Flint 2 MT 6000 still reboots every one hour
Work stable only 4.7.7. firmware and older. All newer firmware (stable, beta, based owrt - reboot router every 1 hour.
Clean OpenWRT work flawlessly.
Capture a persistent system log on a newer GL.iNet firmware so the entries immediately before the hourly reboot survive. This will help distinguish a scheduled service restart from a kernel crash:
uci set system.@system[0].log_size='512'
uci set system.@system[0].log_file='/root/system.log'
uci commit system
/etc/init.d/log restart
After the next reboot, retrieve /root/system.log. Do not post the full log publicly because it may contain network details; send it by private message to a GL.iNet technical support member, together with the exact firmware version and the approximate reboot time. You can click a staff member’s avatar and select Message.
Thank you for your feedback.
To help us investigate this issue further, could you please send us the MAC address printed on the label of your Flint 2 via private message?
Thank you for your patience and cooperation.
How to send private messages:
