Flint 2 doesn’t cross wifi password setup
I installed one of the snapshot firmware and I lost the connection to the router. Tried to reset and setup the router again, but it stuck on wifi password setup. Tried the gl-inet app. Tried different browsers different computers and reset all data of all browsers. I can’t login. Tried through ssh it says connection refused.
I also tried Uboot using 192.168.1.1 and it doesn't load the page.
had the same problem, then I tried another lan Ports on the flint 2 then I get the UBOOT page
Please re-install the latest snapshot or beta version, please do not install the 2025-06-11 snapshot firmware.
The problem I can't access. What is the login password for the Snapshot released on 08/06/2025? I can't access the router page
I reset the router tried every default gl-inet passwords abd it didn't work. I can't complete the initial setup as the page stuck on setting the wifi password and it doesn't go forward.
I had this issue at the same time as the unable to login to the Flint 2.
Had to use Uboot to install a known working version.
Please upgrade the firmware to latest snapshot or beta, today is 4.8.0 Beta 2025-06-14 or 4.8.0 Snapshot 2025-06-20
