Can Flint 2 have more than 2 networks (SSIDs)? My goal is to have 2.4GHz and 5GHz with regular network and 5GHz with VPN running as an additional network, so I can quickly switch between countries.
In addition, can I have multiple VPN countries set up on the router?
But since that is using the CLI you may also want to watch soms videos by onemarcfifty to get familar with the ui.
though i want to advise to use the guest network interface vs creating a new interface because only lan and guest are covered by the scripts for vpn policies.
No this is not possible, the vpn software inside gl-inet does not support multiple vpn clients, the normal OpenWrt without gl-inet software does, you can do a 'split tunnel' and route different local ips to different vpn or wan.
