssdk_dt_parse_intf_mac[683]:INFO:dp1 MAC 94:83:c4:12:15:cb
[ 13.065861] ssdk_dt_parse_intf_mac[683]:INFO:dp2 MAC 94:83:c4:12:15:cc
[ 13.072439] ssdk_plat_init start
[ 13.154970] ssdk_ppe_clock_init[517]:INFO:ppe and uniphy clock init successfully!
[ 13.158171] ssdk_probe[1912]:INFO:ess_rst doesn’t exist!
[ 13.165388] HPPE initializing…
[ 13.166702] malibu_phy_api_ops_init[2849]:INFO:qca probe malibu phy driver succeeded!
[ 13.177708] regi_init[3359]:INFO:Initializing HPPE!!
[ 13.393992] ssdk_ppe_reset_init[801]:INFO:ppe reset successfully!
[ 13.399617] qca_hppe_tdm_hw_init[737]:INFO:tdm setup num=96
[ 13.403286] qca_hppe_portctrl_hw_init[159]:INFO:Cypress PPE port initializing
[ 13.514390] __adpt_hppe_uniphy_psgmii_mode_set[620]:INFO:uniphy 0 psgmii channel selection
[ 13.729187] ssdk_switch_register[1617]:INFO:Chip version 0x1501
[ 13.732174] qca_link_polling_select[1279]:INFO:link-polling-required node does not exist
[ 13.738407] ssdk_switch_register[1642]:INFO:polling is selected
[ 13.746138] regi_init[3363]:INFO:Initializing HPPE Done!!
[ 13.751059] regi_init[3407]:INFO:qca-ssdk module init succeeded!
[ 13.797060] tun: Universal TUN/TAP device driver, 1.6
[ 13.797084] tun: (C) 1999-2004 Max Krasnyansky [email protected]
[ 13.803914] EDMA ver 1 hw init
[ 13.807396] EDMA HW Reset completed succesfully
[ 13.810227] Num rings - TxDesc:1 (23-23) TxCmpl:1 (23-23)
[ 13.814637] RxDesc:1 (15-15) RxFill:1 (7-7)
[ 13.822744] GMAC3(9ceebd00) Invalid MAC@ - using 02:14:0f:3e:d3:0e
[ 13.825274] GMAC4(9ceee500) Invalid MAC@ - using 6e:ec:23:7f:a3:98
[ 13.831684] GMAC5(9c9e0d00) Invalid MAC@ - using 3e:fc:04:b1:1c:cb
[ 13.837700] **********************************************************
[ 13.842756] * NSS Data Plane driver
[ 13.849298] **********************************************************
[ 13.854676] l2tp_core: L2TP core driver, V2.0
[ 13.859967] l2tp_netlink: L2TP netlink interface
[ 13.944139] qca-nss 39000000.nss: Direct firmware load for qca-nss0.bin failed with error -2
[ 13.944172] qca-nss 39000000.nss: Falling back to user helper
[ 14.388106] nss_driver - fw of size 728260 bytes copied to load addr: 40000000, nss_id : 0
[ 14.389285] Supported Frequencies -
[ 14.395269] 187.2 MHz 748.8 MHz
[ 14.401235] 1.4976 GHz <1>[ 14.402192]
[ 14.404688] node size 2 # items 4
[ 14.406017] memory: 40000000 536870912 (avl 425365504) items 4 active_cores 1
[ 14.409237] addr/size storage words 2 2 # words 4 in DTS, ddr size 1000000
[ 14.416362] 7f688180: NSS core 0 DDR from 40000000 to 41000000
[ 14.423190] 7f688180: meminfo init succeed
[ 14.444660] nat46: module (version 8ff2ae59ec9840a7b8b45f976c51cae80abe0226) loaded.
[ 14.447001] gre: GRE over IPv4 demultiplexor driver
[ 14.452324] ip_gre: GRE over IPv4 tunneling driver
[ 14.465686] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[ 14.469067] node size 2 # items 4
[ 14.469269] Invalid macid 6
[ 14.474325] memory: 40000000 536870912 (avl 425365504) items 4 active_cores 1
[ 14.476933] addr/size storage words 2 2 # words 4 in DTS, ddr size 1000000
[ 14.484229] 7f688180: nss core 0 booted successfully
[ 14.496845] QCA multicast snooping installed successfully
[ 14.500697] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 14.511274] nf_conntrack version 0.5.0 (6159 buckets, 24636 max)
[ 15.484752] Netfilter messages via NETLINK v0.30.
[ 15.486240] ip_set: protocol 6
[ 15.967785] Not a bridge device, or device not found: br-
[ 18.777587] QCA Hy-Fi multicast installation successfully
[ 19.425813] PPP generic driver version 2.4.2
[ 19.614613] NET: Registered protocol family 24
[ 19.895576] :module loaded Build_ID - 06/29/21, 12:07:24 SoC=ipq60xx
[ 20.093797] cannot find nss-macsec0 node
[ 20.093845] cannot find nss-macsec1 node
[ 20.096841] cannot find nss-macsec2 node
[ 20.100689] nss_macsec init success
[ 22.374661] u32 classifier
[ 22.374678] input device check on
[ 22.376246] Actions configured
[ 22.744616] Mirror/redirect action on
[ 27.128420] fuse init (API version 7.23)
[ 27.527194] usbcore: registered new interface driver cdc_acm
[ 27.527219] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 27.532921] usbcore: registered new interface driver cdc_wdm
[ 27.544015] Ebtables v2.0 registered
[ 27.545889] Custom GPIO-based I2C driver version 0.1.1
[ 27.549587] i2c-gpio i2c-gpio.0: using pins 43 (SDA) and 42 (SCL)
[ 27.555535] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 27.561234] usbcore: registered new interface driver ipheth
[ 27.568478] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 27.648863] ctnetlink v0.93: registering with nfnetlink.
[ 27.650891] nf_conntrack_rtsp v0.6.21 loading
[ 27.866838] nf_nat_rtsp v0.6.21 loading
[ 27.870109] PPP MPPE Compression module registered
[ 27.871202] PPTP driver version 0.8.5
[ 27.882453] usbcore: registered new interface driver usbserial
[ 27.882515] usbcore: registered new interface driver usbserial_generic
[ 27.887231] usbserial: USB Serial support registered for generic
[ 27.932394] vmap allocation for size 167936 failed: use vmalloc= to increase size.
[ 27.934478] wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
[ 27.939546] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld [email protected]. All Rights Reserved.
[ 27.965133] xt_time: kernel timezone is -0000
[ 27.966429] usbcore: registered new interface driver cdc_ether
[ 27.970442] usbcore: registered new interface driver cdc_ncm
[ 27.974895] usbcore: registered new interface driver cp210x
[ 27.980051] usbserial: USB Serial support registered for cp210x
[ 27.987461] usbcore: registered new interface driver huawei_cdc_ncm
[ 28.002451] usbcore: registered new interface driver qmi_wwan
[ 28.003911] usbcore: registered new interface driver rndis_host
[ 28.009146] usbcore: registered new interface driver sierra
[ 28.012940] usbserial: USB Serial support registered for Sierra USB modem
[ 28.019673] usbcore: registered new interface driver sierra_net
[ 28.029725] usbcore: registered new interface driver option
[ 28.031173] usbserial: USB Serial support registered for GSM modem (1-port)
[ 32.457791] mem_manager: module license ‘unspecified’ taints kernel.
[ 32.457817] Disabling lock debugging due to kernel taint
[ 32.488510] qdf_dbg_mask value is invalid
[ 32.488530] Using the default module debug levels instead
[ 32.491492] qdf_print_ctrl_register: Allocated print control object 0
[ 32.496940]
[ 32.496940] MINIDUMP VA .bss start=7fb120c0 module=qdf
[ 35.392373] vmap allocation for size 2777088 failed: use vmalloc= to increase size.
[ 35.393576] vmap allocation for size 405504 failed: use vmalloc= to increase size.
[ 35.471520] wlan: [2178:E:CONFIG] cfg_uint_item_handler: 142: allow_mon_vaps_in_sr= - Invalid format (status 16); Using default 0
[ 35.471596] wlan: [2178:E:CONFIG] cfg_uint_item_handler: 171: gScanProbeRepeatTime=50 - Out of range [0, 30]; Using 50
[ 35.482252]
[ 35.482252] MINIDUMP VA .bss start=a0913640 module=umac
[ 36.122315] vmap allocation for size 1220608 failed: use vmalloc= to increase size.
[ 36.122885] vmap allocation for size 217088 failed: use vmalloc= to increase size.
[ 36.172512]
[ 36.172512] MINIDUMP VA .bss start=a2f071c0 module=qca_ol
[ 36.370753] vmap allocation for size 663552 failed: use vmalloc= to increase size.
[ 36.378922] wlan: [2227:I:ANY] =======ol_if_register_wifi3_0==========
[ 36.378922]
[ 36.378960] wlan: [2227:I:ANY] osif_nss_register_module: 90: NSS wifi ops registered for target_type:1 with soc_ops:a09e28a0
[ 36.385845] remoteproc remoteproc1: powering up q6v5-m3
[ 36.398653] remoteproc remoteproc1: Booting fw image IPQ6018/m3_fw.mdt, size 6860
[ 36.402206] Sanity check passed for M3 image
[ 36.463906] remoteproc remoteproc1: remote processor q6v5-m3 is now up
[ 36.464043] : glink SUBSYS_BEFOER_POWERUP reinit done
[ 36.469326] wlan: [2227:I:ANY] ol_ath_ahb_ssr: 192: ol_ath_ahb_ssr: SSR event 2
[ 36.474809] remoteproc remoteproc0: powering up q6v5-wcss
[ 36.482098] remoteproc remoteproc0: Booting fw image IPQ6018/q6_fw.mdt, size 7340
[ 36.487882] Sanity check passed for the image
[ 37.558363] glink_core_link_up glink is up
[ 37.558546] glink_xprt_open_event
[ 37.558630] IPC_RTR: ipc_router_create_log_ctx: IPC Logging disabled
[ 37.558748] Subsystem error monitoring/handling services are up
[ 37.571195] remoteproc remoteproc0: remote processor q6v5-wcss is now up
[ 37.574414] cnss: QMI WLFW service connected, state: 0x1
[ 37.584195] wlan: [2227:I:ANY] ol_ath_ahb_ssr: 192: ol_ath_ahb_ssr: SSR event 3
[ 37.584350] cnss: device_id : 65533 mem mode : [0]
[ 37.585184] cnss: No board_id entry in device tree
[ 37.608675] cnss: BDF location : 0x4abc0000
[ 37.608696] cnss: BDF IPQ6018/bdwlan.bin size 65536
[ 37.611951] cnss: BDF download response , result: 0, err: 0x0
[ 37.616730] cnss: per device BDF location : 0x4abe0000
[ 37.622464] cnss: CALDATA IPQ6018/caldata.bin size 65536 offset 0x20000
[ 37.628665] cnss: BDF download response , result: 0, err: 0x0
[ 37.702421] wlan: [2227:I:ANY] pld_ahb_wlan_enable: 681: cnss_mode: Cold boot calibration
[ 37.931999] wlan: [2227:I:ANY] Coldboot calibration wait started
[ 37.931999]
[ 38.232052] wlan: [2227:I:ANY] Coldboot calibration wait ended
[ 38.232052]
[ 38.232748] wlan: [2227:I:ANY] ol_ath_do_cold_boot_calibration: 505: Coldboot calib successful: radio_id 0x65533
[ 38.239301] wlan: [2227:I:ANY] init_ath_pci_3_0: 151: 6ath_ol_pci_wifi3.0: (Atheros/multi-bss)
[ 38.248710]
[ 38.248710] MINIDUMP VA .bss start=a09e2b80 module=wifi_3_0
[ 38.263347] wlan: [2244:I:ANY] ol_ath_ahb_ssr: 192: ol_ath_ahb_ssr: SSR event 0
[ 38.288728] remoteproc remoteproc0: stopped remote processor q6v5-wcss
[ 38.288874] glink_core_link_down glink is down
[ 38.294479] : glink SUBSYS_AFTER_SHUTDOWN cleanup done
[ 38.298580] wlan: [2244:I:ANY] ol_ath_ahb_ssr: 192: ol_ath_ahb_ssr: SSR event 1
[ 38.304185] remoteproc remoteproc1: stopped remote processor q6v5-m3
[ 38.324097] cnss: QMI WLFW service disconnected, state: 0x7
[ 38.363995] glink_xprt_close_event
[ 38.895499] vmap allocation for size 1220608 failed: use vmalloc= to increase size.
[ 38.896063] vmap allocation for size 217088 failed: use vmalloc= to increase size.
[ 38.937795]
[ 38.937795] MINIDUMP VA .bss start=a1b881c0 module=qca_ol
[ 39.076604] vmap allocation for size 663552 failed: use vmalloc= to increase size.
[ 39.083885] wlan: [2254:I:ANY] =======ol_if_register_wifi3_0==========
[ 39.083885]
[ 39.083932] wlan: [2254:I:ANY] osif_nss_register_module: 90: NSS wifi ops registered for target_type:1 with soc_ops:a09e28a0
[ 39.091705] remoteproc remoteproc1: powering up q6v5-m3
[ 39.103209] remoteproc remoteproc1: Booting fw image IPQ6018/m3_fw.mdt, size 6860
[ 39.108069] Sanity check passed for M3 image
[ 39.116346] remoteproc remoteproc1: remote processor q6v5-m3 is now up
[ 39.120120] : glink SUBSYS_BEFOER_POWERUP reinit done
[ 39.126392] wlan: [2254:I:ANY] ol_ath_ahb_ssr: 192: ol_ath_ahb_ssr: SSR event 2
[ 39.131849] remoteproc remoteproc0: powering up q6v5-wcss
[ 39.139122] remoteproc remoteproc0: Booting fw image IPQ6018/q6_fw.mdt, size 7340
[ 39.144935] Sanity check passed for the image
[ 39.451609] glink_core_link_up glink is up
[ 39.451769] glink_xprt_open_event
[ 39.451873] IPC_RTR: ipc_router_create_log_ctx: IPC Logging disabled
[ 39.458023] Subsystem error monitoring/handling services are up
[ 39.464432] remoteproc remoteproc0: remote processor q6v5-wcss is now up
[ 39.465483] cnss: QMI WLFW service connected, state: 0x1
[ 39.465672] cnss: device_id : 65533 mem mode : [0]
[ 39.466353] cnss: No board_id entry in device tree
[ 39.466551] cnss: BDF location : 0x4abc0000
[ 39.466554] cnss: BDF IPQ6018/bdwlan.bin size 65536
[ 39.466812] cnss: BDF download response , result: 0, err: 0x0
[ 39.466954] cnss: per device BDF location : 0x4abe0000
[ 39.466986] cnss: CALDATA IPQ6018/caldata.bin size 65536 offset 0x20000
[ 39.468115] cnss: BDF download response , result: 0, err: 0x0
[ 39.518115] wlan: [2254:I:ANY] ol_ath_ahb_ssr: 192: ol_ath_ahb_ssr: SSR event 3
[ 39.524184] wlan: [2254:I:ANY] pld_ahb_wlan_enable: 689: cnss_mode: Mission mode
[ 39.536738] wlan: [2254:I:ANY] qca_napi_create: 369: qca_napi_create: napi instance 0 created on pipe 4
[ 39.538873] wlan: [2254:I:ANY] __ol_ath_attach: 3520: Allocated soc 9a200500
[ 39.548094] wlan: [2254:E:CONFIG] cfg_uint_item_handler: 171: dp_int_timer_threshold_tx=1000 - Out of range [8, 100]; Using 1000
[ 39.555271] wlan: [2254:E:CONFIG] cfg_uint_item_handler: 171: dp_nss_comp_ring_size=4096 - Out of range [8192, 49152]; Using 8192
[ 39.566962] wlan: [2254:I:ANY] osif_nss_wifi_soc_setup: 189: nss register id -1 nss config 0 Target Type 19
[ 39.578323] wlan: [2254:I:ANY] __ol_ath_attach: 3746: dev name soc0
[ 39.588372] wlan: [2254:I:ANY] ol_ath_soc_attach: 7064: WMI attached. wmi_handle 9aa1a400
[ 39.594291] wlan: [2254:I:ANY] htc_wmi_init: 6358: htc_wmi_init() HT Create . 996c6000
[ 39.602518] wlan: [2254:I:ANY] htc_wmi_init: 6365: htc_wmi_init() Skipping BMI Done.
[ 39.610427] wlan: [2254:I:ANY] htc_wmi_init: 6422: [htc_wmi_init:6422] host_enable 0 nss_nwifi_offload 0
[ 39.621958] wlan: [2254:I:ANY] ol_target_init_complete: 6540: CDP soc attach success
[ 39.627880] wlan: [2254:I:ANY] ol_target_init_complete: 6547: Soc attach success NSS config 0
[ 39.635651] wlan: [2254:I:ANY] htc_set_async_ep: 428: htc_set_async_ep: htc_handle 996c6000, ep 2, value 1
[ 39.644072] wlan: [2254:I:ANY] htc_set_async_ep: 428: htc_set_async_ep: htc_handle 996c6000, ep 3, value 1
[ 39.653690] wlan: [2254:I:ANY] 1 Target failed service 0x106 connect request (status:1)
[ 39.653690]
[ 39.663294] wlan: [2254:E:WMI] Failed to connect to WMI CONTROL service status:27
[ 39.663294]
[ 39.673692] wlan: [114:I:TIF] init_deinit_populate_hw_mode_capability: 361: Preferred mode is not set, use mode id 1
[ 39.673692]
[ 39.681818] wlan: [114:I:TIF] HE_CAP Info = 1a08010d
[ 39.693851] wlan: [114:I:TIF] Num HW modes = 2
[ 39.698880] wlan: [114:I:TIF] Num PHY = 2
[ 39.703129] wlan: [114:I:TIF] Preferred HW Mode = 1 Num Radios = 2
[ 39.707222] wlan: [114:I:TIF] init_deinit_add_11ax_modes: 1440: Adding 11ax regulatory modes,
[ 39.713296] wlan: [114:I:TIF] init_deinit_add_11ax_modes: 1444: phy_id = 0 wireless modes = 391f9001
[ 39.721933] wlan: [114:I:TIF] init_deinit_add_11ax_modes: 1440: Adding 11ax regulatory modes,
[ 39.731097] wlan: [114:I:TIF] init_deinit_add_11ax_modes: 1444: phy_id = 1 wireless modes = 680680c
[ 39.739603] wlan: [114:I:TIF] init_deinit_add_11ax_modes: 1467: hw_mode_id = 1 phy_id = 0 wireless modes = 0
[ 39.748954] wlan: [114:I:TIF] init_deinit_add_11ax_modes: 1467: hw_mode_id = 1 phy_id = 1 wireless modes = 0
[ 39.758621] wlan: [114:I:TIF] init_deinit_add_11ax_modes: 1467: hw_mode_id = 5 phy_id = 0 wireless modes = 0
[ 39.768463] wlan: [114:I:TIF] init_deinit_add_11ax_modes: 1467: hw_mode_id = 5 phy_id = 1 wireless modes = 0
[ 39.778490] wlan: [114:I:dfs] WLAN_DEBUG_DFS_ALWAYS : wlan_dfs_pdev_obj_create_notification: 389: dfs_offload 1
[ 39.788046] wlan: [114:I:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: 1579: dfs->dfs_psoc_idx: 0
[ 39.797855] wlan: [114:I:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: 1585: dfs_soc_obj->num_dfs_privs: 1
[ 39.807796] wlan: [114:I:dfs] WLAN_DEBUG_DFS_ALWAYS : wlan_dfs_pdev_obj_create_notification: 361: Do not allocate DFS object for 2G, pdev_id = 1
[ 39.868776] wlan: [114:I:TIF] init_deinit_update_pdev_tgt_info: 1082: CDP PDEV ATTACH success
[ 39.883421] wlan: [114:I:TIF] init_deinit_update_pdev_tgt_info: 1082: CDP PDEV ATTACH success
[ 39.983922] wlan: [114:I:ANY] copy_fw_abi_version_tlv: 6649: copy_fw_abi_version_tlv: INIT_CMD version: 1, 0, 0x5f414351, 0x4c4d, 0x0, 0x0
[ 40.153450] wlan: [114:I:ANY] dp_peer_map_attach_wifi3: 8664: dp_peer_map_attach_wifi3 max_peers 1111, max_ast_index: 4112
[ 40.153450]
[ 40.153729] wlan: [114:I:ANY] ready_extract_init_status_tlv: 8473: ready_extract_init_status_tlv:0
[ 40.164893] wlan: [2254:I:ANY] ol_ath_connect_htc: 1236: WMI is ready
[ 40.173935] wlan: [2254:E:WMI] wmi_unified_register_event_handler: Event id 141 is unavailable
[ 40.180319] wlan: [2254:E:WMI] wmi_unified_register_event_handler: Event id 137 is unavailable
[ 40.188836] wlan: [2254:I:ANY] ol_ath_soc_attach: 7151: connect HTC
[ 40.197409] wlan: [2254:I:ANY] ol_ath_soc_attach: 7152: bypasswmi : 0
[ 40.203567] wlan: [2254:E:WMI] event handler already registered 0x27001
[ 40.210171] wlan: [2254:E:WMI] event handler already registered 0x27002
[ 40.216597] wlan: [2254:E:WMI] event handler already registered 0x27003
[ 40.223198] wlan: [2254:E:WMI] wmi_unified_register_event_handler: Event id 38 is unavailable
[ 40.229821] wlan: [2254:E:WMI] wmi_unified_register_event_handler: Event id 138 is unavailable
[ 40.238477] wlan: [2254:E:WMI] wmi_unified_register_event_handler: Event id 139 is unavailable
[ 40.246990] wlan: [2254:E:WMI] wmi_unified_register_event_handler: Event id 55 is unavailable
[ 40.255579] wlan: [2254:E:WMI] wmi_unified_register_event_handler: Event id 49 is unavailable
[ 40.264177] wlan: [2254:E:WMI] wmi_unified_register_event_handler: Event id 25 is unavailable
[ 40.272667] wlan: [2254:I:ANY] ol_ath_soc_attach: 7232: ol_ath_soc_attach() UMAC attach .
[ 40.281248] wlan: [2254:I:ANY] __ol_ath_attach: 3862: pdev_netdev name wifi0
[ 40.289353] wlan: [2254:I:ANY] __ol_ath_attach: 3908: Skip txrx_pdev_attach_target
[ 40.296549] wlan: [2254:I:ANY] __ol_ath_attach: 3933: BURSTING enabled by default
[ 40.303996] wlan: [2254:I:ANY] ol_ath_pdev_attach: 8529: interface_id 0
[ 40.311475] wlan: [2254:I:TIF] ol_ath_pdev_regdmn_init: 7393: phy id = 0 Modes supported
[ 40.317906] wlan: [2254:I:TIF] ol_ath_pdev_regdmn_init: 7400: 11b = 0 11g = 0 11a = 1 11n = 1 11ac = 1 11ax = 1
[ 40.326242] wlan: [2254:I:TIF] ol_ath_pdev_regdmn_init: 7409: Reg cap - phy_id = 0 supp_bnd = 2, modes = 391f9001, lo_2g = 0, hi_2g = 0 lo_g5 = 4910, hi_5g = 6100
[ 40.336490] wlan: [2254:I:ANY] ol_ath_update_wireless_modes: 1351: wireless_modes = 391f9001 before update
[ 40.350803] wlan: [2254:I:ANY] ol_ath_update_wireless_modes: 1366: Wireless_modes = 391f9001 after update
[ 40.360526] wlan: [2254:I:ANY] ol_ath_update_ext_caps: 1916: 11ax 5G supported case
[ 40.370293] wlan: [2254:I:ANY] ol_resmgr_create: 223: OL Resmgr Init-ed
[ 40.377692] wlan: [2254:I:ANY] ieee80211_cbs_init
[ 40.384211] wlan: [2254:I:ANY] CBS Inited
[ 40.384211]
[ 40.389089] wlan: [2254:I:ANY] acfg_attach: 3473: acfg_attach: 3473: Netlink socket created:9a01e400
[ 40.394559] wlan: [2254:I:ANY] ol_if_eeprom_attach: 1459: rate power table override is only supported for AR98XX
[ 40.403835] wlan: [2254:I:ANY] ol_ath_stats_attach: 2134: periodic_chan_stats: 1
[ 40.414698] wlan: [2254:I:ANY] wlan_scan_update_channel_list: 1090: num_chan: 25
[ 40.421386] wlan: [0:I:ANY] ol_ath_pdev_attach: 8893: Set global_ic[1], ptr:a091396c
[ 40.428753] wlan: [0:I:ANY] dp_lag_soc_enable: 91: pdev(996eba04) Enabling DBDC Repeater 1
[ 40.436478] wlan: [0:I:ANY] dp_lag_pdev_set_primary_radio: 44: pdev(996eba04) is_primary 1
[ 40.444552] wlan: [2254:I:ANY] ol_ath_pdev_attach: 9022: Pdev = 0 Number of peers = 529
[ 40.453109] wlan: [0:I:ANY] ol_ath_twt_enable_complete_event_handler: 14044: twt enabled.
[ 40.453109]
[ 40.453689] wlan: [2254:E:CFR] tgt_cfr_init_pdev: 107: Error occurred with exit code 11
[ 40.453689]
[ 40.453694] wlan: [2254:E:CFR] wlan_cfr_pdev_open: 105: tgt_cfr_init_pdev failed with 11
[ 40.453694]
[ 40.453723] wlan: [2254:I:ANY] ol_ath_ucfg_set_rx_pkt_protocol_tagging: 2099: Set RX packet type TAG, opcode : 0, pkt_type : 18, metadata : 0xca0,pdev_id = 0, REO dest ring = 5
[ 40.453723]
[ 40.453749] wlan: [2254:I:ANY] ol_ath_pri20_cfg_blockchanlist_parse: 560: cfg block channel list is empty
[ 40.453756] wlan: [2254:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: 3451: pdev_idx = 0 tx_desc_limit = 32768
[ 40.453773] wlan: [2254:I:ANY] osif_wrap_attach: 239: osif wrap attached
[ 40.453773]
[ 40.453778] wlan: [2254:I:ANY] osif_wrap_devt_init: 201: osif wrap dev table init done
[ 40.453778]
[ 40.453784] wlan: [2254:I:ANY] osif_wrap_attach: 247: Wrap Attached: Wrap_com =9d8fa600 ic->ic_wrap_com=9d8fa600 &wrap_com->wc_devt=9d8fa600
[ 40.453784]
[ 40.453806] wlan: [2254:I:ANY] __ol_ath_attach: 4114: needed_headroom reservation 60
[ 40.453855] wlan: [2254:I:ANY] wlan_cfg80211_init: 10915: Number of 5G channels: 25
[ 40.454122] wlan: [2254:I:ANY] ieee80211_cfg80211_radio_attach: 11009: ic: 0x987e0500, wdev: 0x987efc9c, wiphy: 0x9a199960, netdev: 0x987e0000
[ 40.454781] wlan: [2254:I:ANY] __ol_ath_attach: 3862: pdev_netdev name wifi1
[ 40.454798] wlan: [2254:I:ANY] __ol_ath_attach: 3908: Skip txrx_pdev_attach_target
[ 40.454803] wlan: [2254:I:ANY] __ol_ath_attach: 3933: BURSTING enabled by default
[ 40.454856] wlan: [2254:I:ANY] ol_ath_pdev_attach: 8529: interface_id 1
[ 40.454868] wlan: [2254:I:TIF] ol_ath_pdev_regdmn_init: 7393: phy id = 1 Modes supported
[ 40.454874] wlan: [2254:I:TIF] ol_ath_pdev_regdmn_init: 7400: 11b = 1 11g = 1 11a = 0 11n = 1 11ac = 1 11ax = 1
[ 40.454882] wlan: [2254:I:TIF] ol_ath_pdev_regdmn_init: 7409: Reg cap - phy_id = 1 supp_bnd = 1, modes = 680680c, lo_2g = 2312, hi_2g = 2732 lo_g5 = 0, hi_5g = 0
[ 40.454887] wlan: [2254:I:ANY] ol_ath_update_wireless_modes: 1351: wireless_modes = 680680c before update
[ 40.454892] wlan: [2254:I:ANY] ol_ath_update_wireless_modes: 1366: Wireless_modes = 680680c after update
[ 40.454897] wlan: [2254:I:ANY] ol_ath_update_ext_caps: 1924: 11ax 2G supported case
[ 40.455000] wlan: [2254:I:ANY] ol_resmgr_create: 223: OL Resmgr Init-ed
[ 40.455076] wlan: [2254:I:ANY] ieee80211_cbs_init
[ 40.455079] wlan: [2254:I:ANY] CBS Inited
[ 40.455079]
[ 40.455091] wlan: [2254:I:ANY] acfg_attach: 3448: Offload using existing sock 9a01e400
[ 40.455101] wlan: [2254:I:ANY] ol_if_eeprom_attach: 1459: rate power table override is only supported for AR98XX
[ 40.455106] wlan: [2254:I:ANY] ol_ath_stats_attach: 2134: periodic_chan_stats: 1
[ 40.455359] wlan: [2254:I:ANY] wlan_scan_update_channel_list: 1090: num_chan: 11
[ 40.455382] wlan: [0:I:ANY] ol_ath_pdev_attach: 8893: Set global_ic[2], ptr:a091396c
[ 40.455389] wlan: [0:I:ANY] dp_lag_soc_enable: 91: pdev(996eb704) Enabling DBDC Repeater 1
[ 40.455396] wlan: [0:I:ANY] dp_lag_pdev_set_primary_radio: 44: pdev(996eb704) is_primary 0
[ 40.455404] wlan: [2254:I:ANY] ol_ath_pdev_attach: 9022: Pdev = 1 Number of peers = 529
[ 40.456216] wlan: [2254:E:CFR] tgt_cfr_init_pdev: 107: Error occurred with exit code 11
[ 40.456216]
[ 40.456221] wlan: [2254:E:CFR] wlan_cfr_pdev_open: 105: tgt_cfr_init_pdev failed with 11
[ 40.456221]
[ 40.456245] wlan: [2254:I:ANY] ol_ath_ucfg_set_rx_pkt_protocol_tagging: 2099: Set RX packet type TAG, opcode : 0, pkt_type : 18, metadata : 0xca0,pdev_id = 1, REO dest ring = 5
[ 40.456245]
[ 40.456269] wlan: [2254:I:ANY] ol_ath_pri20_cfg_blockchanlist_parse: 560: cfg block channel list is empty
[ 40.456276] wlan: [2254:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: 3451: pdev_idx = 1 tx_desc_limit = 32768
[ 40.456291] wlan: [2254:I:ANY] osif_wrap_attach: 239: osif wrap attached
[ 40.456291]
[ 40.456295] wlan: [2254:I:ANY] osif_wrap_devt_init: 201: osif wrap dev table init done
[ 40.456295]
[ 40.456302] wlan: [2254:I:ANY] osif_wrap_attach: 247: Wrap Attached: Wrap_com =9db28a00 ic->ic_wrap_com=9db28a00 &wrap_com->wc_devt=9db28a00
[ 40.456302]
[ 40.456319] wlan: [2254:I:ANY] __ol_ath_attach: 4114: needed_headroom reservation 60
[ 40.456336] wlan: [2254:I:ANY] wlan_cfg80211_init: 10903: Number of 2G channels: 11
[ 40.456497] wlan: [2254:I:ANY] ieee80211_cfg80211_radio_attach: 11009: ic: 0x98020500, wdev: 0x9802fc9c, wiphy: 0x9a19b960, netdev: 0x98020000
[ 40.457023] wlan: [2254:I:Dynamic Mode Change] ol_ath_check_and_reconfig_hw_mode: 3420: Running with HW mode = 1
[ 40.457355] wlan: [2254:E:QLD] qld_register: 108: Handle or address is NULL
[ 40.457369] wlan: [2254:I:ANY] wlan_pdev_operation: 744: num_radios=1, wifi_radios[0].sc = 987e0500_radio_type = 2
[ 40.457376] wlan: [2254:I:ANY] wlan_pdev_operation: 744: num_radios=2, wifi_radios[1].sc = 98020500_radio_type = 2
[ 40.457402] wlan: [2254:I:ANY] init_ath_pci_3_0: 151: 6ath_ol_pci_wifi3.0: (Atheros/multi-bss)
[ 40.910585]
