Devices / firmware
- GL-MT6000 (Flint 2): 4.11.3 release (update time 2026-11-27 02:54:54 UTC). Router mode, single WAN (DHCP), WireGuard client (policy mode), WireGuard server, AdGuard Home.
- GL-MT3000 (Beryl AX), mesh node since 27 Nov: 4.11.3 release (update time 2026-11-27 03:25:47 UTC).
- Flint history: 4.11 installed 18 Oct 2026, 4.11.2 on 24 Nov, 4.11.3 on 27 Nov.
1. Mesh appears to have been switched on after the 4.11 upgrade
On the Flint, /etc/config/prplmesh and /etc/config/gl-mesh are dated 18 Oct 2026 17:30:54 and 17:31:00 (UK time), about four minutes after the 4.11 first boot. Other configs new in 4.11 (e.g. network-quality) are dated 17:26–17:28. gl-mesh had enabled='1', mode='controller', log_level='DEBUG'. I don't recall enabling mesh and had no nodes. From then on the full prplMesh stack ran (beerocks_controller, beerocks_agent, beerocks_fronthaul on ra0 and rax0, i1905d), with a hidden backhaul BSS, and 802.11k/v enabled on the main SSIDs.
2. beerocks_monitor floods the log with errors
Several times a second, beerocks_monitor logs (ra0 shown; same for ra1, rax0, rax1, rax3):
ERROR mon_wlan_hal_whm.cpp[308] --> Failed to read Enable from Device.WiFi.SSID.[Name == 'ra0'].
ERROR monitor.cpp[1042] --> Failed updating VAP statistics for iface=ra0
WARNING wbapi_utils.cpp[30] --> not Supported bandwidth value: 0MHz
WARNING monitor.cpp[915] --> update_sta_stats: long running operation, stop iterating on all stations
Write rate measured on the Flint (4.11.3, no nodes): /tmp/beerocks/logs grew ~1.38 MB in 4 min 19 s (about 19 MB/hour), ~1 MB of it beerocks_monitor_ra0. On 4.11.0–4.11.2, with no limit on these logs, that would fill /tmp (~495 MB tmpfs) in roughly a day.
3. Symptoms on 4.11.0–4.11.2 consistent with memory exhaustion
From October: phones intermittently refused or dropped from Wi-Fi, roughly daily. On 26 Nov, a full Wi-Fi lockout about two days after a reboot: SSIDs still visible, clients failing to connect with a generic error, cleared only by rebooting. I didn't capture memory figures during a lockout, so the link to the log growth is my inference, not proven.
4. 4.11.3: logs now rotate, but the errors continue, also on a node
On 4.11.3 the beerocks logs rotate (~1 MB per file, older files removed), so /tmp no longer fills. The errors themselves continue. With mesh re-enabled and the Beryl AX added as a node (both 4.11.3), the node shows the same errors: every rotated beerocks_monitor file contains 100–270 "Failed to read Enable from Device.WiFi.SSID" lines. Its monitor logs rotate about once a minute, and it wrote ~8 MB of mesh logs in 15 minutes before rotation trimmed them back.
5. Steering on a single router
With no nodes, the controller still band-steered clients between the 2.4 and 5 GHz radios of the same router:
optimal_path_task.cpp[1893] --> [Band steer] for sta <redacted> from <2.4G BSSID> to <5G BSSID>
optimal_path_task.cpp[1837] --> optimal_path_task: legacy steering suppressed (11v/BTM unsupported or forced steering requested)
Mesh → Reset (27 Nov) stopped the processes and the log growth until I re-enabled mesh to add the node.
Questions
- Is mesh (controller mode) meant to be enabled automatically when upgrading to 4.11?
- Are the whm "Failed to read Enable from Device.WiFi.SSID" errors expected on the MT6000 / MT3000? They suggest prplMesh can't read the Wi-Fi data model, which would presumably also affect its steering decisions.
- Should the controller run and steer clients on a router with no mesh nodes?
- Is a fix planned for the underlying error, beyond the 4.11.3 log rotation?
I'm keeping mesh on with remote syslog and 15-minute memory snapshots on both routers, and will report back in a week. Happy to send full logs privately to support.
