Flint 2 is not showing clients connected to Opal in extender mode
I have a Flint 2, running the primary wifi network.
I used an opal travel router in extender mode to provide wired network access to 2 devices connected to the LAN ports.
The connected devices are getting IP address in the same subnet as the main, and I can see them on the client list on the Opal’s admin GUI.
However I cannot see either Opal itself or the two LAN clients on the Main router (Flint 2) GUI.
I should see 3 new MACs but I see none, not even the Opal’s MAC.
Is this expected behavior for clients on the extender mode ?
Hi!
In Extender mode, the main Flint 2 router should display the MAC address of the Opal device.
However, the client devices connected through Opal will not appear on the Flint 2’s client list.
To view those clients, please check the Opal’s client UI instead.
If the Flint 2 does not show the Opal’s address, it may indicate that the Opal has not successfully connected to the Flint 2. In that case, please verify the Opal’s connection status again.
