Updated to 4.8.4 firmware on my Flint 3 last night. Right away after the router rebooted I noticed the update had cleared the URL exclusion list for the VPN.
Luckily, I only had 5 or 6 URLs so I was able to re-add them from memory. If someone had dozens or hundreds though, they'd have a bad day.
Is there any way inside the UI to backup this list? Or easier to just manually copy & paste into a txt file?
Thank you for your feedback. We’ve confirmed this issue and will fix it in a future release.
At the moment, it only occurs when the VPN remains enabled during the upgrade process. You can resolve it simply by disabling and then re-enabling the VPN.
