Flint 2 - missing firewall options?
I just bought a Flint 2, and one thing I cannot find is the Firewall.
It is nowhere to be found.
The router is in Router mode. IS there a reason I cannot find it?
Do you mean in the GL GUI, which function is not found, port forwarding?
The GL GUI menu does not have the feature "firewall", but it has the menu Security in the GL GUI > System > Security.
And the Firewall is in Luci > Network > Firewall.
