Renato
March 25, 2024, 10:34am
Is there any way to create a VLAN on Flint 2 where the VPN is set only for it?
I would like something like this:
SSID 1: just the Adguard running on it;
SSID 2: it will be used to connect IoT, running Adguard + VPN Client
Or should I buy just another device (like GL-S200 ) for this purpose?
My IoT are connected to Sonoff NSPanel Pro (Zigbee ones) and others by the WiFi.
admon
March 25, 2024, 10:45am
2
It’s built-in: VPN Dashboard - GL.iNet Router Docs 4
Proxy mode: Based on the VLAN
But using AGH will create additional trouble. Might be possible that you can’t use AGH + VPN on some VLANs the same time because AGH will expose your IP then.
Renato
March 25, 2024, 11:00am
3
Thanks, so I’ll probably add an GL-S200 for this purpose
