Flint 2: unable to connect to adguard home settings
Flint2, 4.7.0
I try adguard home on flint 2 for the first time.
It seems to work in default configuration:
but i cannot open adguard settings page:
Unable to connect
Firefox can’t establish a connection to the server at 192.168.1.1:3000.
or trough chromium:
Your Internet access is blocked Firewall or antivirus software may have blocked the connection.
Try:
Checking the connection
Checking firewall and antivirus configurations
ERR_NETWORK_ACCESS_DENIED
Connection is from device on the same subnet as router (not from vpn, wan or guest network)
Did you change your routers IP to 192.168.1.1? Because default is 192.168.8.1
yes, lan is int 192.168.1.0/24 with router at 192.168.1.1
Have you tried open page router on your phone with WiFi Flint2?
When i try from phone to connect to 192.168.1.1:3000, firstly router ask for password and log me in webgui to the main page 192.168.1.1/#internet
Then, i re-type 192.168.1.1:3000 and have the same " Unable to connect"
:face_with_diagonal_mouth:
You need first open GL gui (192.168.1.1) and click link "Setting Page" to open Adguard home.
That link, Setting Page, redirect to 192.168.1.1:3000
Yes, which special cookies without login page in Adguard home.
If not working that's means port changed or conflict DNS server for isp side ?
As I understand it is defenetly on port 3000:
With adguard disabled:
root@GL-MT6000:~# netstat -tuln | grep 3000
With adguard enabled
tcp        0      0 :::3000                 :::*                    LISTEN
Change lan IP back to default, reboot router and see if you can get in to settings. Let me know what happens.
Well, i have no idea there is an issue: I cannot connect from phone or my main windows PC.
but i can from:
  • A VM in bridged mod on the same windows PC
  • From linux boot on the same PC
  • From windows laptop
Everything is fine with router, some crazy stuff going with equipements
