Flint 2 + Huawei MS2372h - 153 4G Stick
Hi everyone, I'm using the Flint 2 and I am very happy with it.
Now I wanted to upgrade it with a 4G dongle.
Unfortunately, I can't get an active connection.
I entered the APN settings correctly.
What else could I try?
What could be the Problem?
The SIM card doesn't have an active PIN and work in the Puli without Problems.
Many Thanks.
In GL Puli router, does it show that the connection method to Huawei MS2372h is tethering or modem?
In GL Flint 2 router, what connection method will it display? As GL firmware does not support Huawei modem, can you switch Huawei modem to control dialing by itself, and so that it can be connected to Flint2 through tethering (RNDIS)?
If you plug stick into computer does it work?
For decades I have had good luck with USB LTE devices on routers. I didn't look up that exact model of yours, but some do very good in Linux.
I'd double check your phone to see if you can tether it.
As mentioned above, there are many AT commands that might be used to interrogate the modem.
Many Thanks to all.
The Stick not work at the PC too.
Maybe it was changed by Vodafone using AT commands.
but it would be too complicated for me.
Now I have buy a new RM520N-GL Card.
Does vodafone have support?
No. But it's not that bad.
I've now bought a other module.
I assume the new device is working.
Now with RM520N-GL everything works perfekt.
