Greetings,
I got flint 2 recently, and I tried to connect PPPoE however, it does not work.
Specs:
- Network Setup: ONT that provides ethernet cable, and the ONT is connected to a fiber cable.
- router model: flint 2 MT6000.
- from the box firmware version : 4.5.6
- from the box OpenWrt Version: OpenWrt 23.05-SNAPSHOT r23001+721.
- from the box Kernel version: 5.15.139
- Using pre-installed OpenWrt from GL.iNet.
- I have upgraded the firmware to: 4.5.8 I downloaded it from the stable tab and then applied the upgrade from System -> Upgrade -> Local Upgrade tab and used the default config "Keep Settings" is ON as i'm unsure if I need to disable this or not.
- OpenWrt Version after firmware update: OpenWrt 21.02-SNAPSHOT r15812+1071.
- Kernel Version after firmware update: 5.4.238.
- before the upgrade I tried PPPoE using the default firmware version, however it only showed first log Unable to complete PPPoE Discovery.
Please note that I updated the firmware because in some replies I found on this forum that when the upgraded the firmware PPPoE worked fine.
in order to have PPPoE connect I found that I need:
- username/password PPPoE.
- maybe a VLAN id.
- maybe I need to try enabling ipv6 and check.
- maybe changing the router MAC address to the same ISP router MAC address (I don't know how I can do this).
So, I got the username/password and VLAN id from the provided router by the ISP.
Here's what I got when connecting the ethernet from ONT ethernet to the router in WAN interface:
Timeout waiting for PADS packets
Exit.
Plugin rp-pppoe.so loaded.
RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
pppd 2.4.8 started by root, uid 0
and then when I enabled IPv6 NAT6 the logs changed however, after I tried changing the IPv6 from NAT6 to Native the previous log returned back and then I never got the following log again:
Connection terminated.
Sent PADT
Exit.
Please I need your support.
