Flint 2 VPN Problem after 4.8.2 update
Hi there,
I use the Flint 2 with PIA VPN set to a US Server. I have various devices connected, like Fire TV, Google Home, Nest Hubs and My Cellphone. Everything worked perfectly until the update to Firmware 4.8.2.
Since the update all devices work EXCEPT my 3 Nest Hubs. They won't accept any command, I get the Answer : something went wrong. The only server I get the hubs to work with is PIA US east coast streaming optimized. However that server causes problems with many websites and apps on my cell phone. So that's not a great Option, besides I need the US Florida server most of the time. I connect to PIA over Wire guard. I also have a Nordvpn account. If I connect to the NORDVPN US Server (there is only one in Seattle) my Hubs work fine. Any idea what the problem could be? I can send a log if needed. But it's strange that only my Nest Hubs don't work. My Google Home works just fine.
Thanks for any help in Advance.
When the router VPN (PIA/NordVPN) is disabled, do the Hubs work properly?
Yes, they work with VPN off, as well as Nord Vpn over Wire guard or even PIA over OPENVPN. But with PIA VPN over wire guard they only work on one server - not the one I need and have used for many months before the update.
It looks like the VPN server or Nest hub server probably block the traffic.
If you downgrade the firmware of Flint2 to v4.7.7, does it work fine?
I also have the same problem with my blink doorbell, it’s Amazon blocking the vpn connection. This is the only drawback with vpn usage.
