Anyone else super slow accessing their share on android? Takes like 10 seconds to open each folder. On pc works great.
Im using folder sync and file manager +.
open a folder takes 10 secs in Android? Looks like the APP issue, please try the APP ES File Explorer.
May I know if the PC is laptop and connected the Flint 2 with wireless? and work ok?
if possible, test more with different Android phone.
Ive tried a few different file explorers same thing. Pc is windows desktop. Both phone and pc wireless.
Any folder super slow to load. I got a nas box with samba and all folders load really fast on phone and pc same app.
As the mentioned 'On PC works great' this time the PC is connected the router via the cable?
Probably the USB3.0 port interfere the WiFi speed, but only affect 2.4GHz, not 5GHz.
Further check:
Speed test 400 down 30 up on phone or pc with usb drive. Phone and pc hooked to 5ghz wifi.
Since I did not reproduce the issue in my router.
Did you mind furthermore tests with me please?
May I know what connection method of the PC when the USB drive connected, cable?
