time to time my flint 2 reboot randomly in interval from 15 miutes to 1h. it stat maybe 3 week ago
In system log there no errors, and kernel log blank
firmware stable 4.8.3, wifi both enabled 2.4, 5, try to play with hardware acceleration - reboots still present. cpu load ±1%, temperatures about 40-50c
week ago have issue, that router heated to 70c with no load, playing hardware acceleration doesn’t help too
trying to reflash from uboot - help for a week.
have thoughts to flash snapshot, but not sure that it will help
Could you also confirm whether the power supply is consistent? Please check the power adapter for any visible damage, and make sure that the wall outlet or extension cord is in good condition.
Which power adapter are you using? Is it the original one, or one that meets the 12V/4A specifications?
Does the ambient temperature range between 40 and 50°C? Or is this the CPU temperature displayed in Admin Panel > System > Overview? If possible, try adding a small external fan to the Flint 2 to enhance cooling.
Please SSH into the router on a wired connected device and run the following command to continuously print system logs and memory usage.
Keep the terminal open, and after the issue occurs, capture and send us the output via private message.
logread -f &
while true; do free -h; echo '-----------------'; sleep 5; done
