houmi
December 31, 2023, 4:16am
The symptom is no connectivity, and the led light blinks. Can’t connect to the router and I can only remove the power and put back. I tried the reset button for 3 seconds per the manual but that didn’t do anything.
I don’t see anything peculiar in system log other than this.
I stopped the Wireguard & Adguard services to see if it reproes again.
Sat Dec 30 20:08:09 2023 daemon.err usbmuxd[8263]: [20:08:09.821][3] usbmuxd v1.1.1 starting up
Sat Dec 30 20:08:09 2023 daemon.err usbmuxd[8263]: [20:08:09.822][3] Using libusb 1.0.26
Sat Dec 30 20:08:09 2023 daemon.err usbmuxd[8263]: [20:08:09.822][3] Initialization complete
Sat Dec 30 20:08:09 2023 daemon.err usbmuxd[8263]: [20:08:09.822][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Sat Dec 30 20:08:11 2023 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:415) found device: radio0 mac80211 phy0 2g
Sat Dec 30 20:08:11 2023 daemon.info lua: (...arch64_cortex-a53/gl-sdk4-repeater/usr/sbin/repeater:415) found device: radio1 mac80211 phy1 5g
Sat Dec 30 20:08:11 2023 daemon.err usbmuxd[8263]: [20:08:11.821][3] Caught signal 15, exiting
Sat Dec 30 20:08:11 2023 daemon.err usbmuxd[8263]: [20:08:11.821][3] usbmuxd shutting down
Sat Dec 30 20:08:11 2023 daemon.err usbmuxd[8263]: [20:08:11.921][3] Shutdown complete
houmi
December 31, 2023, 4:23am
2
I disabled Network acceleration. Going to re-enable AdGuard & WIreGuard in a few to see if it happens again.
Got another crash + some call trace I posted here:
Oops#1 Part1
<7>[ 4087.802747] iptable_filter ipheth ip_tables crc_ccitt compat cls_flower cdc_wdm cdc_acm br_netfilter arptable_filter arpt_mangle arp_tables act_vlan crypto_safexcel fuse cls_bpf act_bpf sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet i…
xize11
December 31, 2023, 5:44am
3
What is the function of your usb stick?
From what i gather it looks your usb disconnects maybe its loose?
The problem is what i suspect is your usb stick is mounted as /overlay?, mind showing the config /etc/fstab with us?
The symptom you can get is that the heavy duty data lands on your router instead of the usb with the potentional it can softbrick the device.
It basically litterly does what it says overlaying so if the overlay falls off it will be placed on the router.
The crash it looks like the wireless driver is crashing but i don’t know why, it can be a interference issue, it can be a full space issue (i see a few high memory offsets in the stack, also the paging start address is high, sounds like its too full of memory or the driver has trouble cleaning something up), it can be something random, either its already known by GL-iNet or you can give them a backup of your configs and firmware version and then remove the sensitive data from it.
^ this is how i would do it, make a backup in luci open it with 7zip and remove everything else except /etc/config this still work if they choose to upload it in luci to test your network they really appreciate such things if they need to replicate such crash.
houmi
December 31, 2023, 6:17am
4
There is nothing connected to the USB port.
Also 95% of my router utilization is done by Ethernet, I don’t use wireless much other than iPhone/iPad which I rarely use.
I’ll work on the backup… where should I upload it to once done ?
xize11
December 31, 2023, 6:21am
5
I guess its a normal message then
I guess i tag @alzhao or @Dipin i think you can sent it to them via private or their email, they will let you know
houmi
December 31, 2023, 6:49am
6
Thanks, I contacted them.
I can repro this consistently more or less.
I basically have wireguard working in the background to a PC (via Ethernet), then I start moving some data via wireless and it crashes the router. It doesn’t matter if Network hardware acceleration is on or off, happens on both cases.
admon
December 31, 2023, 8:39am
7
What kind of data between which devices do you move?
houmi
December 31, 2023, 4:25pm
8
Wireguard on the Router connected to Torguard (via port forwarding), used for Plex (1-2 streams)
Adguard was active
Wireless activities (browsing) in the house but most devices are on Ethernet
IPv6 is active (via passthru), no IPv6 traffic
Ethernet 2 (by WAN) is being used as extra LAN for another device
I thought to disable Wireguard just as a test and it has not crashed so far, so it could be related to Wireguard issues on the router.
houmi
December 31, 2023, 6:31pm
9
I enabled Wireguard, no crashes so far… but a ton of these on the log (what do they mean ?)
Sun Dec 31 09:50:18 2023 kern.info kernel: [36688.815202] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 09:52:20 2023 kern.info kernel: [36811.075650] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 09:54:21 2023 kern.info kernel: [36931.246759] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 09:56:21 2023 kern.info kernel: [37051.263064] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 09:58:24 2023 kern.info kernel: [37174.652290] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:00:28 2023 kern.info kernel: [37298.020904] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:02:28 2023 kern.info kernel: [37418.087809] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:04:30 2023 kern.info kernel: [37539.521082] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:06:30 2023 kern.info kernel: [37659.875450] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:08:31 2023 kern.info kernel: [37780.223775] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:10:31 2023 kern.info kernel: [37900.265912] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:12:31 2023 kern.info kernel: [38020.388421] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:14:32 2023 kern.info kernel: [38140.774687] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:16:33 2023 kern.info kernel: [38261.623509] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:18:33 2023 kern.info kernel: [38381.850848] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:20:34 2023 kern.info kernel: [38502.571440] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:22:35 2023 kern.info kernel: [38623.633442] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:24:35 2023 kern.info kernel: [38743.625441] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:26:36 2023 kern.info kernel: [38864.136806] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Sun Dec 31 10:28:36 2023 kern.info kernel: [38984.676344] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
houmi
December 31, 2023, 8:05pm
10
I noticed some slowness browsing regular pages (wired / wireless) then noticed these crashes in log (I did clean the page previously after I restarted Wiregard).
Note that Wireguard is only for 2 IPs in my Network (actually virtual mac addresses / IP in my Unraid for two docker containers including Plex)
Oops#1 Part1
<7>[42648.724938] iptable_filter ipheth ip_tables crc_ccitt compat cls_flower cdc_wdm cdc_acm br_netfilter arptable_filter arpt_mangle arp_tables act_vlan crypto_safexcel fuse cls_bpf act_bpf sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel tun ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha1_generic seqiv md5 des_generic libdes authencesn authenc mtdoops uas usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd
<7>[42648.812261] xhci_hcd uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list vfat fat exfat usbcore usb_common mii gl_sdk4_hw_info
<7>[42648.918547] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.15.134 #0
<7>[42648.924623] Hardware name: GL.iNet GL-MT6000 (DT)
<7>[42648.929308] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
<7>[42648.936249] pc : dev_watchdog+0x330/0x33c
<7>[42648.940244] lr : dev_watchdog+0x330/0x33c
<7>[42648.944238] sp : ffffffc00800bdb0
<7>[42648.947536] x29: ffffffc00800bdb0 x28: 0000000000000140 x27: 00000000ffffffff
<7>[42648.954652] x26: 0000000000000000 x25: 0000000000000001 x24: ffffff8000d5b4c0
<7>[42648.961769] x23: 0000000000000000 x22: 0000000000000001 x21: ffffffc008b26000
<7>[42648.968885] x20: ffffff8000d5b000 x19: 0000000000000003 x18: ffffffc008b3f3b8
<7>[42648.976004] x17: ffffffc037294000 x16: ffffffc008008000 x15: 000000000000051f
<7>[42648.983120] x14: 00000000000001b5 x13: ffffffc00800bae8 x12: ffffffc008b973b8
<7>[42648.990238] x11: 712074696d736e61 x10: ffffffc008b973b8 x9 : 0000000000000000
<7>[42648.997354] x8 : ffffffc008b3f368 x7 : ffffffc008b3f3b8 x6 : 0000000000000001
<7>[42649.004469] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
<7>[42649.011585] x2 : 0000000000000040 x1 : 0000000000000004 x0 : 000000000000003f
<7>[42649.018702] Call trace:
<7>[42649.021135] dev_watchdog+0x330/0x33c
<7>[42649.024783] call_timer_fn.constprop.0+0x20/0x80
<7>[42649.029385] __run_timers.part.0+0x208/0x284
<7>[42649.033639] run_timer_softirq+0x38/0x70
<7>[42649.037545] _stext+0x10c/0x28c
<7>[42649.040672] __irq_exit_rcu+0xdc/0xfc
<7>[42649.044322] irq_exit+0xc/0x1c
<7>[42649.047364] handle_domain_irq+0x60/0x8c
<7>[42649.051272] gic_handle_irq+0x50/0x120
<7>[42649.055010] call_on_irq_stack+0x20/0x34
<7>[42649.058918] do_interrupt_handler+0x4c/0x54
<7>[42649.063084] el1_interrupt+0x2c/0x4c
<7>[42649.066645] el1h_64_irq_handler+0x14/0x20
<7>[42649.070725] el1h_64_irq+0x78/0x7c
<7>[42649.074112] arch_cpu_idle+0x14/0x20
<7>[42649.077672] do_idle+0xc0/0x150
<7>[42649.080801] cpu_startup_entry+0x30/0x70
<7>[42649.084709] secondary_start_kernel+0x130/0x140
<7>[42649.089222] __secondary_switched+0x50/0x54
<4>[42649.093390] ---[ end trace 60d2f0ea286f4f61 ]---
<3>[42649.098013] mtk_soc_eth 15100000.ethernet eth0: transmit timed out
<3>[42653.742309] mt798x-wmac 18000000.wifi: wed reset complete timeout
<6>[42654.044058] mtk_soc_eth 15100000.ethernet eth0: Link is Down
<6>[42654.049751] mtk_soc_eth 15100000.ethernet eth1: Link is Down
<1>[42654.573245] Unable to handle kernel paging request at virtual address ffffffffd4780000
<1>[42654.581159] Mem abort info:
<1>[42654.583962] ESR = 0x0000000096000145
<1>[42654.587694] EC = 0x25: DABT (current EL), IL = 32 bits
<1>[42654.592994] SET = 0, FnV = 0
<1>[42654.596033] EA = 0, S1PTW = 0
<1>[42654.599157] FSC = 0x05: level 1 translation fault
<1>[42654.604023] Data abort info:
<1>[42654.606887] ISV = 0, ISS = 0x00000145
<1>[42654.610705] CM = 1, WnR = 1
<1>[42654.613662] swapper pgtable: 4k pages, 39-bit VAs, pgdp=0000000048aa3000
<1>[42654.620341] [ffffffffd4780000] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
<0>[42654.629023] Internal error: Oops: 96000145 [#1] SMP
<7>[42654.633884] Modules linked in: pppoe ppp_async option wireguard usb_wwan rndis_host qmi_wwan pppox ppp_generic nft_fib_inet nf_flow_table_ipv6 nf_flow_table_ipv4 nf_flow_table_inet mt7915e mt76_connac_lib mt76 mac80211 libchacha20poly1305 ipt_REJECT huawei_cdc_ncm chacha_neon cfg80211 cdc_ncm cdc_ether xt_time xt_tcpudp xt_state xt_recent xt_quota xt_pkttype xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_helper xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_cgroup xt_addrtype xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_CT usbserial usbnet slhc poly1305_neon nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_objref nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_counter nft_compat nft_chain_nat nf_tables nf_reject_ipv4 nf_log_syslog nf_flow_table nf_conntrack_netlink nf_conncount mdio_netlink libcurve25519_generic libcrc32c libchacha iptable_nat iptable_mangle
<7>[42654.634025] iptable_filter ipheth ip_tables crc_ccitt compat cls_flower cdc_wdm cdc_acm br_netfilter arptable_filter arpt_mangle arp_tables act_vlan crypto_safexcel fuse cls_bpf act_bpf sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel tun ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha1_generic seqiv md5 des_generic libdes authencesn authenc mtdoops uas usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd
<7>[42654.721349] xhci_hcd uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list vfat fat exfat usbcore usb_common mii gl_sdk4_hw_info
<7>[42654.827634] CPU: 1 PID: 3359 Comm: kworker/1:1 Tainted: G W 5.15.134 #0
<7>[42654.835529] Hardware name: GL.iNet GL-MT6000 (DT)
<7>[42654.840216] Workqueue: events mtk_pending_work
<7>[42654.844650] pstate: 40400005 (nZcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
<7>[42654.851590] pc : dcache_inval_poc+0x3c/0x54
<7>[42654.855760] lr : arch_sync_dma_for_cpu+0x1c/0x2c
<7>[42654.860359] sp : ffffffc010b4bc10
<7>[42654.863657] x29: ffffffc010b4bc10 x28: ffffff803fda3e70 x27: ffffff800c6b9700
<7>[42654.870773] x26: 0000000000000008 x25: 0000000000000000 x24: 0000000014780000
<7>[42654.877888] x23: 0000000000000800 x22: 0000000000000000 x21: 0000000000000002
<7>[42654.885004] x20: ffffff8000094010 x19: 0000000014780000 x18: 0000000000000070
<7>[42654.892119] x17: 0000000000000000 x16: 0000000000000000 x15: 3700060049100301
<7>[42654.899235] x14: ffffffffffffd9f8 x13: 0000000000002c00 x12: 0000000000000006
<7>[42654.906350] x11: ffffffc008b144d0 x10: 0000000000000000 x9 : ffffffc037294000
<7>[42654.913466] x8 : 0000000010000000 x7 : 0000000000000000 x6 : 0000000000000200
<7>[42654.920582] x5 : ffffffc0088d32a0 x4 : 0000000000000000 x3 : 000000000000003f
<7>[42654.927698] x2 : 0000000000000040 x1 : ffffffffd4780800 x0 : ffffffffd4780000
<7>[42654.934814] Call trace:
<7>[42654.937246] dcache_inval_poc+0x3c/0x54
<7>[42654.941067] dma_unmap_page_attrs+0x18c/0x1a0
<7>[42654.945411] mtk_rx_clean+0xa4/0x190
<7>[42654.948970] mtk_dma_free+0x160/0x234
<7>[42654.952617] mtk_stop+0x26c/0x2dc
<7>[42654.955916] mtk_pending_work+0x78/0x1cc
<7>[42654.959823] process_one_work+0x210/0x3b0
<7>[42654.963817] worker_thread+0x170/0x4d0
<7>[42654.967550] kthread+0x11c/0x130
<7>[42654.970766] ret_from_fork+0x10/0x20
<0>[42654.974329] Code: 8a230000 54000060 d50b7e20 14000002 (d5087620)
<4>[42654.980402] ---[ end trace 60d2f0ea286f4f62 ]---
Panic#2 Part1
<0>[42654.991061] Kernel panic - not syncing: Oops: Fatal exception
<2>[42654.996789] SMP: stopping secondary CPUs
<0>[42655.000697] Kernel Offset: disabled
<0>[42655.004168] CPU features: 0x0,00000000,20000802
<0>[42655.008681] Memory Limit: none
admon
December 31, 2023, 8:44pm
11
They are normal - just ignore it.
houmi
December 31, 2023, 9:17pm
12
I noticed in top that adguard was using 74% of VSZ (Virtual Memory?) in idle. I disabled AdGuard to see if it makes these crashes go away.
alzhao
January 1, 2024, 3:24am
13
houmi
January 1, 2024, 3:43am
14
I updated to 4.5.5, will let you know if it crashes again.
houmi
January 1, 2024, 5:10am
15
Got the router to crash again on that firmware (blinking light) had to remove ac power and reconnect. No crash log available.
I kinda wish this router had a power on/off button.
I see a bunch of kworkers and napi/mtk_eth-# , but the load is always < 1.0
I’ll keep a top open in case I see something out of ordinary.
houmi
January 1, 2024, 11:42pm
16
Quick update, no crashes so far with the latest firmware.
Though my Wireguard testing has been minimal, I suspect these crashes were because of Wireguard.
Update
I got it to crash again… basically if i use the wireguard connection too much it happens. I have a reverse connection for Plex from the outside (so people stream via the outside) I also have a few downloads happening via wireguard, so it’s being stressed. If there are ways to enable debug log for wireguard, I can enable them… I don’t see any dump files nor crash logs.
Cheers
alzhao
January 2, 2024, 3:21am
17
The old logs seems a crash of the Ethernet driver.
Do you have the log from 4.5.5 crash?
houmi
January 2, 2024, 3:53am
18
Nothing in the crash logs, the router just locked up.
Unless they get written to some log files on disk ?
Magges
February 9, 2024, 6:29am
19
well, i kinda have the same Problem with mine with Wireguard as a Client connect to a Provider and Adguard Running. Random Hangups with no connection to the Router only when i unplug and replug it.
Any Solution known or cause until now?
admon
February 9, 2024, 6:30am
20
Hey
please follow these instructions to provide more information for troubleshooting: How to get support quickly
