Flint 2, 4.11.0 stable, vpn issues and network restarts
I continue to stumble with 4.11.0 stable. Any type of changes in the UI causes a network restart. This was initially experienced in another topic wrt adding/removed reserved IP's ( Flint 2 on V4.11.0 network disconnect/reconnect - #7 by psyenz101 ) . And I thought I understood why that happened after the explanation, but now see the same behavior when enabling or disabling additional VPN tunnels - anytime an existing VPN tunnel is either enabled or disabled, the network apparently performs a restart since internet access is lost.
Not to mention the VPN's no longer act as a fallback / waterfall so if priority 1 goes down, priority 2 does not take over.
Any idea if this will be fixed in an upcoming release; perhaps even in an op25 version? I tired the op-25 version and had newtwork instability issues having to reboot after a few hours - this behavior has been described by others in at least one other thread (OP25 Firmware for Flint 2 & Beryl AX is out - #271 by clweb67)
Thanks for the details.
The interruption when enabling a VPN tunnel can occur because its Kill Switch is enabled by default. Traffic matching that tunnel’s policy is blocked while it shows Connecting, preventing it from going through the WAN before the VPN is ready.
When disabling a VPN tunnel, the router needs to clear existing connection states so traffic can follow the updated routing rules. A brief interruption during this transition is therefore expected.
For the fallback/waterfall setup you described, this is now handled by multiple VPN profiles within a single tunnel. Separate tunnels operate independently, and their priority determines which policy matches the traffic. We recommend placing your primary and backup profiles in the same tunnel, with the primary first, so the tunnel can automatically try the backup if the active profile fails.
The VPN Dashboard guide explains this behavior and the setup in more detail.
