Flint 2 refuses to connect to xfinity through Netgear modem
I have no problem using a Slate 7 on the same modem. The log is as follows:
Tue Apr 22 17:01:37 2025 kern.info kernel: [ 126.181004] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
Tue Apr 22 17:01:37 2025 kern.info kernel: [ 126.189632] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Tue Apr 22 17:01:37 2025 daemon.notice netifd: Network device 'eth1' link is up
Tue Apr 22 17:01:37 2025 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Apr 22 17:01:37 2025 daemon.notice netifd: Interface 'wan' is setting up now
Tue Apr 22 17:01:37 2025 daemon.notice netifd: wan (12433): udhcpc: started, v1.33.2
Tue Apr 22 17:01:37 2025 daemon.notice netifd: wan (12433): udhcpc: sending discover
Tue Apr 22 17:01:39 2025 daemon.info avahi-daemon[5502]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::9683:c4ff:feab:6cd3.
Tue Apr 22 17:01:39 2025 daemon.info avahi-daemon[5502]: New relevant interface eth1.IPv6 for mDNS.
Tue Apr 22 17:01:39 2025 daemon.info avahi-daemon[5502]: Registering new address record for fe80::9683:c4ff:feab:6cd3 on eth1.*.
Tue Apr 22 17:01:40 2025 daemon.notice netifd: wan (12433): udhcpc: sending discover
It seems to be using IPv6, even though that option is turned off.
Any suggestions?
Thanks!
What firmware does the router use? If v.4.7 then may be it makes sense to try 4.6.8 (the latest stable one based on OpenWRT 21)?
Please check if the MAC black/white list is enabled by the primary router?
The IPv6 related log is mDNS multicast, it can be ignored.
From the log, the WAN in DHCP mode, udhcpc sends 2 times discover requests for IP, but seems the primary router does not offer IP, so the Flint 2 WAN cannot obtain IP
