Flint 2 and probably other models as well
Hello wonderful people,
I encountered a bug with NordVPN (WireGuard / NordLynx) — what a surprise, right? :sweat_smile:
If you go to a country and try to add all available links (for example, Spain –> Madrid –> 50 servers, or whatever number), and then do the same for 2 - 3 countries, the list becomes completely empty. It won’t add anything and just stays blank with no option to connect.
I went in circles deleting the VPN completely even factory-resetting my router to try to resolve this issue.
However, I found a better workaround if this hasn’t been permanently fixed:
If you only add 2–3 links from each country, and keep the total number of entries under about 20, everything works perfectly. It can then be used without needing to pull .conf files from your Linux machine.
I hope this helps as a temporary solution. Please accept my apologies if you’ve already resolved this issue elsewhere and I simply couldn’t find the topic.
All the best.
Ignore my post, replied to wrong post.
May I know what firmware version your Flint2 is?
Please share us some screenshots of the issue.
I did not reproduce this issue in the latest firmware version, I first added Madrid 20, and then added Australia 20 + Portugal 20, a total of 60, and the list was normal; I added more servers to the list reaching 180, which was also normal.
Hello Bruce,
I just updated to
| Firmware Version | OpenWrt 21.02-SNAPSHOT / LuCI openwrt-21.02 branch git-22.335.71649-0ecaf74
I think you`re absolutely right.
I tried few times and it seems fine, so I guess that was issue with the previous version.
Thanks :slight_smile:
