I'll test it as soon as I get home.
Release note of V4.6.3-op24 says:
Upgraded AdGuard Home to version 0.107.46
But this version has a security issue which was fixed on 0.107.47... but one day after was released the 0.107.48 to fix another critical issue.
Why not go direct to 0.107.52?
If someone wants to use a backup config file from previous op24 version and is using Wireguard, you'll have to add the line
explict_vpn:x:20000:root
to /etc/group otherwise dnsmasq won't start.
Found 2 minor bugs:
Trying to set MTU to wan interface doesn't work (I am using a VLAN), the form is simply blank on GL-UI after connection showing the default 1500 value. Changing MTU from Luci works and then you can see that value on GL-UI.
MiniDLNA won't work on boot unless you restart it (pheraphs it's starting before the USB drive is mounted?)
They fixed fullcone which wasn't working in the previous version and they also fixed opening ports in the firewall directly from the gl gui. in the previous version you had to open the doors in luci.
So far I'm liking this version.
EDIT: Unfortunately, after restarting the door opening via gl ui it stopped working, only for luci, and fullcone also stopped working.
good morning!
fullcone in this version 4.6.3-op24 is not working and opening the ports of a specific device is also not working, it works if you open the port directly from luci.
Could you check before releasing as a stable version?
this problem still persists.
is resolved with the command below.
uci set system.@system[0].cronloglevel="10"
uci commit system
uci show system
/etc/init.d/gl_timer restart
a clean install was done
I agree with the other members that this thread is getting out of control, so I will close it now.
If there are specific bugs you want to report, please refer to How to get support quickly
If you are having issues with WireGuard VPN, please refer to How to troubleshoot WireGuard
For all other topics (and after reading How to get support quickly) feel free to open up a new thread
- including all necessary information.
