Hi i have this firmware on my router and it works very good openwrt-mt6000-4.7.0-0923-1727090772 but when install the latest firmware openwrt-mt6000-4.7.0-1205-1733363900
the router hang all the time and i must restart it all the time so i need to reinstall the beta of 4.7.0
and it work good again, what is the problem?
What firmware version is Flint 2 Now?
If it in an older version, please send me the configuration:
Luci -> System -> Backup and Flash firmware -> Download backup -> Generate archive
If it is not the latest version openwrt-mt6000-4.7.0-0923-1727090772, please try to flash/upgrade the firmware on the uboot mode.
Note the uboot flash the firmware will cause to clear the configuration.
So your operation is re-upgraded the firmware v4.7.0 on the GL GUI one more time, and it work well now?
Hi, I recently purchased the Flint 2 upgraded it to the latest 4.7.0 OP24 firmware. I see that it uses the OpenWRT rc2 instead of the newer RC5, is there any ETA when the RC5 will be availbale?
I ask this because i encounter some issues with this firmware.
In the Gl.iNet gui it says under LAN the DHCP range is 192.168.0.100 to 192.168.0.254 while the LAN interface in Luci says it's 192.168.0.100 to 192.168.150
I installed wireguard server via the Gl.iNet gui, in Luci it says under the WGserver interface:
" Unsupported protocol type.
[Install protocol extensions...]"
In Luci there is an updated package "wireguard-tools" available. but upgrading it gives an error
The GL firmware will never be up-to-date. Sometimes more up-to-date, sometimes less.
If you would like to work with the newest code, you need to switch to plain OpenWrt.
Please configure WireGuard only via the GL GUI. It's not supported to adjust settings by luci since the WireGuard integration is customized for the GL router.
