Flint 2 problem with vpn kill switch
Hi, I bought the Flint 2 to have gigabit ports. I previously had the GL.iNet AX1200 configured with a WireGuard client for the main Wi-Fi network, and a guest network with internet access without VPN. The killswitch worked correctly: if the VPN dropped or I clicked “disconnect,” the PCs connected to the main Wi-Fi network would no longer have internet access.
I tried to recreate this setup on the newly purchased Flint 2, but it no longer has VPN policies, and the killswitch now also blocks the guest network, which is on a different tunnel.
I read that this was a known bug fixed in version 4.8, but even after installing the beta firmware, I still can’t achieve what I need.
There are several topics about this issue, but I haven’t found any solution.
Thank for your help
The v4.8.0 firmware still supports various VPN policies, but you need to switch to policy mode first, including interfaces:
In Primary Tunnel settings :gear:, it is possible to enable killswitch.
Thank you for your message, i make the same config After update from official version but it not work . I make a factory reset and make same config and it work good. Maybe there are some corrupt data from previus firmware . Thank you
Hey @bruce, I have some related questions here, would be great if you could assist: How does the VPN Kill Switch really work?
