I just ran a snapshot 4.5.7 on the Flint 2 (2024-02-27), but its becoming more unresponsive for me.
here is one example to demonstrate what I mean:
- First i remove all firewall zones, put all global rules to accept and disable dnsmasq and firewall and then remove all interface such as
wwan
,modem
,secondwan
until i only have wan and lan. - Then I create a DSA bridge named
br-wlan0
, and addeth1.50
(eth1
is the wan interface) and select checkboxkeep up bridge
- create a interface
wlan0
with protocol dhcp using this bridge device.
result no dhcp client ip has been given, I can see TX and RX but no ip resolution.
interestingly if I change the device of interface wlan0
to eth1.50
it works.
I even reset my main router to make sure my gretap interface was not the one interfering, this issue is new for me because it always worked in a bridge.
when I played too much with it, the router locked up, and dropped my packets with a time out.
^ this is not true, I noticed the ip was changed on wan so thats fine.
my main router uses OpenWrt snapshot: r25246-bf304d10e9
and my dumbap the one I got issues with: 4.5.7 (2024-02-27)
also I got a suggestion for the dl.gl-inet.com site
there is no way for me to copy the checksum it only shows when hovering but I cannot copy it or click it to copy, that would be very useful.
