If I set my DNS as manual (pihole on local subnet) when I set up a wireguard client using the client based VPN policy it can only use the DNS servers specified in the manual set up rather than using the VPN servers specified in the VPN config? (this is the behaviour I'm seeing).
I have also tried with Allow Custom DNS to Override VPN DNS on and off and makes no difference.
I have tested with "Allow Custom DNS to Override VPN DNS" turned off and on, and it is the same outcome.
Current FW is 4.7.5-op24, the problem was still there previously on 4.6.6-op24 also.
Client/s receive DNS server settings via DHCP, and the DHCP server settings are below.
Out of interest, where are you getting the confirmation that your devices are using pi-hole DNS instead of the VPN ascribed ones? Are you using a browser or a command line utility? Either way, have you cleared the DNS cache in the browser (i.e. Edge Browser: edge://net-internals/#dns) and/or flushed the DNS if you're using windows (not sure about Linux/other OS) with 'ipconfig /flushdns' ?
Using Windows, I have flushed DNS but have not specifically cleared the browser DNS cache (chrome: chrome://net-internals/#dns). Didn't actually know that was possible in Chrome, thanks for the tip!
Will test but lookup requests to unbound on the pihole can be seen as the browser asks for them, so not so sure clearing the browser DNS cache will have an impact as I can see the browser asking the pihole (which then returns it from its cache or a fresh lookup from root servers).
