You’re losing time.
These speeds are what is advertised from the vendor, you can see specific details by searching for the chip based on the Flint 2, the Filogic 830.
PS: Every router vendor does this. Just wake up…
You’re losing time.
I don’t think I’m losing time asking for their measurements to compare against what they have announced ![]()
They announced what the vendor says. And this is the same for every router brands.
Again and again and again…we are talking about same things.
Great, so they can ask to their vendors why the chipset is not given the performance announced.
Again? ![]()
Why are you ignoring what I already said before?
in 4.5.7 a lot of tools miss from the package repository (at least fdisk, cfdisk, cryptsetup, several modules like kmod-crypto-user)
edit:
glinet_packages (4.5.5) was 816kB, glinet_gli_packages is a mere 626 kB, so I guess ~ 25% are missing.
edit 2:
~25% were a good guess, it’s 9712 packages in 4.5.5 and 4.5.6 (same distfeeds.conf) vs. 7757 packages in 4.5.7
There’s not much incentive to update when functionality is abandoned, GL-inet starts to remind of Microsoft where updating is a sure receipt for trouble
Yes, for certification from regulatory bodies a lab is used. Most of us don’t have a telecom lab sitting at home inside a Faraday Cage. But most of the better reviewers set up their test routers and nodes in the same locations and with the same WIFI parameters to be able to compare router performance. Pretty much all the reviewers do it that way. That is not 10 decimal place precise, but it is directionally correct testing.
After being on 4.57 for about 8 hours…I decided to go back to 4.56 (Uboot restore) for now…Until I can figure out what I’m going to do…Clearly this whole Flint 2 firmware thing is going nowhere at least in the short term. I may give the Open-Wrt Snapshot a go and of course pull my hair out trying to get that going…Or just sit still for a while…Or abandon this all together and go back to Asus Merlin…
Would you mind sharing with us what the issues are, you discovered?
An extremely uneasy feeling that I was sitting on a flawed unpatched firmware by a company that does not know what to do and are more concerned with designing picture frames for their next 21.02 router.
Using an Openwrt snapshot and is working very well I have to say. Some devices that were not able to connect to both wifi with lg.net firmware (both .6 and .7) are now working very well.
So not real issues, just emotional ones. I see.
Fully expected that response from you. Not looking to get into a p contest with you. No I’m not a Router Programmer/Engineer…I do know from experience that when companies do stuff like this…I lose complete confidence. I guess you feel differently. To each his own.
Well, ain't my reasons good enough?
A firmware missing ~25% of package repository, missing essential tools like fdisk and (the needed modukes for) cryptsetup is enough reason to downgrade.
TBH I do use the Flint2 only as switch, AP and DHCP-/VPN-server, kept my Beryl as router and kept it on firmware 3.x bc firmware v.4 already is a huge step down, made by people w/o actual networking practice who downgraded functionality (especially
Currently I‘m running 4.5.4 as this one is working more of less stable besides the WiFi issues. I’ve seen multiple people in this thread which also stay on that version as the newer ones had new issues. Hopefully they are creating a new firmware with the updated OpenWRT branch based on the 4.5.4 version which then may resolves some remaining issues.
Yeah, totally essential packages like fdisk or cryptsetup on a router for consumers.
I don’t understand why people are always trying to do professional things without having a clue. OpenWrt is simply some kind of Linux, so just use the power, Luke!
cd /tmp
wget https://archive.openwrt.org/releases/21.02.0/packages/aarch64_cortex-a53/base/libfdisk1_2.36.1-2_aarch64_cortex-a53.ipk && opkg install libfdisk1_2.36.1-2_aarch64_cortex-a53.ipk
wget https://archive.openwrt.org/releases/21.02.0/packages/aarch64_cortex-a53/base/fdisk_2.36.1-2_aarch64_cortex-a53.ipk && opkg install fdisk_2.36.1-2_aarch64_cortex-a53.ipk
And … ![]()
root@robbenrouter:~# fdisk -v
fdisk from util-linux 2.36.1
Sure, bc. a sane user does automated backup to encrypted external media.
Whilst he can use a Linux machine or VM (needs to own it to use it!) to create said media he still cannot open and mount it in 4.5.7.
But I see how 'serious' your approach is. What a pity, v.3 were cool versatile actually usable routers.
regarding the rest:
Already downgraded to 4.5.6 and will probably stay with it for a while, it's just too much effort to check/edit your scripts after each update, it's really like with MSFT.
We are still talking about a router.
It does route things. It’s not a NAS, nor a media server, nor some UTM next-gen firewall.
Doing backups on a encrypted hard drive attached to a router is just … insane. Of course, it works, like many things. But it’s not the job of the router to provide the possibility.
If you need it, because you built some custom whatever (like using an encrypted HDD connected to the router to store files there) then you need to take care of it by yourself, just my 2 cents.
One backs up the routers configs and other changed/added files, not external stuff.
