Flint 2: Netlink receive failure: Out of memory
I see many error out of memory, i have always free memory on router (v4.8.3-op24),
I use banip, all world is blocked only my country is whitelisted
Thu Nov 27 10:47:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 10:47:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
Thu Nov 27 10:57:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 10:57:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
Thu Nov 27 11:07:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 11:07:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
Thu Nov 27 11:17:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 11:17:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
Thu Nov 27 11:27:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 11:27:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
Thu Nov 27 11:37:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 11:37:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
Thu Nov 27 11:47:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 11:47:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
Thu Nov 27 11:57:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 11:57:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
Thu Nov 27 12:07:22 2025 daemon.err nlbwmon[7533]: Netlink receive failure: Out of memory
Thu Nov 27 12:07:22 2025 daemon.err nlbwmon[7533]: Unable to dump conntrack: No buffer space available
This appears to be a known issue with nlbwmon:
Please try manually adjusting the following Linux kernel parameters to see if it improves the situation:
sysctl -w net.core.rmem_default=16777216 \
net.core.wmem_default=16777216 \
net.core.rmem_max=16777216 \
net.core.wmem_max=16777216
If this resolves the issue, you can add these settings to /etc/sysctl.conf so they are applied automatically at boot:
echo "net.core.rmem_default=16777216
net.core.wmem_max=16777216" >> /etc/sysctl.conf
