xize11
May 2, 2024, 9:25am
1935
Does this happen on OpenWrt master?
I cannot replicate this with mt76 alone on kernel 6.6, but there are indeed some quirks i noticed.
For the increase of slowness:
One example is when i use something like banip, if the ban list is kinda above 20000 elements i get these strange time outs aswell, though my expectation is that the cpu should ‘handle’ this expensive load, but instead doesn’t handle it very well, i noticed the same type behaviours on sqm when banip was turned off and irqbalance, so somehow i suspect mt79 being vulnerable to cpu load in where the speed can malfunction.
When i ended disabling them it works stable to me, and when i removed all my interfering devices such as bluetooth and usb stick my range also normalized, i’m aware there is also a bug report for end devices using bluetooth and wifi causing issues can you check if this improves your connection?
opened 01:30PM - 16 Apr 24 UTC
target/mediatek
bug
SNAPSHOT
Self Built Image
### Describe the bug
I'm a bit unsure whether I should post this problem here… or rather in the mt76 repo. Let me know if it is out of place here.
I have several devices here (HTC U12 Plus, OnePlus 10 Pro, Samsung Galaxy A32) that have very low download speeds (just under 20 MBit) if they are connected to the router via the 2.4 GHz module (MT7975N). It is irrelevant whether both devices are in an inteference-free environment or not. However, if the client are connected to the 5 GHz module (MT7975P), they show a stable download speed (stable well above 80 MBit).
An iperf3 test (attached below) between router and client shows that the MT7975N module apparently has problems in the TX direction. Many retries are noticeable. These problems do not appear to occur in the RX direction. The 5 GHz module (MT7975P), on the other hand, shows a stable bandwidth over minutes with very few retries.
I first noticed this problem with OpenWRT release 23.05.2 (I have not tried older versions) and it also occurs in 23.05.3. I currently have a self-built image running on the router. The OpenWRT source is from last night (main branch). I have changed the mt76 package to the current commit "8f301a5c5fe3d998b50666bde1d35d412833be89". The problem can also be observed here.
I then ran an 802.11 dump. I noticed that during the iperf3 test the client occasionally sends QoS Null function and QoS Data frames with the power management flag set.
The whole thing becomes even stranger as soon as the client are sent to standby while the iperf3 test is running. The bandwidth stabilizes abruptly to around 100 MBit and the retries stop immediately. There are also no more frames to be seen with the power management flag set.
So is this possibly a problem with the power saving?
On the other hand, the devices work without any problems with other chipsets.
Iperf3 test on latest source - TX path:
> Accepted connection from 192.168.1.215, port 44074
> [ 5] local 192.168.1.1 port 5201 connected to 192.168.1.215 port 44076
> [ ID] Interval Transfer Bitrate Retr Cwnd
> [ 5] 0.00-1.00 sec 2.62 MBytes 22.0 Mbits/sec 48 41.0 KBytes
> [ 5] 1.00-2.00 sec 3.00 MBytes 25.2 Mbits/sec 6 43.8 KBytes
> [ 5] 2.00-3.00 sec 3.38 MBytes 28.3 Mbits/sec 18 53.7 KBytes
> [ 5] 3.00-4.00 sec 9.62 MBytes 80.7 Mbits/sec 74 56.6 KBytes
> [ 5] 4.00-5.00 sec 10.0 MBytes 83.9 Mbits/sec 58 90.5 KBytes
> [ 5] 5.00-6.00 sec 10.0 MBytes 83.9 Mbits/sec 99 73.5 KBytes
> [ 5] 6.00-7.00 sec 9.50 MBytes 79.7 Mbits/sec 47 67.9 KBytes
> [ 5] 7.00-8.00 sec 10.4 MBytes 87.0 Mbits/sec 54 105 KBytes
> [ 5] 8.00-9.00 sec 9.50 MBytes 79.7 Mbits/sec 98 63.6 KBytes
> [ 5] 9.00-10.00 sec 10.6 MBytes 89.1 Mbits/sec 54 89.1 KBytes
> [ 5] 10.00-11.00 sec 10.4 MBytes 87.0 Mbits/sec 71 100 KBytes
> [ 5] 11.00-12.00 sec 9.50 MBytes 79.7 Mbits/sec 125 48.1 KBytes
> [ 5] 12.00-13.00 sec 10.1 MBytes 84.9 Mbits/sec 62 79.2 KBytes
> [ 5] 13.00-14.00 sec 10.2 MBytes 86.0 Mbits/sec 40 28.3 KBytes
> [ 5] 14.00-15.00 sec 8.88 MBytes 74.4 Mbits/sec 65 66.5 KBytes
> [ 5] 15.00-16.00 sec 10.0 MBytes 83.9 Mbits/sec 21 103 KBytes
> [ 5] 16.00-17.00 sec 9.88 MBytes 82.8 Mbits/sec 97 84.8 KBytes
> [ 5] 17.00-18.00 sec 10.6 MBytes 89.1 Mbits/sec 98 82.0 KBytes
> [ 5] 18.00-19.00 sec 10.4 MBytes 87.0 Mbits/sec 66 102 KBytes
> [ 5] 19.00-20.00 sec 9.38 MBytes 78.6 Mbits/sec 71 59.4 KBytes
> [ 5] 20.00-21.00 sec 10.2 MBytes 86.0 Mbits/sec 36 86.3 KBytes
> [ 5] 21.00-22.00 sec 10.2 MBytes 86.0 Mbits/sec 76 80.6 KBytes
> [ 5] 22.00-23.00 sec 10.1 MBytes 84.9 Mbits/sec 78 60.8 KBytes
> [ 5] 23.00-24.00 sec 10.2 MBytes 86.0 Mbits/sec 57 96.2 KBytes
> [ 5] 24.00-25.00 sec 10.4 MBytes 87.0 Mbits/sec 78 84.8 KBytes
> [ 5] 25.00-26.00 sec 10.0 MBytes 83.9 Mbits/sec 44 82.0 KBytes
> [ 5] 26.00-27.00 sec 10.8 MBytes 90.2 Mbits/sec 20 110 KBytes
> [ 5] 27.00-28.00 sec 9.38 MBytes 78.6 Mbits/sec 124 59.4 KBytes
> [ 5] 28.00-29.00 sec 7.00 MBytes 58.7 Mbits/sec 50 1.41 KBytes
> [ 5] 29.00-30.00 sec 10.0 MBytes 83.9 Mbits/sec 108 99.0 KBytes
> [ 5] 30.00-31.00 sec 9.25 MBytes 77.6 Mbits/sec 102 63.6 KBytes
> [ 5] 31.00-32.00 sec 10.2 MBytes 86.0 Mbits/sec 47 102 KBytes
> [ 5] 32.00-33.00 sec 9.75 MBytes 81.8 Mbits/sec 52 119 KBytes
> [ 5] 33.00-34.00 sec 9.75 MBytes 81.8 Mbits/sec 152 63.6 KBytes
> [ 5] 34.00-35.00 sec 10.2 MBytes 86.0 Mbits/sec 15 96.2 KBytes
> [ 5] 35.00-36.00 sec 9.25 MBytes 77.6 Mbits/sec 85 56.6 KBytes
> [ 5] 36.00-37.00 sec 10.0 MBytes 83.9 Mbits/sec 55 84.8 KBytes
> [ 5] 37.00-38.00 sec 8.75 MBytes 73.4 Mbits/sec 45 249 KBytes
> [ 5] 38.00-39.00 sec 9.88 MBytes 82.8 Mbits/sec 324 94.7 KBytes
> [ 5] 39.00-40.00 sec 10.4 MBytes 87.0 Mbits/sec 51 83.4 KBytes
> [ 5] 40.00-41.00 sec 10.1 MBytes 84.9 Mbits/sec 42 89.1 KBytes
> [ 5] 41.00-42.00 sec 10.6 MBytes 89.1 Mbits/sec 76 83.4 KBytes
> [ 5] 42.00-43.00 sec 10.4 MBytes 87.0 Mbits/sec 85 103 KBytes
> [ 5] 43.00-44.00 sec 10.5 MBytes 88.1 Mbits/sec 22 86.3 KBytes
> [ 5] 44.00-45.00 sec 9.62 MBytes 80.7 Mbits/sec 84 76.4 KBytes
> [ 5] 45.00-46.00 sec 10.2 MBytes 86.0 Mbits/sec 62 102 KBytes
> [ 5] 46.00-47.00 sec 9.12 MBytes 76.5 Mbits/sec 116 62.2 KBytes
> [ 5] 47.00-48.00 sec 10.2 MBytes 86.0 Mbits/sec 66 74.9 KBytes
> [ 5] 48.00-49.00 sec 10.2 MBytes 86.0 Mbits/sec 50 110 KBytes
> [ 5] 49.00-50.00 sec 9.00 MBytes 75.5 Mbits/sec 113 66.5 KBytes
> [ 5] 50.00-51.00 sec 10.5 MBytes 88.1 Mbits/sec 30 103 KBytes
> [ 5] 51.00-52.00 sec 10.4 MBytes 87.0 Mbits/sec 81 86.3 KBytes
> [ 5] 52.00-53.00 sec 9.75 MBytes 81.8 Mbits/sec 52 83.4 KBytes
> [ 5] 53.00-54.00 sec 11.0 MBytes 92.3 Mbits/sec 28 123 KBytes
> [ 5] 54.00-55.00 sec 9.50 MBytes 79.7 Mbits/sec 105 62.2 KBytes
> [ 5] 55.00-56.00 sec 10.5 MBytes 88.1 Mbits/sec 60 84.8 KBytes
> [ 5] 56.00-57.00 sec 9.62 MBytes 80.7 Mbits/sec 71 66.5 KBytes
> [ 5] 57.00-58.00 sec 9.50 MBytes 79.7 Mbits/sec 50 58.0 KBytes
> [ 5] 58.00-59.00 sec 10.8 MBytes 90.2 Mbits/sec 66 97.6 KBytes
> [ 5] 59.00-60.00 sec 9.75 MBytes 81.8 Mbits/sec 112 55.1 KBytes
> [ 5] 0.00-60.00 sec 575 MBytes 80.4 Mbits/sec 4242 sender
Iperf3 test on latest source - TX path with standby:
> Accepted connection from 192.168.1.215, port 44110
> [ 5] local 192.168.1.1 port 5201 connected to 192.168.1.215 port 44112
> [ 5] 0.00-1.00 sec 9.38 MBytes 78.6 Mbits/sec 59 65.0 KBytes
> [ 5] 1.00-2.00 sec 10.6 MBytes 89.1 Mbits/sec 74 94.7 KBytes
> [ 5] 2.00-3.00 sec 10.4 MBytes 87.0 Mbits/sec 20 115 KBytes
> [ 5] 3.00-4.00 sec 10.5 MBytes 88.1 Mbits/sec 126 79.2 KBytes
> [ 5] 4.00-5.00 sec 11.1 MBytes 93.3 Mbits/sec 52 120 KBytes
> [ 5] 5.00-6.00 sec 10.5 MBytes 88.1 Mbits/sec 134 76.4 KBytes
> [ 5] 6.00-7.00 sec 9.75 MBytes 81.8 Mbits/sec 75 58.0 KBytes
> [ 5] 7.00-8.00 sec 10.6 MBytes 89.2 Mbits/sec 68 105 KBytes
> [ 5] 8.00-9.00 sec 9.38 MBytes 78.6 Mbits/sec 116 76.4 KBytes
> [ 5] 9.00-10.00 sec 10.5 MBytes 88.1 Mbits/sec 53 100 KBytes
> [ 5] 10.00-11.00 sec 10.1 MBytes 84.9 Mbits/sec 74 116 KBytes
> [ 5] 11.00-12.00 sec 10.5 MBytes 88.1 Mbits/sec 67 123 KBytes <-- Client has been set to standby
> [ 5] 12.00-13.00 sec 12.4 MBytes 104 Mbits/sec 0 184 KBytes
> [ 5] 13.00-14.00 sec 12.6 MBytes 106 Mbits/sec 0 232 KBytes
> [ 5] 14.00-15.00 sec 13.1 MBytes 110 Mbits/sec 0 264 KBytes
> [ 5] 15.00-16.00 sec 12.9 MBytes 108 Mbits/sec 0 294 KBytes
> [ 5] 16.00-17.00 sec 13.0 MBytes 109 Mbits/sec 0 314 KBytes
> [ 5] 17.00-18.00 sec 12.8 MBytes 107 Mbits/sec 0 334 KBytes
> [ 5] 18.00-19.00 sec 13.5 MBytes 113 Mbits/sec 0 349 KBytes
> [ 5] 19.00-20.00 sec 12.9 MBytes 108 Mbits/sec 0 358 KBytes
> [ 5] 20.00-21.00 sec 13.2 MBytes 111 Mbits/sec 0 370 KBytes
> [ 5] 21.00-22.00 sec 12.5 MBytes 105 Mbits/sec 0 376 KBytes
> [ 5] 22.00-23.00 sec 13.2 MBytes 111 Mbits/sec 0 472 KBytes
> [ 5] 23.00-24.00 sec 11.9 MBytes 99.6 Mbits/sec 0 549 KBytes
> [ 5] 24.00-25.00 sec 12.9 MBytes 108 Mbits/sec 0 677 KBytes
> [ 5] 25.00-26.00 sec 13.8 MBytes 115 Mbits/sec 0 864 KBytes
> [ 5] 26.00-27.00 sec 12.9 MBytes 108 Mbits/sec 0 864 KBytes
> [ 5] 27.00-28.00 sec 12.6 MBytes 106 Mbits/sec 0 864 KBytes
> [ 5] 28.00-29.00 sec 12.6 MBytes 106 Mbits/sec 0 864 KBytes
> [ 5] 29.00-30.00 sec 12.8 MBytes 107 Mbits/sec 0 864 KBytes
> [ 5] 30.00-31.00 sec 13.2 MBytes 111 Mbits/sec 0 864 KBytes
> [ 5] 31.00-32.00 sec 11.2 MBytes 94.4 Mbits/sec 0 864 KBytes
> [ 5] 32.00-33.00 sec 11.1 MBytes 93.3 Mbits/sec 578 79.2 KBytes <-- Client has been taken out of standby
> [ 5] 33.00-34.00 sec 10.0 MBytes 83.9 Mbits/sec 494 228 KBytes
> [ 5] 34.00-35.00 sec 11.1 MBytes 93.3 Mbits/sec 231 106 KBytes
> [ 5] 35.00-36.00 sec 8.25 MBytes 69.2 Mbits/sec 82 70.7 KBytes
> [ 5] 36.00-37.00 sec 9.62 MBytes 80.7 Mbits/sec 53 102 KBytes
> [ 5] 37.00-38.00 sec 6.88 MBytes 57.7 Mbits/sec 66 60.8 KBytes
> [ 5] 38.00-39.00 sec 9.62 MBytes 80.7 Mbits/sec 28 93.3 KBytes
> [ 5] 39.00-40.00 sec 9.62 MBytes 80.7 Mbits/sec 47 112 KBytes
> [ 5] 40.00-41.00 sec 7.25 MBytes 60.8 Mbits/sec 217 80.6 KBytes
> [ 5] 41.00-42.00 sec 8.25 MBytes 69.2 Mbits/sec 16 106 KBytes
> [ 5] 42.00-43.00 sec 9.62 MBytes 80.7 Mbits/sec 64 83.4 KBytes
> [ 5] 43.00-44.00 sec 8.12 MBytes 68.2 Mbits/sec 36 74.9 KBytes
> [ 5] 44.00-45.00 sec 9.62 MBytes 80.8 Mbits/sec 23 103 KBytes
> [ 5] 45.00-46.00 sec 9.62 MBytes 80.7 Mbits/sec 114 60.8 KBytes
> [ 5] 46.00-47.00 sec 9.50 MBytes 79.7 Mbits/sec 22 80.6 KBytes <-- Client has been switched to standby again
> [ 5] 47.00-48.00 sec 11.1 MBytes 93.3 Mbits/sec 0 157 KBytes
> [ 5] 48.00-49.00 sec 12.4 MBytes 104 Mbits/sec 0 208 KBytes
> [ 5] 49.00-50.00 sec 11.0 MBytes 92.3 Mbits/sec 0 246 KBytes
> [ 5] 50.00-51.00 sec 12.6 MBytes 106 Mbits/sec 0 276 KBytes
> [ 5] 51.00-52.00 sec 12.6 MBytes 106 Mbits/sec 0 298 KBytes
> [ 5] 52.00-53.00 sec 12.4 MBytes 104 Mbits/sec 0 320 KBytes
> [ 5] 53.00-54.00 sec 12.6 MBytes 106 Mbits/sec 0 335 KBytes
> [ 5] 54.00-55.00 sec 14.1 MBytes 118 Mbits/sec 0 349 KBytes
> [ 5] 55.00-56.00 sec 12.8 MBytes 107 Mbits/sec 0 359 KBytes
> [ 5] 56.00-57.00 sec 12.6 MBytes 106 Mbits/sec 0 372 KBytes
> [ 5] 57.00-58.00 sec 12.4 MBytes 104 Mbits/sec 0 416 KBytes
> [ 5] 58.00-59.00 sec 12.9 MBytes 108 Mbits/sec 0 526 KBytes
> [ 5] 59.00-60.00 sec 11.2 MBytes 94.4 Mbits/sec 0 652 KBytes
> [ 5] 0.00-60.00 sec 678 MBytes 94.8 Mbits/sec 2989 sender
Iperf3 test on latest source - RX path:
> Connecting to host 192.168.1.1, port 5201
> [ 5] local 192.168.1.215 port 39712 connected to 192.168.1.1 port 5201
> [ 5] 0.00-1.00 sec 11.6 MBytes 97.2 Mbits/sec 44 303 KBytes
> [ 5] 1.00-2.00 sec 12.4 MBytes 103 Mbits/sec 0 337 KBytes
> [ 5] 2.00-3.00 sec 11.7 MBytes 98.4 Mbits/sec 0 356 KBytes
> [ 5] 3.00-4.00 sec 11.6 MBytes 97.1 Mbits/sec 0 366 KBytes
> [ 5] 4.00-5.00 sec 12.8 MBytes 107 Mbits/sec 0 392 KBytes
> [ 5] 5.00-6.00 sec 12.5 MBytes 105 Mbits/sec 0 416 KBytes
> [ 5] 6.00-7.00 sec 11.7 MBytes 98.1 Mbits/sec 24 337 KBytes
> [ 5] 7.00-8.00 sec 12.2 MBytes 102 Mbits/sec 0 373 KBytes
> [ 5] 8.00-9.00 sec 12.2 MBytes 102 Mbits/sec 0 399 KBytes
> [ 5] 9.00-10.00 sec 12.2 MBytes 103 Mbits/sec 0 413 KBytes
> [ 5] 10.00-11.00 sec 11.7 MBytes 98.5 Mbits/sec 0 419 KBytes
> [ 5] 11.00-12.00 sec 12.1 MBytes 101 Mbits/sec 0 431 KBytes
> [ 5] 12.00-13.00 sec 12.8 MBytes 107 Mbits/sec 0 454 KBytes
> [ 5] 13.00-14.00 sec 12.7 MBytes 107 Mbits/sec 0 475 KBytes
> [ 5] 14.00-15.00 sec 12.8 MBytes 108 Mbits/sec 0 495 KBytes
> [ 5] 15.00-16.00 sec 12.9 MBytes 108 Mbits/sec 0 515 KBytes
> [ 5] 16.00-17.00 sec 11.9 MBytes 99.6 Mbits/sec 0 533 KBytes
> [ 5] 17.00-18.00 sec 12.8 MBytes 107 Mbits/sec 0 550 KBytes
> [ 5] 18.00-19.00 sec 12.5 MBytes 105 Mbits/sec 0 590 KBytes
> [ 5] 19.00-20.00 sec 12.1 MBytes 101 Mbits/sec 0 679 KBytes
> [ 5] 20.00-21.00 sec 11.4 MBytes 96.3 Mbits/sec 225 542 KBytes
> [ 5] 21.00-22.00 sec 11.6 MBytes 97.2 Mbits/sec 0 598 KBytes
> [ 5] 22.00-23.00 sec 12.7 MBytes 106 Mbits/sec 0 636 KBytes
> [ 5] 23.00-24.00 sec 12.8 MBytes 108 Mbits/sec 0 662 KBytes
> [ 5] 24.00-25.00 sec 12.8 MBytes 107 Mbits/sec 0 675 KBytes
> [ 5] 25.00-26.00 sec 12.6 MBytes 106 Mbits/sec 135 506 KBytes
> [ 5] 26.00-27.00 sec 12.3 MBytes 103 Mbits/sec 0 542 KBytes
> [ 5] 27.00-28.00 sec 12.4 MBytes 104 Mbits/sec 0 561 KBytes
> [ 5] 28.00-29.00 sec 12.6 MBytes 106 Mbits/sec 0 571 KBytes
> [ 5] 29.00-30.00 sec 13.1 MBytes 109 Mbits/sec 0 574 KBytes
> [ 5] 30.00-31.00 sec 12.3 MBytes 104 Mbits/sec 0 574 KBytes
> [ 5] 31.00-32.00 sec 12.7 MBytes 106 Mbits/sec 0 590 KBytes
> [ 5] 32.00-33.00 sec 12.9 MBytes 108 Mbits/sec 0 605 KBytes
> [ 5] 33.00-34.00 sec 12.1 MBytes 101 Mbits/sec 0 621 KBytes
> [ 5] 34.00-35.00 sec 12.7 MBytes 107 Mbits/sec 135 492 KBytes
> [ 5] 35.00-36.00 sec 12.0 MBytes 101 Mbits/sec 0 546 KBytes
> [ 5] 36.00-37.00 sec 12.4 MBytes 104 Mbits/sec 0 583 KBytes
> [ 5] 37.00-38.00 sec 12.0 MBytes 100 Mbits/sec 0 605 KBytes
> [ 5] 38.00-39.00 sec 13.1 MBytes 109 Mbits/sec 0 618 KBytes
> [ 5] 39.00-40.00 sec 12.2 MBytes 102 Mbits/sec 0 622 KBytes
> [ 5] 40.00-41.00 sec 12.5 MBytes 105 Mbits/sec 0 622 KBytes
> [ 5] 41.00-42.00 sec 12.9 MBytes 108 Mbits/sec 0 622 KBytes
> [ 5] 42.00-43.00 sec 12.7 MBytes 107 Mbits/sec 0 625 KBytes
> [ 5] 43.00-44.00 sec 12.8 MBytes 107 Mbits/sec 0 635 KBytes
> [ 5] 44.00-45.00 sec 12.7 MBytes 107 Mbits/sec 0 655 KBytes
> [ 5] 45.00-46.00 sec 12.7 MBytes 107 Mbits/sec 0 686 KBytes
> [ 5] 46.00-47.00 sec 13.3 MBytes 111 Mbits/sec 0 735 KBytes
> [ 5] 47.00-48.00 sec 12.9 MBytes 108 Mbits/sec 0 802 KBytes
> [ 5] 48.00-49.00 sec 12.5 MBytes 105 Mbits/sec 0 626 KBytes
> [ 5] 49.00-50.00 sec 13.0 MBytes 109 Mbits/sec 45 491 KBytes
> [ 5] 50.00-51.00 sec 12.8 MBytes 107 Mbits/sec 0 530 KBytes
> [ 5] 51.00-52.00 sec 12.6 MBytes 106 Mbits/sec 0 554 KBytes
> [ 5] 52.00-53.00 sec 12.8 MBytes 107 Mbits/sec 0 567 KBytes
> [ 5] 53.00-54.00 sec 12.6 MBytes 105 Mbits/sec 0 573 KBytes
> [ 5] 54.00-55.00 sec 12.3 MBytes 103 Mbits/sec 0 573 KBytes
> [ 5] 55.00-56.00 sec 11.9 MBytes 99.5 Mbits/sec 0 581 KBytes
> [ 5] 56.00-57.00 sec 12.8 MBytes 107 Mbits/sec 0 598 KBytes
> [ 5] 57.00-58.00 sec 12.7 MBytes 106 Mbits/sec 0 614 KBytes
> [ 5] 58.00-59.00 sec 12.7 MBytes 107 Mbits/sec 0 629 KBytes
> [ 5] 59.00-60.00 sec 11.8 MBytes 99.2 Mbits/sec 0 643 KBytes
> [ 5] 0.00-60.00 sec 747 MBytes 104 Mbits/sec 608 sender
> [ 5] 0.00-60.02 sec 747 MBytes 104 Mbits/sec receiver
station dump:
> Station 74:f6:1c:00:07:5a (on phy0-ap0)
> inactive time: 10 ms
> rx bytes: 20652981
> rx packets: 232663
> tx bytes: 4186210649
> tx packets: 2730929
> tx retries: 46785
> tx failed: 46792
> rx drop misc: 1
> signal: -46 [-51, -49, -53, -53] dBm
> signal avg: -45 [-50, -48, -52, -52] dBm
> tx bitrate: 130.0 MBit/s MCS 15
> tx duration: 271301023 us
> rx bitrate: 144.4 MBit/s MCS 15 short GI
> rx duration: 21442329 us
> last ack signal:-30 dBm
> avg ack signal: -29 dBm
> airtime weight: 256
> authorized: yes
> authenticated: yes
> associated: yes
> preamble: short
> WMM/WME: yes
> MFP: no
> TDLS peer: no
> DTIM period: 2
> beacon interval:100
> short preamble: yes
> short slot time:yes
> connected time: 1756 seconds
> associated at [boottime]: 11531.518s
> associated at: 1713270221356 ms
> current time: 1713271977259 ms
### OpenWrt version
r25934-93d75f8401
### OpenWrt release
SNAPSHOT
### OpenWrt target/subtarget
mediatek/filogic
### Device
Bananapi BPI-R3
### Image kind
Self-built image
### Steps to reproduce
_No response_
### Actual behaviour
_No response_
### Expected behaviour
_No response_
### Additional info
_No response_
### Diffconfig
```text
CONFIG_TARGET_mediatek=y
CONFIG_TARGET_mediatek_filogic=y
CONFIG_TARGET_mediatek_filogic_DEVICE_bananapi_bpi-r3=y
CONFIG_ALL_KMODS=y
CONFIG_ALL_NONSHARED=y
CONFIG_DEVEL=y
CONFIG_AUTOREMOVE=y
CONFIG_BPF_TOOLCHAIN_BUILD_LLVM=y
# CONFIG_BPF_TOOLCHAIN_NONE is not set
CONFIG_BUILDBOT=y
CONFIG_CCACHE=y
CONFIG_COLLECT_KERNEL_DEBUG=y
CONFIG_HAS_BPF_TOOLCHAIN=y
CONFIG_HTOP_LMSENSORS=y
CONFIG_IB=y
CONFIG_IMAGEOPT=y
CONFIG_JSON_CYCLONEDX_SBOM=y
CONFIG_KERNEL_BUILD_DOMAIN="buildhost"
CONFIG_KERNEL_BUILD_USER="builder"
# CONFIG_KERNEL_KALLSYMS is not set
CONFIG_LIBCURL_COOKIES=y
CONFIG_LIBCURL_FILE=y
CONFIG_LIBCURL_FTP=y
CONFIG_LIBCURL_HTTP=y
CONFIG_LIBCURL_MBEDTLS=y
CONFIG_LIBCURL_NGHTTP2=y
CONFIG_LIBCURL_NO_SMB="!"
CONFIG_LIBCURL_PROXY=y
CONFIG_LIBCURL_UNIX_SOCKETS=y
CONFIG_LIBQMI_COLLECTION_FULL=y
CONFIG_LIBQMI_WITH_MBIM_QMUX=y
CONFIG_LIBQMI_WITH_QRTR_GLIB=y
CONFIG_LUCI_LANG_de=y
CONFIG_MAKE_TOOLCHAIN=y
CONFIG_MODEMMANAGER_WITH_AT_COMMAND_VIA_DBUS=y
CONFIG_MODEMMANAGER_WITH_MBIM=y
CONFIG_MODEMMANAGER_WITH_QMI=y
CONFIG_MODEMMANAGER_WITH_QRTR=y
CONFIG_OPENSSL_ENGINE=y
CONFIG_OPENSSL_WITH_ASM=y
CONFIG_OPENSSL_WITH_CHACHA_POLY1305=y
CONFIG_OPENSSL_WITH_CMS=y
CONFIG_OPENSSL_WITH_DEPRECATED=y
CONFIG_OPENSSL_WITH_ERROR_MESSAGES=y
CONFIG_OPENSSL_WITH_IDEA=y
CONFIG_OPENSSL_WITH_MDC2=y
CONFIG_OPENSSL_WITH_PSK=y
CONFIG_OPENSSL_WITH_SEED=y
CONFIG_OPENSSL_WITH_SRP=y
CONFIG_OPENSSL_WITH_TLS13=y
CONFIG_OPENSSL_WITH_WHIRLPOOL=y
CONFIG_OPENVPN_openssl_ENABLE_FRAGMENT=y
CONFIG_OPENVPN_openssl_ENABLE_LZ4=y
CONFIG_OPENVPN_openssl_ENABLE_LZO=y
CONFIG_OPENVPN_openssl_ENABLE_PORT_SHARE=y
CONFIG_OPENVPN_openssl_ENABLE_SMALL=y
# CONFIG_PACKAGE_atm-aread is not set
# CONFIG_PACKAGE_atm-atmaddr is not set
# CONFIG_PACKAGE_atm-atmdiag is not set
# CONFIG_PACKAGE_atm-atmdump is not set
# CONFIG_PACKAGE_atm-atmloop is not set
# CONFIG_PACKAGE_atm-atmsigd is not set
# CONFIG_PACKAGE_atm-atmswitch is not set
# CONFIG_PACKAGE_atm-atmtcp is not set
# CONFIG_PACKAGE_atm-awrite is not set
# CONFIG_PACKAGE_atm-bus is not set
# CONFIG_PACKAGE_atm-debug-tools is not set
# CONFIG_PACKAGE_atm-diagnostics is not set
# CONFIG_PACKAGE_atm-esi is not set
# CONFIG_PACKAGE_atm-ilmid is not set
# CONFIG_PACKAGE_atm-ilmidiag is not set
# CONFIG_PACKAGE_atm-lecs is not set
# CONFIG_PACKAGE_atm-les is not set
# CONFIG_PACKAGE_atm-mpcd is not set
# CONFIG_PACKAGE_atm-saaldump is not set
# CONFIG_PACKAGE_atm-sonetdiag is not set
# CONFIG_PACKAGE_atm-svc_recv is not set
# CONFIG_PACKAGE_atm-svc_send is not set
# CONFIG_PACKAGE_atm-tools is not set
# CONFIG_PACKAGE_atm-ttcp_atm is not set
# CONFIG_PACKAGE_atm-zeppelin is not set
CONFIG_PACKAGE_bash=y
CONFIG_PACKAGE_blkid=y
# CONFIG_PACKAGE_br2684ctl is not set
CONFIG_PACKAGE_ca-certificates=y
CONFIG_PACKAGE_cgi-io=y
CONFIG_PACKAGE_chat=y
CONFIG_PACKAGE_comgt=y
CONFIG_PACKAGE_comgt-directip=y
CONFIG_PACKAGE_comgt-ncm=y
CONFIG_PACKAGE_curl=y
CONFIG_PACKAGE_dbus=y
CONFIG_PACKAGE_dmesg=y
CONFIG_PACKAGE_ethtool-full=y
CONFIG_PACKAGE_fdisk=y
CONFIG_PACKAGE_glib2=y
CONFIG_PACKAGE_htop=y
CONFIG_PACKAGE_iftop=y
CONFIG_PACKAGE_iperf3=y
# CONFIG_PACKAGE_iw is not set
CONFIG_PACKAGE_iw-full=y
CONFIG_PACKAGE_iwcap=y
# CONFIG_PACKAGE_kmod-3c59x is not set
# CONFIG_PACKAGE_kmod-8139cp is not set
# CONFIG_PACKAGE_kmod-8139too is not set
# CONFIG_PACKAGE_kmod-alx is not set
# CONFIG_PACKAGE_kmod-ar5523 is not set
# CONFIG_PACKAGE_kmod-at86rf230 is not set
# CONFIG_PACKAGE_kmod-ath is not set
# CONFIG_PACKAGE_kmod-ath10k is not set
# CONFIG_PACKAGE_kmod-ath10k-ct is not set
# CONFIG_PACKAGE_kmod-ath10k-ct-smallbuffers is not set
# CONFIG_PACKAGE_kmod-ath10k-smallbuffers is not set
# CONFIG_PACKAGE_kmod-ath11k is not set
# CONFIG_PACKAGE_kmod-ath11k-pci is not set
# CONFIG_PACKAGE_kmod-ath5k is not set
# CONFIG_PACKAGE_kmod-ath6kl-sdio is not set
# CONFIG_PACKAGE_kmod-ath6kl-usb is not set
# CONFIG_PACKAGE_kmod-ath9k is not set
# CONFIG_PACKAGE_kmod-ath9k-htc is not set
# CONFIG_PACKAGE_kmod-atl1 is not set
# CONFIG_PACKAGE_kmod-atl1c is not set
# CONFIG_PACKAGE_kmod-atl1e is not set
# CONFIG_PACKAGE_kmod-atl2 is not set
# CONFIG_PACKAGE_kmod-atlantic is not set
# CONFIG_PACKAGE_kmod-atusb is not set
# CONFIG_PACKAGE_kmod-b43 is not set
# CONFIG_PACKAGE_kmod-b44 is not set
# CONFIG_PACKAGE_kmod-be2net is not set
# CONFIG_PACKAGE_kmod-bnx2 is not set
# CONFIG_PACKAGE_kmod-bnx2x is not set
# CONFIG_PACKAGE_kmod-brcmfmac is not set
# CONFIG_PACKAGE_kmod-brcmsmac is not set
# CONFIG_PACKAGE_kmod-brcmutil is not set
# CONFIG_PACKAGE_kmod-ca8210 is not set
# CONFIG_PACKAGE_kmod-can is not set
# CONFIG_PACKAGE_kmod-carl9170 is not set
# CONFIG_PACKAGE_kmod-cc2520 is not set
# CONFIG_PACKAGE_kmod-chaoskey is not set
# CONFIG_PACKAGE_kmod-dahdi is not set
# CONFIG_PACKAGE_kmod-dm9000 is not set
# CONFIG_PACKAGE_kmod-e100 is not set
# CONFIG_PACKAGE_kmod-e1000 is not set
# CONFIG_PACKAGE_kmod-e1000e is not set
# CONFIG_PACKAGE_kmod-et131x is not set
# CONFIG_PACKAGE_kmod-ethoc is not set
# CONFIG_PACKAGE_kmod-fakelb is not set
# CONFIG_PACKAGE_kmod-firewire is not set
# CONFIG_PACKAGE_kmod-forcedeth is not set
CONFIG_PACKAGE_kmod-fs-exfat=y
CONFIG_PACKAGE_kmod-fs-ext4=y
# CONFIG_PACKAGE_kmod-fs-ntfs is not set
CONFIG_PACKAGE_kmod-fs-ntfs3=y
CONFIG_PACKAGE_kmod-fs-vfat=y
# CONFIG_PACKAGE_kmod-hfcmulti is not set
# CONFIG_PACKAGE_kmod-hfcpci is not set
# CONFIG_PACKAGE_kmod-i40e is not set
# CONFIG_PACKAGE_kmod-iavf is not set
# CONFIG_PACKAGE_kmod-ieee802154 is not set
# CONFIG_PACKAGE_kmod-ieee802154-6lowpan is not set
# CONFIG_PACKAGE_kmod-igb is not set
# CONFIG_PACKAGE_kmod-igc is not set
# CONFIG_PACKAGE_kmod-iio-ad799x is not set
# CONFIG_PACKAGE_kmod-iio-ads1015 is not set
# CONFIG_PACKAGE_kmod-iio-am2315 is not set
# CONFIG_PACKAGE_kmod-iio-bh1750 is not set
# CONFIG_PACKAGE_kmod-iio-bme680 is not set
# CONFIG_PACKAGE_kmod-iio-bme680-i2c is not set
# CONFIG_PACKAGE_kmod-iio-bme680-spi is not set
# CONFIG_PACKAGE_kmod-iio-bmp280 is not set
# CONFIG_PACKAGE_kmod-iio-bmp280-i2c is not set
# CONFIG_PACKAGE_kmod-iio-bmp280-spi is not set
# CONFIG_PACKAGE_kmod-iio-ccs811 is not set
# CONFIG_PACKAGE_kmod-iio-core is not set
# CONFIG_PACKAGE_kmod-iio-dht11 is not set
# CONFIG_PACKAGE_kmod-iio-fxas21002c is not set
# CONFIG_PACKAGE_kmod-iio-fxas21002c-i2c is not set
# CONFIG_PACKAGE_kmod-iio-fxas21002c-spi is not set
# CONFIG_PACKAGE_kmod-iio-fxos8700 is not set
# CONFIG_PACKAGE_kmod-iio-fxos8700-i2c is not set
# CONFIG_PACKAGE_kmod-iio-fxos8700-spi is not set
# CONFIG_PACKAGE_kmod-iio-hmc5843 is not set
# CONFIG_PACKAGE_kmod-iio-htu21 is not set
# CONFIG_PACKAGE_kmod-iio-kfifo-buf is not set
# CONFIG_PACKAGE_kmod-iio-lsm6dsx is not set
# CONFIG_PACKAGE_kmod-iio-lsm6dsx-i2c is not set
# CONFIG_PACKAGE_kmod-iio-lsm6dsx-spi is not set
# CONFIG_PACKAGE_kmod-iio-mt6577-auxadc is not set
# CONFIG_PACKAGE_kmod-iio-si7020 is not set
# CONFIG_PACKAGE_kmod-iio-sps30 is not set
# CONFIG_PACKAGE_kmod-iio-st_accel is not set
# CONFIG_PACKAGE_kmod-iio-st_accel-i2c is not set
# CONFIG_PACKAGE_kmod-iio-st_accel-spi is not set
# CONFIG_PACKAGE_kmod-iio-tsl4531 is not set
# CONFIG_PACKAGE_kmod-industrialio-triggered-buffer is not set
# CONFIG_PACKAGE_kmod-input-joydev is not set
# CONFIG_PACKAGE_kmod-input-matrixkmap is not set
# CONFIG_PACKAGE_kmod-input-touchscreen-ads7846 is not set
# CONFIG_PACKAGE_kmod-input-touchscreen-edt-ft5x06 is not set
# CONFIG_PACKAGE_kmod-iwlwifi is not set
# CONFIG_PACKAGE_kmod-ixgbe is not set
# CONFIG_PACKAGE_kmod-ixgbevf is not set
# CONFIG_PACKAGE_kmod-lan743x is not set
CONFIG_PACKAGE_kmod-lib-crc16=y
# CONFIG_PACKAGE_kmod-mac802154 is not set
# CONFIG_PACKAGE_kmod-mhi-net is not set
# CONFIG_PACKAGE_kmod-mhi-wwan-ctrl is not set
# CONFIG_PACKAGE_kmod-mhi-wwan-mbim is not set
CONFIG_PACKAGE_kmod-mii=y
# CONFIG_PACKAGE_kmod-mlx4-core is not set
# CONFIG_PACKAGE_kmod-mlx5-core is not set
# CONFIG_PACKAGE_kmod-mrf24j40 is not set
# CONFIG_PACKAGE_kmod-mwifiex-pcie is not set
# CONFIG_PACKAGE_kmod-mwifiex-sdio is not set
# CONFIG_PACKAGE_kmod-mwl8k is not set
# CONFIG_PACKAGE_kmod-natsemi is not set
# CONFIG_PACKAGE_kmod-ne2k-pci is not set
# CONFIG_PACKAGE_kmod-niu is not set
CONFIG_PACKAGE_kmod-nls-cp437=y
CONFIG_PACKAGE_kmod-nls-iso8859-1=y
CONFIG_PACKAGE_kmod-nls-utf8=y
# CONFIG_PACKAGE_kmod-of-mdio is not set
# CONFIG_PACKAGE_kmod-owl-loader is not set
# CONFIG_PACKAGE_kmod-pcnet32 is not set
# CONFIG_PACKAGE_kmod-phy-aquantia is not set
# CONFIG_PACKAGE_kmod-phy-bcm84881 is not set
# CONFIG_PACKAGE_kmod-phy-broadcom is not set
# CONFIG_PACKAGE_kmod-phy-marvell is not set
# CONFIG_PACKAGE_kmod-phy-marvell-10g is not set
# CONFIG_PACKAGE_kmod-phy-realtek is not set
# CONFIG_PACKAGE_kmod-qlcnic is not set
# CONFIG_PACKAGE_kmod-r6040 is not set
# CONFIG_PACKAGE_kmod-r8169 is not set
# CONFIG_PACKAGE_kmod-rsi91x is not set
# CONFIG_PACKAGE_kmod-rsi91x-sdio is not set
# CONFIG_PACKAGE_kmod-rsi91x-usb is not set
# CONFIG_PACKAGE_kmod-rt2800-pci is not set
# CONFIG_PACKAGE_kmod-rt2800-usb is not set
# CONFIG_PACKAGE_kmod-rt2x00-lib is not set
# CONFIG_PACKAGE_kmod-rtl8192ce is not set
# CONFIG_PACKAGE_kmod-rtl8192cu is not set
# CONFIG_PACKAGE_kmod-rtl8192de is not set
# CONFIG_PACKAGE_kmod-rtl8192se is not set
# CONFIG_PACKAGE_kmod-rtl8723bs is not set
# CONFIG_PACKAGE_kmod-rtl8812au-ct is not set
# CONFIG_PACKAGE_kmod-rtl8821ae is not set
# CONFIG_PACKAGE_kmod-rtl8xxxu is not set
CONFIG_PACKAGE_kmod-scsi-core=y
CONFIG_PACKAGE_kmod-sctp=y
# CONFIG_PACKAGE_kmod-sfc is not set
# CONFIG_PACKAGE_kmod-sfc-falcon is not set
# CONFIG_PACKAGE_kmod-siit is not set
# CONFIG_PACKAGE_kmod-sis190 is not set
# CONFIG_PACKAGE_kmod-sis900 is not set
# CONFIG_PACKAGE_kmod-skge is not set
# CONFIG_PACKAGE_kmod-sky2 is not set
# CONFIG_PACKAGE_kmod-solos-pci is not set
# CONFIG_PACKAGE_kmod-spi-ks8995 is not set
# CONFIG_PACKAGE_kmod-switch-ar8xxx is not set
# CONFIG_PACKAGE_kmod-switch-bcm53xx is not set
# CONFIG_PACKAGE_kmod-switch-bcm53xx-mdio is not set
# CONFIG_PACKAGE_kmod-switch-ip17xx is not set
# CONFIG_PACKAGE_kmod-switch-rtl8306 is not set
# CONFIG_PACKAGE_kmod-switch-rtl8366-smi is not set
# CONFIG_PACKAGE_kmod-switch-rtl8366rb is not set
# CONFIG_PACKAGE_kmod-switch-rtl8366s is not set
# CONFIG_PACKAGE_kmod-switch-rtl8367 is not set
# CONFIG_PACKAGE_kmod-switch-rtl8367b is not set
# CONFIG_PACKAGE_kmod-tg3 is not set
# CONFIG_PACKAGE_kmod-tulip is not set
CONFIG_PACKAGE_kmod-tun=y
CONFIG_PACKAGE_kmod-udptunnel4=y
CONFIG_PACKAGE_kmod-udptunnel6=y
# CONFIG_PACKAGE_kmod-usb-atm is not set
# CONFIG_PACKAGE_kmod-usb-cm109 is not set
CONFIG_PACKAGE_kmod-usb-ehci=y
CONFIG_PACKAGE_kmod-usb-net=y
# CONFIG_PACKAGE_kmod-usb-net-aqc111 is not set
# CONFIG_PACKAGE_kmod-usb-net-asix is not set
# CONFIG_PACKAGE_kmod-usb-net-asix-ax88179 is not set
CONFIG_PACKAGE_kmod-usb-net-cdc-ether=y
CONFIG_PACKAGE_kmod-usb-net-cdc-mbim=y
CONFIG_PACKAGE_kmod-usb-net-cdc-ncm=y
# CONFIG_PACKAGE_kmod-usb-net-dm9601-ether is not set
CONFIG_PACKAGE_kmod-usb-net-huawei-cdc-ncm=y
# CONFIG_PACKAGE_kmod-usb-net-ipheth is not set
# CONFIG_PACKAGE_kmod-usb-net-kalmia is not set
# CONFIG_PACKAGE_kmod-usb-net-kaweth is not set
# CONFIG_PACKAGE_kmod-usb-net-lan78xx is not set
# CONFIG_PACKAGE_kmod-usb-net-mcs7830 is not set
# CONFIG_PACKAGE_kmod-usb-net-pegasus is not set
# CONFIG_PACKAGE_kmod-usb-net-pl is not set
CONFIG_PACKAGE_kmod-usb-net-qmi-wwan=y
# CONFIG_PACKAGE_kmod-usb-net-rtl8150 is not set
# CONFIG_PACKAGE_kmod-usb-net-rtl8152 is not set
CONFIG_PACKAGE_kmod-usb-net-sierrawireless=y
# CONFIG_PACKAGE_kmod-usb-net-smsc75xx is not set
# CONFIG_PACKAGE_kmod-usb-net-smsc95xx is not set
# CONFIG_PACKAGE_kmod-usb-net-sr9700 is not set
CONFIG_PACKAGE_kmod-usb-serial=y
# CONFIG_PACKAGE_kmod-usb-serial-garmin is not set
# CONFIG_PACKAGE_kmod-usb-serial-ipw is not set
CONFIG_PACKAGE_kmod-usb-serial-keyspan=y
# CONFIG_PACKAGE_kmod-usb-serial-mos7720 is not set
# CONFIG_PACKAGE_kmod-usb-serial-mos7840 is not set
CONFIG_PACKAGE_kmod-usb-serial-option=y
# CONFIG_PACKAGE_kmod-usb-serial-oti6858 is not set
# CONFIG_PACKAGE_kmod-usb-serial-pl2303 is not set
CONFIG_PACKAGE_kmod-usb-serial-qualcomm=y
CONFIG_PACKAGE_kmod-usb-serial-sierrawireless=y
# CONFIG_PACKAGE_kmod-usb-serial-simple is not set
# CONFIG_PACKAGE_kmod-usb-serial-ti-usb is not set
# CONFIG_PACKAGE_kmod-usb-serial-visor is not set
CONFIG_PACKAGE_kmod-usb-serial-wwan=y
CONFIG_PACKAGE_kmod-usb-storage=y
CONFIG_PACKAGE_kmod-usb-uhci=y
CONFIG_PACKAGE_kmod-usb-wdm=y
# CONFIG_PACKAGE_kmod-usb-yealink is not set
CONFIG_PACKAGE_kmod-usb2=y
# CONFIG_PACKAGE_kmod-via-rhine is not set
# CONFIG_PACKAGE_kmod-via-velocity is not set
# CONFIG_PACKAGE_kmod-vmxnet3 is not set
# CONFIG_PACKAGE_kmod-w1 is not set
# CONFIG_PACKAGE_kmod-wil6210 is not set
# CONFIG_PACKAGE_kmod-wl12xx is not set
# CONFIG_PACKAGE_kmod-wl18xx is not set
# CONFIG_PACKAGE_kmod-wlcore is not set
# CONFIG_PACKAGE_knot-resolver_dnstap is not set
CONFIG_PACKAGE_libaio=y
CONFIG_PACKAGE_libatomic=y
CONFIG_PACKAGE_libattr=y
CONFIG_PACKAGE_libbpf=m
CONFIG_PACKAGE_libbsd=y
CONFIG_PACKAGE_libcap-ng=y
CONFIG_PACKAGE_libcurl=y
CONFIG_PACKAGE_libdbus=y
CONFIG_PACKAGE_libelf=m
CONFIG_PACKAGE_libevdev=y
CONFIG_PACKAGE_libexpat=y
CONFIG_PACKAGE_libfdisk=y
CONFIG_PACKAGE_libffi=y
CONFIG_PACKAGE_libiperf3=y
CONFIG_PACKAGE_libjpeg-turbo=y
CONFIG_PACKAGE_libkmod=y
CONFIG_PACKAGE_liblua=y
CONFIG_PACKAGE_liblucihttp=y
CONFIG_PACKAGE_liblucihttp-lua=y
CONFIG_PACKAGE_liblucihttp-ucode=y
CONFIG_PACKAGE_liblz4=y
CONFIG_PACKAGE_liblzo=y
CONFIG_PACKAGE_libmbim=y
CONFIG_PACKAGE_libmount=y
CONFIG_PACKAGE_libncurses=y
CONFIG_PACKAGE_libnetsnmp=y
CONFIG_PACKAGE_libnghttp2=y
CONFIG_PACKAGE_libnl-core=y
CONFIG_PACKAGE_libnl-genl=y
CONFIG_PACKAGE_libopenssl=y
CONFIG_PACKAGE_libopenssl-conf=y
CONFIG_PACKAGE_libopenssl-legacy=y
CONFIG_PACKAGE_libparted=y
CONFIG_PACKAGE_libpcap=y
CONFIG_PACKAGE_libpci=y
CONFIG_PACKAGE_libpcre2=y
CONFIG_PACKAGE_libqmi=y
CONFIG_PACKAGE_libqrtr-glib=y
CONFIG_PACKAGE_libreadline=y
CONFIG_PACKAGE_libsctp=y
CONFIG_PACKAGE_libsensors=y
CONFIG_PACKAGE_libsmartcols=y
CONFIG_PACKAGE_libspeedtestcpp=y
CONFIG_PACKAGE_libstdcpp=y
CONFIG_PACKAGE_libsysfs=y
CONFIG_PACKAGE_libubus-lua=y
CONFIG_PACKAGE_libuci-lua=y
CONFIG_PACKAGE_libudev-zero=y
CONFIG_PACKAGE_libusb-1.0=y
CONFIG_PACKAGE_libustream-mbedtls=m
CONFIG_PACKAGE_libustream-openssl=y
CONFIG_PACKAGE_libxdp=m
# CONFIG_PACKAGE_linux-atm is not set
CONFIG_PACKAGE_lm-sensors=y
CONFIG_PACKAGE_lm-sensors-detect=y
CONFIG_PACKAGE_lsblk=y
CONFIG_PACKAGE_lua=y
CONFIG_PACKAGE_lua-cjson=y
CONFIG_PACKAGE_luafilesystem=y
CONFIG_PACKAGE_luci=y
CONFIG_PACKAGE_luci-app-acl=y
CONFIG_PACKAGE_luci-app-firewall=y
CONFIG_PACKAGE_luci-app-openvpn=y
CONFIG_PACKAGE_luci-app-openwisp=y
CONFIG_PACKAGE_luci-app-opkg=y
CONFIG_PACKAGE_luci-app-upnp=y
CONFIG_PACKAGE_luci-app-watchcat=y
CONFIG_PACKAGE_luci-base=y
CONFIG_PACKAGE_luci-compat=y
CONFIG_PACKAGE_luci-i18n-acl-de=y
CONFIG_PACKAGE_luci-i18n-base-de=y
CONFIG_PACKAGE_luci-i18n-firewall-de=y
CONFIG_PACKAGE_luci-i18n-openvpn-de=y
CONFIG_PACKAGE_luci-i18n-openwisp-de=y
CONFIG_PACKAGE_luci-i18n-opkg-de=y
CONFIG_PACKAGE_luci-i18n-upnp-de=y
CONFIG_PACKAGE_luci-i18n-watchcat-de=y
CONFIG_PACKAGE_luci-lib-base=y
CONFIG_PACKAGE_luci-lib-ip=y
CONFIG_PACKAGE_luci-lib-jsonc=y
CONFIG_PACKAGE_luci-lib-nixio=y
CONFIG_PACKAGE_luci-light=y
CONFIG_PACKAGE_luci-lua-runtime=y
CONFIG_PACKAGE_luci-mod-admin-full=y
CONFIG_PACKAGE_luci-mod-network=y
CONFIG_PACKAGE_luci-mod-status=y
CONFIG_PACKAGE_luci-mod-system=y
CONFIG_PACKAGE_luci-proto-ipv6=y
CONFIG_PACKAGE_luci-proto-mbim=y
CONFIG_PACKAGE_luci-proto-modemmanager=y
CONFIG_PACKAGE_luci-proto-ncm=y
CONFIG_PACKAGE_luci-proto-ppp=y
CONFIG_PACKAGE_luci-proto-qmi=y
CONFIG_PACKAGE_luci-ssl-openssl=y
CONFIG_PACKAGE_luci-theme-bootstrap=y
CONFIG_PACKAGE_mbim-utils=y
CONFIG_PACKAGE_minicom=y
CONFIG_PACKAGE_miniupnpd-nftables=y
CONFIG_PACKAGE_modemmanager=y
CONFIG_PACKAGE_mtr-json=y
CONFIG_PACKAGE_nand-utils=y
CONFIG_PACKAGE_nano-full=y
CONFIG_PACKAGE_netjson-monitoring=y
CONFIG_PACKAGE_openssh-sftp-server=y
CONFIG_PACKAGE_openssl-util=y
CONFIG_PACKAGE_openvpn-easy-rsa=y
CONFIG_PACKAGE_openvpn-openssl=y
CONFIG_PACKAGE_openwisp-config=y
CONFIG_PACKAGE_openwisp-monitoring=y
CONFIG_PACKAGE_parted=y
CONFIG_PACKAGE_perl=y
CONFIG_PACKAGE_perlbase-base=y
CONFIG_PACKAGE_perlbase-bytes=y
CONFIG_PACKAGE_perlbase-class=y
CONFIG_PACKAGE_perlbase-config=y
CONFIG_PACKAGE_perlbase-cwd=y
CONFIG_PACKAGE_perlbase-data=y
CONFIG_PACKAGE_perlbase-errno=y
CONFIG_PACKAGE_perlbase-essential=y
CONFIG_PACKAGE_perlbase-fcntl=y
CONFIG_PACKAGE_perlbase-file=y
CONFIG_PACKAGE_perlbase-filehandle=y
CONFIG_PACKAGE_perlbase-getopt=y
CONFIG_PACKAGE_perlbase-i18n=y
CONFIG_PACKAGE_perlbase-integer=y
CONFIG_PACKAGE_perlbase-io=y
CONFIG_PACKAGE_perlbase-list=y
CONFIG_PACKAGE_perlbase-locale=y
CONFIG_PACKAGE_perlbase-params=y
CONFIG_PACKAGE_perlbase-posix=y
CONFIG_PACKAGE_perlbase-re=y
CONFIG_PACKAGE_perlbase-scalar=y
CONFIG_PACKAGE_perlbase-selectsaver=y
CONFIG_PACKAGE_perlbase-socket=y
CONFIG_PACKAGE_perlbase-symbol=y
CONFIG_PACKAGE_perlbase-tie=y
CONFIG_PACKAGE_perlbase-unicore=y
CONFIG_PACKAGE_perlbase-utf8=y
CONFIG_PACKAGE_perlbase-xsloader=y
CONFIG_PACKAGE_picocom=y
CONFIG_PACKAGE_powertop=y
CONFIG_PACKAGE_px5g-mbedtls=y
CONFIG_PACKAGE_qmi-utils=y
CONFIG_PACKAGE_qosify=m
CONFIG_PACKAGE_rpcd=y
CONFIG_PACKAGE_rpcd-mod-file=y
CONFIG_PACKAGE_rpcd-mod-iwinfo=y
CONFIG_PACKAGE_rpcd-mod-luci=y
CONFIG_PACKAGE_rpcd-mod-rrdns=y
CONFIG_PACKAGE_rpcd-mod-ucode=y
CONFIG_PACKAGE_screen=y
CONFIG_PACKAGE_sms-tool=y
CONFIG_PACKAGE_snmpd=y
CONFIG_PACKAGE_speedtestcpp=y
CONFIG_PACKAGE_stress-ng=y
CONFIG_PACKAGE_sysfsutils=y
CONFIG_PACKAGE_tc-tiny=m
CONFIG_PACKAGE_tcpdump=y
CONFIG_PACKAGE_terminfo=y
CONFIG_PACKAGE_ucode-mod-html=y
CONFIG_PACKAGE_ucode-mod-lua=y
CONFIG_PACKAGE_ucode-mod-math=y
CONFIG_PACKAGE_uhttpd=y
CONFIG_PACKAGE_uhttpd-mod-ubus=y
CONFIG_PACKAGE_umbim=y
CONFIG_PACKAGE_uqmi=y
CONFIG_PACKAGE_usb-modeswitch=y
CONFIG_PACKAGE_usbids=y
CONFIG_PACKAGE_usbutils=y
CONFIG_PACKAGE_watchcat=y
CONFIG_PACKAGE_wget-ssl=y
# CONFIG_PACKAGE_wpad-basic-mbedtls is not set
CONFIG_PACKAGE_wpad-openssl=y
CONFIG_PACKAGE_wwan=y
CONFIG_PACKAGE_xdp-filter=m
CONFIG_PACKAGE_xdp-loader=m
CONFIG_PACKAGE_xdpdump=m
CONFIG_PACKAGE_zlib=y
CONFIG_PARTED_READLINE=y
CONFIG_PERL_NOCOMMENT=y
CONFIG_PERL_THREADS=y
CONFIG_REPRODUCIBLE_DEBUG_INFO=y
CONFIG_SDK=y
CONFIG_SDK_LLVM_BPF=y
CONFIG_USE_LLVM_BUILD=y
CONFIG_VERSIONOPT=y
CONFIG_VERSION_BUG_URL=""
CONFIG_VERSION_CODE=""
CONFIG_VERSION_DIST="OpenWrt"
CONFIG_VERSION_FILENAMES=y
CONFIG_VERSION_HOME_URL=""
CONFIG_VERSION_HWREV=""
CONFIG_VERSION_MANUFACTURER=""
CONFIG_VERSION_MANUFACTURER_URL=""
CONFIG_VERSION_NUMBER=""
CONFIG_VERSION_PRODUCT=""
CONFIG_VERSION_REPO="https://downloads.openwrt.org/releases/23.05.2"
CONFIG_VERSION_SUPPORT_URL=""
CONFIG_PACKAGE_ath9k-htc-firmware=m
CONFIG_PACKAGE_bnx2-firmware=m
CONFIG_PACKAGE_bnx2x-firmware=m
CONFIG_PACKAGE_brcmfmac-firmware-usb=m
CONFIG_PACKAGE_carl9170-firmware=m
CONFIG_PACKAGE_e100-firmware=m
CONFIG_PACKAGE_mwifiex-pcie-firmware=m
CONFIG_PACKAGE_mwl8k-firmware=m
CONFIG_PACKAGE_r8152-firmware=m
CONFIG_PACKAGE_r8169-firmware=m
CONFIG_PACKAGE_rs9113-firmware=m
CONFIG_PACKAGE_rt2800-pci-firmware=m
CONFIG_PACKAGE_rt2800-usb-firmware=m
CONFIG_PACKAGE_rtl8192ce-firmware=m
CONFIG_PACKAGE_rtl8192cu-firmware=m
CONFIG_PACKAGE_rtl8192de-firmware=m
CONFIG_PACKAGE_rtl8192se-firmware=m
CONFIG_PACKAGE_rtl8821ae-firmware=m
CONFIG_PACKAGE_wil6210-firmware=m
CONFIG_PACKAGE_wl12xx-firmware=m
CONFIG_PACKAGE_wl18xx-firmware=m
# CONFIG_VERSION_CODE_FILENAMES is not set
### Terms
- [X] I am reporting an issue for OpenWrt, not an unsupported fork.
It happens for me with the snapshot version which I got from: OpenWrt Firmware Selector
I also created an issue report: MT7986 - temporarily ping spikes and terrible WiFi performance - 5GHz, 160 MHz · Issue #877 · openwrt/mt76 · GitHub
SQM was never activated by me. I have a VLAN network switch connected to the Flints USB port, but its just using the power, no data is transmitted.
The mentioned problems disappear with the stock firmware 4.5.8 or by using the Flint 1 instead.
xize11
May 2, 2024, 10:45am
1937
This could be part of the issue even though no data is going through there might be electricity interference, it is how well shielded the connection is from the cables connector.
But why it is not an issue for the firmware 4.5.8 and even the Flint 1?
xize11
May 2, 2024, 10:49am
1939
My suspicioun is that it runs on usb2 or usb1 drivers, but the OpenWrt version by default uses usb3, i could be wrong but that seem the most reasonable explaination.
You could try opkg update && opkg install usbutils and then type lsusb inside the cli if you see xhci its using usb 3, ehci is usb 2.
oly
May 2, 2024, 2:29pm
1940
Hello all,
@GL.iNet Staff Please focus on the latest stable version of OpenWrt
23.05.3, I returned to the official GL-MT6000 software and I am satisfied, I have been using it for 5 days on a pppoe ipv6 dual stack connection with IPV6 active, wireguard server, everything works without problems!
GL-MT6000 Ver.4.5.6 Xiaomi 14 wifi speed test 2Ghz & 5Ghz!
xize11
May 2, 2024, 6:07pm
1942
Jup in that case it must be a issue then since the usb3 is mutual present in both firmwares
I'm having regular also WiFi crashes with 4.5.8 every 1-2 hrs for around 5min. My VLAN switch is now powered externally.
@alzhao I can provide you the full log file if you want.
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.492372] mtwf_dbg_prt: vsnprintf error
Fri May 3 17:15:33 2024 kern.err kernel: [56525.496399] 7986@C08L1,wifi_sys_op_lock() 812: wifi_sys_disconn_act+0xec/0x2b8 [mt_wifi](0): get wdev_op_lock fail!! The latest caller with the lock: wifi_sys_disconn_act+/../mt_wifi/embedded/common/wifi_sys_info.c:813 assert FALSEfailed
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.517420] CPU: 0 PID: 6525 Comm: RtmpMlmeTask Tainted: P 5.4.238 #0
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.525319] Hardware name: GL.iNet GL-MT6000 (DT)
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.530008] Call trace:
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.532447] dump_backtrace+0x0/0x198
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.536096] show_stack+0x14/0x20
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.539399] dump_stack+0xb4/0xf4
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.542865] wifi_sys_op_lock+0x17c/0x1a8 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.547832] wifi_sys_disconn_act+0xec/0x2b8 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.553037] wdev_do_disconn_act+0x20/0x38 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.558060] MacTableDeleteEntry+0x370/0x1160 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.563340] ap_peer_auth_req_at_idle_action+0x894/0x1820 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.569663] auth_fsm_mlme_auth_req_action+0x5dc/0x778 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.575723] StateMachinePerformAction+0x6c/0x80 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.581264] MlmeHandler+0x6d4/0x958 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.585763] MlmeHandler+0x898/0x958 [mt_wifi]
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.590194] kthread+0x120/0x128
Fri May 3 17:15:33 2024 kern.debug kernel: [56525.593410] ret_from_fork+0x10/0x1c
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.691950] mtwf_dbg_prt: vsnprintf error
Fri May 3 17:16:24 2024 kern.err kernel: [56576.695970] 7986@C08L1,wifi_sys_op_lock() 812: wifi_sys_disconn_act+0xec/0x2b8 [mt_wifi](0): get wdev_op_lock fail!! The latest caller with the lock: wifi_sys_disconn_act+/../mt_wifi/embedded/common/wifi_sys_info.c:813 assert FALSEfailed
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.717298] CPU: 0 PID: 4897 Comm: RtmpCmdQTask Tainted: P 5.4.238 #0
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.725197] Hardware name: GL.iNet GL-MT6000 (DT)
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.729887] Call trace:
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.732326] dump_backtrace+0x0/0x198
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.735976] show_stack+0x14/0x20
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.739280] dump_stack+0xb4/0xf4
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.742772] wifi_sys_op_lock+0x17c/0x1a8 [mt_wifi]
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.747757] wifi_sys_disconn_act+0xec/0x2b8 [mt_wifi]
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.752960] wdev_do_disconn_act+0x20/0x38 [mt_wifi]
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.757981] MacTableDeleteEntry+0x370/0x1160 [mt_wifi]
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.763260] SetRtsThenCtsRetryCnt+0x37c/0xcc8 [mt_wifi]
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.768628] CMDHandler+0x13c/0x2b0 [mt_wifi]
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.773042] RTPCICmdThread+0x1c8/0x278 [mt_wifi]
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.777803] hif_cmd_thread+0x2c/0x88 [mt_wifi]
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.782321] kthread+0x120/0x128
Fri May 3 17:16:24 2024 kern.debug kernel: [56576.785538] ret_from_fork+0x10/0x1c
Edit: It looks like this is caused by a unspecific client. It didn't happen so far in the evening.
I'm also wondering. Why is Gl-inet using an old MTK version?
Currently it is:
Filogic 630/830 MP2.1 Release (20230508)
while there is already:
Filogic 830 MP2.2 Release (20231027)
Source:
https://git01.mediatek.com/plugins/gitiles/openwrt/feeds/mtk-openwrt-feeds/+/refs/heads/master/autobuild_mac80211_release/Release.md
I tried to compile MP2.2, which worked fine but unfortunately it seems to need some further configuration so that it can boot from the MT6000.
ethernet port 2 like wan 2 does not work as load balance
bonefire:
wifi_sys_op_lock
What’s your cypher? WPAx?
None, Open (public) network.
@xize11 I also tried the OpenWRT snapshot version without anything connected to USB. The WiFi is still timing out/freezing and the performance often suddenly terrible. There is not much traffic load during this time.
Here a comparison between openwrt snapshot and the stock firmware 4.5.8
xize11
May 4, 2024, 3:14pm
1947
This is indeed strange, could it be something device specific?
For the random speed i noticed this too, often it fixes itself by reconnecting to wifi or by repositioning the device angle towards the router.
Though my router hangs vertically and also some of the antennas point to the wrong direction, it isn’t super bad since i pulled up a few antenna vertical but it could explain why this happens to me.
I think that your device lost connection for some reason… Just to understand if you set a wpa2 do you get same issue?
Do you get this issue from a specific device? Do you measure the ping from the device or from router or?
Thank you!
Flyboy
May 5, 2024, 5:17am
1949
Yes brand new Flint2 and can’t even get in to the routers browser. Password doesn’t work!
What a shame!
admon
May 5, 2024, 8:04am
1950
There is no password.
Are you sure it’s a brand new one?
Reset it so the initial setup will begin.
Since I updated Flint2 to v4.5.8 my Fairphone3 has difficulties to reconnect to wifi. The wifi networks from Flint2 does not appear anymore in stored wifi networks of the phone.
So it works fine at the first connection and it won’t or hardly reconnect after. Even if I click on one of my wifi network (2.4G or 5G, LAN or Guest) the FP3 ask again for the password (weird?) and then nothing more happens.
I tried to reset wifi data from FP3 but it changed nothing.
On other wifi networks I don’t have this problem.
admon
May 5, 2024, 12:09pm
1952
From which version did you update to 4.5.8?
Hi, I updated from v4.5.6
(I used to install v4.5.7. As I needed docker that did not work anymore I rolled back to v4.5.6 and reset the router)
