Hello everybody! Just received my Flint 2 and got problems. Everything works with defaults, but then I changed the router IP adress from 192.168.8.1 to 10.0.0.0 and both Wi-Fis lost connection to the internet. LAN works fine. Funny thing is both Guest Wi-Fis still work with default settings. Is there anything I am doing wrong? Or is it a firmware problem?
What is your subnet?
What is the upstream router's subnet?
Are you using vpn server or client?
I didn't change anything else other than the router IP, everything else is on default.
Subnet is 255.255.255.0
Upstream is a CH7465VF coaxial cable modem from my ISP running in bridge mode with subnet 255.255.248.0 and IP 192.168.100.1
No VPN running.
I tested on my MT3000.
The computer on LAN changed IP address immediatelly to 10.0.0.x and work correctly.
While the phone on wifi remains 192.168.8.x. I need to turn off wifi and reconnect and it update IP to 10.0.0.x and works fine.
You can do the same.
I put 10.0.0.1 and it works fine. But 10.0.0.0 still doesn't. As soon as I apply the setting, the wifis cut the internet access. I guess .0 is reserved or something or generates some kind of conflict.
Also from an online subnet calculator, for 10.0.0.0/8 i get the subnet 255.0.0.0, but the dropdown menu only allows 255.255.255.0 or 255.255.0.0. I guess I'll just keep it 10.0.0.1 and be done with it. Thanks for the help!
I tested 10.0.0.0 and it works perfectly with Windows11.
But it has some problem with my iPhone and Andriod.
Yeah, it works on LAN, but the Wi-Fi doesn't get internet. That's why I've said it's a conflict. If you put 192.168.0.0 the box gets a red border and you can't save the settings. Probably somebody forgot to implement this for 10.0.0.0. Haven't tried 172.16.0.0, I don't like those numbers haha.
I tested 172.16.0.0, not valid.
Yes only 10.0.0.0 is forgot by developers.
But worth to do further check.
