Connect the local network cable to the WAN/LAN1 port
System/Reset Firmware – Delete all and reboot
Set an IP address from the 192.168.8.0/24 network on your device
Open 192.168.8.1 in a browser
Select language and click next
Set the password for the Admin user (root in LUCI) and click Apply
Change Ethernet port 1 (WAN as labeled under the port) to LAN. Now both 2.5 Gb ports are on the LAN
Network/LAN Change the router’s IP to your desired LAN IP (If you have DHCP, reserve it in the DHCP or set an IP outside the DHCP range) in my case 192.168.10.6/24 and click Apply
Access the router's IP from the browser, in my case 192.168.10.6, enter the password, and log in
In my case, disable DHCP in the Network/LAN menu (I don’t want to use this, I would set it as a relay, but it doesn’t have that option, unfortunately) and click Apply
System/Time Zone “Sync” if it detects the time zone from your computer, or set the desired time zone and click Apply
Applications/Plug-ins and confirm that no plug-ins are available for installation, only the installed ones are shown (we’ll fix this now)
System/Advanced Settings and access the address shown on the right, in my case: 192.168.10.6/cgi-bin/luci
Enter the password and log in
Go to Network/Interface, a warning will appear, accept “Continue”
Click “Edit” on the LAN Interface (br-lan)
Interfaces >> LAN / General Settings enter the IPv4 gateway, which is the IP of the router that connects to the internet (the ISP router in my case) 192.168.10.1 and click Save
It returns to the Interfaces screen, click Save & Apply at the bottom
Now we can verify internet access. Go to Network/Diagnostics and change the first field from openwrt.org to a known internet IP and click IPv4 Ping, in my case I used 1.1.1.1 and it should respond
If you don’t enter an IP and leave it as it is, you will receive this message: since no DNS is configured (we’ll set it now), but we already have internet access
(Image 2) -
Go to Network/DHCP and DNS, in General Settings, enter at least one DNS Forwarding, in my case, I enter my ISP router’s IP (192.168.10.1) since it accepts DNS resolution requests, but you can enter any internet DNS IPs you want (8.8.8.8 or 8.8.4.4 or 1.1.1.1 or whichever you prefer) and click Save & Apply, the left button at the bottom
Go back to Network/Diagnostics and this time everything should work (all three tests)
Now let’s check the Plug-ins, go to System/Software and click the green “Update lists…” button; it will access the internet and download the list of updatable items, something like this should appear:
(Image 3) -
Click Dismiss and return to the Software screen where you will see everything available for installation (several pages)
(Image 4) -
Return to the gl.inet Interface to Applications/Plug-ins and see the same list, you can install but not update “refresh”, this must be done from LUCI
(Image 5) -
And the message above, of course.
Then I configure “my stuff”, like WiFi, TailScale, etc.
I can't upload more than one image, but I hope this helps.
Flint 2 Config.zip (271.6 KB)
