Old ISP router works just fine but my new Flint 2 wont connect to the internet. I have followed my ISP's instructions and tried to connect via PPPoE with no luck. I called my ISP and they have confirmed the user/pw is correct and cannot help further.
I have tried:
cloning my previous routers MAC address
disabling IPv6
nslookup returns nothing
My previous ISP provided router is connected via DHCP.
Thanks
- Which router (which model?) are you using? - GL-MT6000
- Which firmware version is in use? - 4.5.8
- How is your router connected to the Internet? - Router connected to Arris CM8200B via ethernet cable
- Which DNS server do you use? - local
