Hello! My Flint 2 mt6000 reboot every 1 hour. When uptime section shows “1 hour” - it loses all connections. All reboots. No additional devices via lan is connected.
Solved.
Hard Reset and back to 4.7.7
Hi there. I seem to be having an issue with my Flint 2 that is very similar to what you experienced, except it’s more like every 20-60 minutes.
Out of curiosity, what firmware version were you on before you rolled back? Will try rolling back to 4.7.7 too since that worked for you.
Thanks.
I am trying to determine whether my Flint 2 (GL-MT6000) may have a hardware fault.
I installed the router yesterday when my full-fibre connection was activated. Since installation, the router appears to reboot spontaneously every 10–60 minutes.
Observed behaviour
When the issue occurs:
The network freezes briefly.
The router LEDs cycle as if the device is restarting.
Wi-Fi and Ethernet both drop.
The admin panel session is lost.
Router uptime resets to 0.
During the event, continuous pings to the router also fail.
Example:
ping 192.168.1.1 -t
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Request timed out.
Request timed out.
The outage lasts roughly 45–60 seconds, consistent with a reboot cycle.
Firmware history
Initially running beta firmware
Rolled back to Stable 4.7.7
Multiple factory resets performed
Issue persists on the stable release
Troubleshooting steps already taken
Factory reset (multiple times)
Wireless configuration simplified:
WPA2-PSK only (WPA3 disabled)
Fast roaming (802.11r) disabled
Smart Connect / band steering disabled
Manual channel configuration:
2.4 GHz → Channel 1, 20 MHz
5 GHz → Channel 36, 80 MHz
Hardware acceleration tested:
ON
OFF
Issue occurs in both configurations.
Multi-WAN interface status tracking disabled.
Environment
Router: GL-MT6000 (Flint 2)
Firmware: Stable 4.7.7
WAN: PPPoE via FTTP ONT
Clients: mix of wired and wireless devices
Frequency: roughly every 10–60 minutes
The issue affects both wired and wireless connectivity simultaneously.
Log observations
Just before the event I see repeated WPA handshake failures from multiple clients:
WpaEAPOLRetryAction(): 4Way-MSG1 timeout
Send DEAUTH frame
MacTableDeleteEntry()
Recv Assoc from STA
ASSOC Send ASSOC response
Example:
4Way-MSG1 timeout with 48:e1:e9:3b:08:b9
4Way-MSG1 timeout with cc:3b:fb:e3:cc:58
4Way-MSG1 timeout with c4:db:ad:0e:59:37
In earlier logs I also noticed:
warp_probe(): probe fail since warp is full
warp_dev0: probe of 15010000.wed2 failed with error -1
ExtEventBeaconLostHandler(): AP Beacon OFF!!!
Questions
Are spontaneous reboots like this a known issue on the MT7986 platform or the Flint 2 firmware?
Could the
warp_probe/ WED errors indicate a driver issue? -
Given the behaviour on stable firmware and after factory resets, does this point toward a potential hardware fault?
I can provide full log bundles if needed.
Any guidance would be appreciated. Thank you.
4.7.7 work flawlessly. Today update again to 4.8.3. Reboot every 1 hour
