Since updating to firmware v4.11.0 (stable version, not beta), everytime I make a change to reserved IP's (e.g., adding a new one), the entire network connection drops for a short bit, it does automatcally reconnect but if streaming music as an example, the stream stops until manually restarting it. This scenario never happened prior to the update. And I have also experienced connection issues with sonos speakers (all newer versions like the ERA's) even though they have had static ip's assigned since day 1 and run outside the vpn tunnel.
No concrete "evidence" but as stated, this did not happen with earlier firmware versions with same config.
Just wondering if anyone had any ideas what is happening? Possibly a bug?
I'm on the stable 4.11.0 version. I am considering flashing the 4.11 OpenWrt 25 version though because of the kernel age since, tbh, I wouldn't have a clue on backporting the kernel. I'm just a basic user, a novice here, nothing advanced in what I do so it's a learn as I go scenario.
Something I did though that apparently prevented the complete network restart when assigning/reassigning static ip's was to make the ip reservations in the Flint GUI and rather than select "apply", I went to terminal and restarted dnsmasq from there. This seemed to have accomplished the assignment of the reserved IP's without a complete network restart, which seems to be what the "Apply" does in the GUI.
And thank you for the reply. I did go to that post you cited and after reading comments there am feeling more comfortable with doing the update to OP25.
Adding or editing an IP reservation in the GL.iNet web interface on v4.11 automatically applies the change and restarts dnsmasq in the background. You do not need to click Apply or restart dnsmasq manually.
The Apply button reapplies the LAN network settings and restarts the corresponding LAN interface, briefly interrupting connections. It is needed when changing settings such as the router’s LAN IP address.
We’ll discuss with our product and development teams whether the Apply button can be disabled when there are no pending LAN settings changes.
Thank you for the explanation, now it makes much more sense. I completely misunderstood the use of the Apply button. I assumed that since it was active it was necessary to use it for the reserved ip changes to take effect.
Much appreciated. And, tbh, I wouldn't worry too much about having the team put much effort into disabling the button if no pending LAN changes. It may be more beneficial to have time/effort directed to larger concerns. So a nice to have....
