Flint 2 - notification on failover
I have a Flint 2 router, with WAN1 set as my primary internet connection and WAN2 as my backup (using a hotspot connected via Ethernet).
I’ve tested the failover process by disconnecting the WAN1 Ethernet cable, and the router successfully switches to the WAN2 hotspot.
My question is: I want to receive an email alert when this failover happens. I’ve set up a PowerShell script that runs SSH commands on my machine via Windows Task Scheduler, checking every minute. The script checks if WAN1 is UP, and if it’s DOWN, it successfully sends an email alert.
However, I’m wondering how to track the situation when WAN1 is UP, but there’s no internet connection, and the router switches over to WAN2. How can this scenario be detected via SSH commands?
Alright i was able to figure out, by using ping via eth1
Forces ping through WAN1
'ping -I eth1 -c 3 8.8.8.8'
and based the 100% packets lost, i get notification, it is working correctly now. :partying_face: :partying_face:
If anyone wants the power-shell script, let me know. it was a pain to get it working had to use chatgpt's help due to parsing errors. long live the gpt! :smiley: lol
I would like to do something like Flint 2 - notification on failover - #2 by subzero06 on my Marble.
@subzero06 could you please share the script you did via ssh? I will be doing that from a windows pc too.
Hi - you can see the script here:
you need putty so that it uses it for ssh connection and create a blank “counterData.json” and smtp for emailing - i have it so that when it triggers outage it sends me email to my “pushover” app via email and pushes notifications on my phone.
  • My setup is Flint 2 via (main) ethernet and my failover is using via usb (hotspot backup) - you can modify the script as it suits your needs.
Many many thank you!
For all the others, in Marble, they should be “eth1.1” and “eth.1.2” instead of the ones you posted.
I needed to change the SHA256 as well even if there was no variable at the beginning (you can obtain it after a first succesfull connection via ssh outside of the script) and there is no need to create a blank file json because it will crash if the file is empty, the file will be created itself by the script itself.
I will modify the script to call a callback instead because I want the alert biz logic to be handled by Homey or Home Assistant
