pinus
October 23, 2024, 10:03am
I've seen this morning an update for my Flint. If I understand correctly, this update was only meant to fix the GUI issue with wifi, which I already fixed temporarily following that topic .
After the update, the 2.4 GHz network was down.
I have 3 wireless network in that frequency:
Management - radio1.network1
Guest - radio1.network2
IoT - radio1.network3
The first two are the default ones from gl-iNET, I didn't change any settings.
The third one was added manually in Luci.
The weird thing is that if I disable the first 2.4 AP (management - radio1.network1), all of sudden the two other networks appear and work fine.
Any suggestions ?
Many thanks
bruce
October 24, 2024, 3:35am
2
May I know if the radio1 disabled, does the radio2/3 not work?
pinus
October 24, 2024, 7:30am
4
I don't have radio 2/3.
Here are the names showing in Luci:
5 GHz management : wlan1
5 GHz guest : wlan1-1
2.4 GHz management : radio1.network1
2.4 GHz guest : radio1.network2
2.4 GHz IoT : radio1.network3
Both 5 GHz are fine.
For 2.4 GHz, if Management - radio1.network1 is activated, none of the 2.4 GHz are OK.
If I deactivate radio1.network1, the other 2.4 GHz are OK.
bruce
October 28, 2024, 12:13pm
5
This config group 'radio1.network1' probably has issue.
Please check the /etc/config/wireless. Have you configured it before?
pinus
October 28, 2024, 4:50pm
6
I haven't done any manual change in the wireless config file.
I have only applied these commands from the thread mentioned in the first post:
uci set wireless.default_radio0.ifname='wlan1'
uci set wireless.default_radio1.ifname='wlan0'
uci set wireless.guest5g.ifname='wlan1-1'
uci set wireless.guest2g.ifname='wlan0-1'
uci commit wireless
And here is my /etc/config/wireless file:
config wifi-device 'radio0'
option type 'mac80211'
option path 'platform/soc/c000000.wifi'
option band '5g'
option htmode 'HE80'
option country 'US'
option disabled '0'
option legacy_rates '0'
option hwmode '11a'
option channel '44'
option channels '36,40,44,48'
option random_bssid '1'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option wds '1'
option isolate '0'
option hidden '0'
option key ''
option ssid '龴ↀ◡ↀ龴'
option encryption 'sae'
option ifname 'wlan1'
option macaddr '2E:74:6F:4C:72:13'
option disabled '0'
config wifi-device 'radio1'
option path 'platform/soc/c000000.wifi+1'
option band '2g'
option country 'US'
option htmode 'HE40'
option hwmode '11g'
option cell_density '0'
option channel 'auto'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'ap'
option wds '1'
option isolate '0'
option ssid '龴ↀ◡ↀ龴'
option hidden '0'
option key ''
option ifname 'wlan0'
option macaddr '86:39:18:30:7C:CA'
option disabled '1'
config wifi-iface 'guest5g'
option network 'guest'
option mode 'ap'
option guest '1'
option wds '1'
option isolate '1'
option disabled '0'
option encryption 'sae-mixed'
option ssid 'mathieu'
option hidden '0'
option key ''
option ifname 'wlan1-1'
option macaddr 'C6:34:9A:D7:C1:21'
config wifi-iface 'guest2g'
option mode 'ap'
option guest '1'
option wds '1'
option isolate '1'
option hidden '0'
option key ''
option ifname 'wlan0-1'
option macaddr '66:B8:A1:7C:4F:B3'
config wifi-iface 'wifinet4'
option network 'IoT'
option wds '1'
option ssid 'IoT'
option mode 'ap'
option key ''
option macaddr '0E:F8:BB:58:47:38'
Thanks for your help,
bruce
October 29, 2024, 11:36am
7
There are 2 'ifname's same, try configuring the second one to 'wlan0-2'
pinus
October 29, 2024, 12:06pm
8
That was it, thanks for the solution !
system
Closed
April 28, 2025, 1:11am
10
