Mu Flint 2 is no longer accepting a login password. Have done the 10 second reset which asked me for a new password which I set. But still will not login
I had downloaded a snap shot version - I think it was version 4.8.0-0611
Any ideas?
Any ideas?
Never, never, never install an snapshot unless explicitly requested by someone from GL-iNet
It's probably due to the same reason reported here:
the same for me, after installed the snapshot you said, no login, after reset and set new password the same problem.
Only way for me are the Recoverymode like here:
So my MT6000 come back with 4.7.7. Firmware
Thank you all - Unbrick has worked
