Ok, I did some tests here with the GL-MT3000. I did a clean install of firmwares 4.4.6 and 4.5.0 (beta).
The problem is on firmware 4.5.0 where the download speed on 2.4GHz drops abruptly on Android. In firmware 4.4.6 this does not happen.
Although if I back up the settings from firmware 4.4.6 and put it in firmware 4.5.0, the problem is solved. There is something with the configuration files in firmware 4.5.0 and I believe this is also reflected in Flint 2 as it is in firmware 4.5.x
I still don’t know which file is the villain.
EDIT:
Ok, on Beryl sometimes on firmware 4.5.0 clean install I have more than 200mbps download speed, but sometimes less then 100mbps. So, I can’t really say the culprit is firmware 4.5.0.
But on Flint 2 I never got more than 100/120mbps download speed
Having this problem as well. I’m on firmware 4.5.3 and have 1.5gbs fiber. On 5ghz i’m getting 1400mbs and on 2.4ghz i’m only getting ~40mbs right next to router (testing on Samsung S23)
I seem to observe similar behaviour but on a snapshot of OpenWrt, somehow 5ghz has more range than 2.4ghz which is kind of strange to me, on the flint 1 i was even able to reach it with 5 bars from 4/5th levels of my appartment outside.
On the other hand I have roaming active on a another flint 2 with official firmware, maybe i should check later what it shows when im far away with the OpenWrts one off.
The strange thing is in wifiman it keeps saying both AP are in 20mhz when I had set them to 40mhz.
Now i also have set them to legacy and B rates unchecked to see if it works better.
Something seem off, can someone confirm if flint 2 signal is more interfering to close devices like a wifi connected energy meter (homewizard)?
I just tested snapshot of OpenWrt on MT3000 and the speed on Android, on 2.4ghz is very slow. But changing to GL inet firmware (21.10 based) I have no more issues with 2.4GHz speed on MT3000.
Since MT6000 is 23.05 based, It seems the problem is related with openwrt version.
i guess the driver has to mature too, on their github branch i still see some commits, but i also see some issues too.
I guess its all very new, from what i understand even sharing the calibration firmware through emmc is something they also added recently atleast from what i understand of it.
I hope once when a new release comes out it can be added to GL’s, because i believe the current version is 23.05.0 rc0 when 23.05.02 is out as full release but support is added after 23.05.02 for mt6000 that would be a much more stable foundation as fork.
Just bought Flint 2 from AliExpress and I have the same problem, wifi 2.4ghz speed is awful and the latency is very high on android and other devices. My old Slate GL-AR750s is much better in 2.4ghz band, it’s crazy
Same here, getting 20mbps/down on 2.4ghz compared to 580mbps/down on 5ghz. Still much slower than my ISP-provided Eero at 950mbps/down but the 2.4ghz is obscenely slow.
I was having slowed 2.4 GHz Wi-Fi speeds on my iPhone 11so I changed the Wi-Fi mode from 11b/g/n/ax to 11g/n/ax and it went from 60 Mbps to 120Mpbs. That is not the full speed of my connection as it is a 250 Mbps. I then switched back to 11b/g/n/ax just to check and I was still getting 120 Mbps?? Go figure. Don't know if this will help you guys, but it worked for me.
I’m also getting around 120Mbs on 2.4 set to 20MHz channel width. I’d guess that would improve if I set it to 40 MHz?
My uneducated guess is that the 2.4 GHz radio is worse than my old router….in fairness, I haven’t tried to tune any settings to improve it. Initially, I thought this would be an issue for me but the 5 GHz channel is working so well and the range better than my old router that I don’t need 2.4 for anything other than my IoT devices, so I honestly don’t care if it’s a bit lacking. I use 5 GHz for everything important.
But what also helps is using a phone app to check the noise levels such as wifi analyzer or wifiman.
Setting it to auto can help aswell since it will search for the proper channels, this only works as expected if you have set the correct country settings via luci.
I do know a bad channel can cause alot of slower internet, the flint 2 wifi is also very vulnerable on the usb connection try setting it on usb 2.0 or none usb if the usb port is in use.
Also the use of the original plug is important.
Other than that, it could also be the case of a bad patch cable, depending how your flint 2 has been setup.
I lately had also a similar situation, i had a patch cable with passthrough connectors, always worked for me, until my switch reported it as a FE (100mbps negotiation), when i replugged it was fine at 2.5gbps i re-terminated it since the contacts weren't properly connected, it was also not erroring on the cable tester, try replace those rj45 cables too if your router uses them as for a connected wan/ap router.
^ i forgot to add, you may want to look into dhcp spamming too, if such cables switch between negotiation rate it will spam relentless, this can make your full network slow, because it basicly creates amplification by ignoring acks, i had two of these things going on
I live in a rural area and don't have many neighbors close to me. I periodically do run wifi scans to check radio traffic around me. Where I live, there are two 2.4 GHz channels broadcasting but they are on channels 6 and 11 (they obviously understand how things work) - so I set mine to channel 1. That is about as clean as 2.4 GHz can get and would also allow 40 MHz channel width to work without issue if I wanted. I'm not sure if my old IoT cameras 'understand' 40 MHz,
As for the rest, the 5 GHz is extremely fast - so that rules out bad networking or DNS issues. Because both radio frequencies share a common feed inside the router.
EDIT - all the resetting of my cable modem was fortuitous - I noticed my Xfinity speeds went up from 300/20 to 400/35... And then I read an article that Xfinity had just increased the speed for every customer at no fee So that's nice. Of course, I can only see that speed on the 5 GHz frequency...
EDIT 2 - you don't even need a phone app to check wifi signals... Luci has a radio scanner built into it.
