hi all
after update to beta 4.8.4 beta i cant have access directly to web page of my flint1 into mullvad vpn servers
maybe bug because this issue there isnt to my flint2 that work very well
possible t o verify?
thx in advance
hi all
thx in advance
Could you please clarify what you mean by “unable to access Mullvad VPN servers” and provide some screenshots so we can better understand the issue you’re experiencing?
If you’re referring to Mullvad under Admin Panel → VPN → WireGuard Client, we tested it locally on the AX1800 (v4.8.4 beta), and it appears to be working normally.
This is a network issue preventing the router from retrieving the configuration file from the Mullvad servers.
Please try the following:
thx for answer
tried as a wrote but same problem
Could you please follow the guide and share your device with us via GoodCloud so we can check this issue remotely?
