On a FLINT 2 I have a lot of problems during a PPPoE establishment.
From the logs (that now I lost because a reboot) you can see that the port goes up and down.
Sometimes goes down after a successful PPPoE registration sometimes before.
I'm using the latest 4.6.4 with MTK sdk.
Please share your logs ![]()
Please try to fix the interface negotiate rate, probably it related to the compatibility issue between the 2.5Gbps.
ifconfig
//Confirm which one interface is the WAN, say if the eth1 is the WAN and fixed 1000Mbps:
ethtool -s eth1 autoneg off
ethtool -s eth1 speed 1000
