Hello, Today I would like to mention there is a bug currently on beta 4.7.0
WGCLIENT - Unsupported protocol type.
(how it affects me)
I use a vpn with my own fine tweaked dns called control D with a vpn azirevpn and currently I am not able to use my dns with my vpn like I did on none beta build, My vpn will not work with my control dns enabled, I have done some investigation and it seems that (WGCLIENT) is missing in Luci
I have then attempted to install & update which did not fix this bug
I am by no means an amateur with these sort of things so I know for certain the issue is WGclient protocol is not being supported.
My dns works fine I have encountered issues that I have not had on my none beta version.
I am using azirevpn and basically it works fine, but when I enable my encrypted dns over tls the vpn will stop working, funny thing is I had to enable ipv6 nat6 with the dns over tls enabled otherwise I get (RTNETLINK answers: Permission denied) when i enable ipv6 nat6 it fixes it but still cannot connect to the vpn, I have tried it on automatic and also manually.
I have Allow Custom DNS to Override VPN DNS setting enabled by default
vpn connection logs
(Sun Oct 27 13:29:54 2024 daemon.notice netifd: Network device 'wgclient' link is down
Sun Oct 27 13:29:54 2024 user.notice nat6: Firewall config="wgclient" zone="wgclient" zone_masq6="1".
Sun Oct 27 13:29:54 2024 daemon.notice netifd: Interface 'wgclient' is now down
Sun Oct 27 13:29:56 2024 user.notice nat6: Firewall config="wgclient" zone="wgclient" zone_masq6="1".
Sun Oct 27 13:30:17 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Oct 27 13:30:17 2024 daemon.notice netifd: wgclient (30269): RTNETLINK answers: Permission denied
Sun Oct 27 13:30:17 2024 daemon.notice netifd: Network device 'wgclient' link is up
Sun Oct 27 13:30:17 2024 daemon.notice netifd: Interface 'wgclient' is now up
Sun Oct 27 13:30:17 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Hideme IPVanish Mullvad NordVPN PIA Surfshark FromApp group_3360 group_6327 group_5646 group_8612 group_1579 group_898 group_3864 group_6831 peer_4695 peer_7661 peer_628 peer_9947 peer_2913 peer_5880 peer_5198 peer_8165 peer_1132 peer_450 peer_3417 peer_6384 peer_5702 peer_8669 peer_1636 peer_954 peer_3921 peer_6888 peer_6206 peer_9173 peer_2140 peer_1458 peer_4425 peer_
Sun Oct 27 13:30:17 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Sun Oct 27 13:32:12 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Oct 27 13:32:12 2024 daemon.notice netifd: Network device 'wgclient' link is down
Sun Oct 27 13:32:13 2024 daemon.notice netifd: Interface 'wgclient' is now down
Sun Oct 27 13:32:13 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Oct 27 13:32:18 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Oct 27 13:32:18 2024 daemon.notice netifd: wgclient (1127): RTNETLINK answers: Permission denied
Sun Oct 27 13:33:17 2024 daemon.notice netifd: Interface 'wgclient' is now down
Sun Oct 27 13:33:17 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Oct 27 13:34:37 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Oct 27 13:34:37 2024 daemon.notice netifd: wgclient (3686): RTNETLINK answers: Permission denied)
After i enable ipv6 the logs shows something different.
Sun Oct 27 13:39:16 2024 user.notice nat6: Firewall config="wgclient" zone="wgclient" zone_masq6="1".
Sun Oct 27 13:39:17 2024 user.notice nat6: Firewall config="wgclient" zone="wgclient" zone_masq6="1".
Sun Oct 27 13:39:26 2024 user.notice nat6: Firewall config="wgclient" zone="wgclient" zone_masq6="1".
Sun Oct 27 13:39:30 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Oct 27 13:39:32 2024 user.notice nat6: Firewall config="wgclient" zone="wgclient" zone_masq6="1".
Sun Oct 27 13:39:32 2024 user.notice nat6: Found firewall zone_name="wgclient" with zone_masq6="1" zone_masq6_privacy="1".
Sun Oct 27 13:39:32 2024 user.notice nat6: Setting up masquerading nat6 for zone_name="wgclient" with zone_masq6_privacy="1"
Sun Oct 27 13:39:32 2024 user.notice nat6: Ensuring ip6tables chain="zone_wgclient_postrouting" contains our MASQUERADE.
Sun Oct 27 13:39:32 2024 user.notice nat6: Ensuring ip6tables chain="zone_wgclient_input" contains our permissive DNAT rule.
Sun Oct 27 13:39:32 2024 user.notice nat6: Ensuring ip6tables chain="zone_wgclient_forward" contains our permissive DNAT rule.
Sun Oct 27 13:39:32 2024 user.notice nat6: Done setting up nat6 for zone="wgclient" on devices:
So I ended up having to manually configure ipv4 and ipv6 dns resolver instead of using my SSH command sh -c 'sh -c "$(curl -sSL https://api.controld.com/dl)" -s redacted forced'
so far I am using my vpn while using my controlD dns as I type this and by looking at my dns queries / logs it seems DoH is now working with my vpn. the fact I did not needed to do this before until now seems a bit of an odd change.
