Flint 2 crashing
My Flint 2 starting crashing roughly every 20m today, I've had no issues for the last ~4 month since I first set it up.
The CPU load and ram use seem fine, the only detail I can tell is that the LED starts flashing blue when it crashes, I've reset the router, reinstall firmware 4.7, then ubooted, then reinstalled with op24, still crashes.
logread4.tar (115.5 KB)
From the sys log, it seems that the device does not crash, and there is no crash log file.
The LAN wired port is connected normally, and the wireless client WiFi connection is also normal.
Can the clients access the router GL GUI when the issue occurs, or can it ping the router IP? (like if the router IP is 192.168.8.1, ping 192.168.8.1)
The blue flash may be as there is no Internet access of router, please check the WAN port status.
I've discovered that the router is still accessible over wifi, and the issue only occurred when the LAN ports where connected. After plugging and unplugging the LAN ports the issue seems to be caused by a powerline, as the router has been running fine for 24h since it was unplugged.
So the router does not crash, this is probably other reasons cause the router to have no Internet access.
Please export the syslog in time after the issue occurs, and inform us about the time of the issue.
