Flint 2 | Flint 3 - v4.9.0 Firmware Bug
I have both Flint 2 and Flint 3 and on both of them I am running v4.9.0.
On the web UI for DHCP reservations, why is it that it doesn’t show all the reservations? I have over 20 reservations. My screen shows only about 10 and no possibility to display the rest. I was expecting some pagination when the reservations exceed the space allocated for the reservations.
I have Flint-2 on 4.9 beta 4 and my page shows all 24 reservations without any need for further pages so this does not appear to be a universal fault.
You could be right. I imported the reservations from /etc/config/dhcp of another router that I have - only the reservations part of that file. If there was a problem with doing that, it shouldn’t be showing some and leaving some, no?
Anyway, I will delete all of them and configure manually one by one and see. I had hoped OpenWrt is OpenWrt whether on Dynalink or Flint X.
This would hold true if both were using vanilla openwrt.
You’re right. I have just manually created all the reservations on Flint 2 and copied them to Flint 3 and they are now displaying correctly. I think the issue was caused by extra options that are in the vanilla OpenWrt and not in the gl-iNet code.
