Flint 2 (GL-MT6000) – Compatibility with Huawei/Vodafone K5160 USB 4G modem for WAN failover
Hello everyone,
I'm considering purchasing a GL.iNet Flint 2 (GL-MT6000) to replace my current router, and I would like to confirm compatibility with my existing Huawei/Vodafone K5160 USB 4G LTE dongle before making the purchase.
The USB modem is already working perfectly on Linux (Debian 12, Raspberry Pi 5) with the following characteristics:
  • Model: Huawei/Vodafone K5160
  • USB Vendor/Product ID: 12d1:157f (after mode switching)
  • Linux driver: cdc_ether
  • Operating mode: Host-less / USB Ethernet
  • USB network interface: eth1
  • IP address assigned via DHCP: 192.168.9.109
  • Modem gateway: 192.168.9.1
  • Internet connectivity: Successfully tested over LTE with a Vodafone Italy SIM
The modem presents itself as a USB Ethernet network adapter and handles the cellular connection internally.
My intended configuration is:
  • Primary WAN: Ethernet connection to my existing FTTH router.
  • Backup WAN: Huawei K5160 connected directly to the Flint 2 USB port.
  • Automatic failover: Switch to USB/LTE when the primary FTTH Internet connection becomes unavailable, even if the Ethernet link remains physically active.
  • Automatic failback: Return to the primary Ethernet WAN once Internet connectivity is restored and stable.
I have read that GL.iNet routers support host-less USB modems through the Tethering interface.
Could someone from GL.iNet technical support, or anyone with practical experience, please confirm:
  1. Is the Huawei K5160 (12d1:157f, cdc_ether) supported by the Flint 2 GL-MT6000 with its official stock firmware?
  2. Should it be automatically recognized as a USB Ethernet/tethering WAN device, without installing additional drivers or modifying the firmware?
  3. Can this USB connection participate in the router's automatic Multi-WAN failover and failback functionality, including detection of Internet failure while the primary Ethernet link remains UP?
  4. Are there any known limitations or additional configuration requirements for this specific USB modem?
I would prefer to use the official GL.iNet firmware and web interface, without custom OpenWrt modifications.
My main concern is confirming compatibility before purchasing the router, since the USB 4G backup is an essential requirement for my home network.
Thank you very much for your help!
Thanks for the detailed information. Please check our response below:
  1. We haven't tested the K5160 with the Flint 2, and we haven't found confirmed user reports of this combination working with our stock firmware. Other community users have reported it working on OpenWrt, so our -op firmware or vanilla OpenWrt may be alternatives if needed. However, compatibility with those builds is also unverified.
  2. If the K5160 operates in HiLink/host-less mode using RNDIS or CDC Ethernet, we would expect the Flint 2 to recognize it as a Tethering device. We cannot confirm that it will work without additional configuration until this combination has been tested.
  3. Yes—provided the modem works correctly as a Tethering connection, it can participate in automatic failover and failback. With interface status tracking enabled, the router can detect loss of Internet connectivity even when the Ethernet link remains physically active. Please see our Multi-WAN guide for details.
  4. We are not currently aware of any K5160-specific limitations or additional configuration requirements, though our testing coverage for this model is limited.
First of all, thank you very much for your detailed and helpful response regarding the Huawei K5160 USB modem compatibility and Multi-WAN failover functionality.
Before deciding to purchase the Flint 2 (GL-MT6000), I would like to clarify one additional important aspect: Wi-Fi coverage and performance with the latest stock firmware.
My current router is a Vodafone Wi-Fi 6 Station (Sercomm RHG3006), featuring 4×4 MIMO on both 2.4 GHz and 5 GHz bands.
The Flint 2 appears to have comparable radio specifications, also featuring 4×4 MIMO on both bands and four external antennas.
However, I have read community reports suggesting that Wi-Fi coverage, particularly on the 2.4 GHz band, decreased after firmware version 4.8.4 due to changes in transmit power settings required for regulatory compliance.
This is especially important in my case because I have several IoT devices and outdoor security cameras operating at the edge of my current router's Wi-Fi coverage.
Could you please clarify the following?
  1. Has the Wi-Fi coverage issue reported after firmware 4.8.4 been addressed or improved in subsequent stable firmware releases, particularly version 4.11.0?
  2. With the router configured for Italy/EU regulatory requirements, should I expect the Flint 2 to provide Wi-Fi coverage comparable to a high-end Wi-Fi 6 router with 4×4 MIMO, such as my Vodafone Station?
  3. Are there any known limitations affecting 2.4 GHz range, transmit power or reception sensitivity with the latest stock firmware?
  4. Can GL.iNet provide any technical measurements, comparative coverage tests or recommendations for installations where reliable connectivity to distant 2.4 GHz IoT devices is essential?
I understand that actual Wi-Fi coverage depends on the environment and cannot be guaranteed without testing. However, I would like to avoid replacing my current router with a device that might offer less coverage, especially after regulatory firmware changes.
My intention is to use the official GL.iNet firmware, without custom modifications or changes that could violate EU radio regulations.
Thank you again for your support and technical clarification.
Best regards
I'm being using this one Inseego USB8 Global USB Modem with my Flint2 since day one (almost 3 years) with all kinds of firmware from stock op21 op23 op24 op25 to vanilla op24 op25 and it never failed to be recognized by the router, and being a great wan backup option.
Like @will.qiu said you can tried with yours and see if it fit your needs, if not just return it :call_me_hand:
Thanks for the follow-up. The adjustments introduced in firmware v4.8.4 were made to ensure compliance with applicable regulatory requirements. Please refer to our official statement in the earlier discussion for more details:
